question regarding datapools [message #98649] |
Tue, 15 May 2007 10:05 |
Originally posted by: Eitanush.gamil.com
I would like to tun the same test (that I created using the AGR), but with
different selections.
For example build the same project on diffrent configurations.
I thought I could do this using datapools but as far as I understood the
datapool is good only when user enters text. Am I correct?
Is there a convenient way to cause a test, created with AGR, run with
different selections?
Re: question regarding datapools [message #98843 is a reply to message #98679] |
Thu, 17 May 2007 06:26 |
Originally posted by: Eitanush.gmail.com
If I break the test to smaller test cases as you suggested, I should
actually run this set of tests in a loop. How can I do that?
And a more general question, is there a good documentation for the TPTP,
and espacially AGR, apart from the AGR Introduction document?
FUDForum. Page generated in 0.03725 seconds
