VE I20050719: Unable to open a visual class [message #98480] |
Wed, 20 July 2005 01:48  |
I'm testing the VE I20050719 driver and I'm unable to open a visual class
created with the VE I20050715 diver and I can open it without problems
with VE 1.0.2.2 driver.
The error message says 'An internal error occurred during: "Setup Java
Visual Editor"'.
And the log file contains:
!ENTRY org.eclipse.core.runtime 4 2 2005-07-20 07:37:00.796
!MESSAGE An internal error occurred during: "Setup Java Visual Editor".
!STACK 0
java.lang.StackOverflowError
at
org.eclipse.jem.internal.instantiation.base.JavaObjectInstan ce.migrate(JavaObjectInstance.java:199)
at
org.eclipse.jem.internal.instantiation.base.JavaObjectInstan ce.eDynamicFeatureID(JavaObjectInstance.java:264)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicGet(Basi cEObjectImpl.java:493)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:488)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:483)
at
org.eclipse.jem.internal.instantiation.base.JavaObjectInstan ce.getAllocation(JavaObjectInstance.java:40)
at
org.eclipse.ve.internal.java.codegen.java.CodeGenExpFlattene r.visit(CodeGenExpFlattener.java:80)
at
org.eclipse.jem.internal.instantiation.impl.PTInstanceRefere nceImpl.accept0(PTInstanceReferenceImpl.java:161)
at
org.eclipse.jem.internal.instantiation.impl.PTExpressionImpl .accept(PTExpressionImpl.java:65)
at
org.eclipse.ve.internal.java.codegen.java.CodeGenExpFlattene r.visit(CodeGenExpFlattener.java:84)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: VE I20050719: Unable to open a visual class [message #98957 is a reply to message #98667] |
Thu, 21 July 2005 08:43   |
Gili Mendel wrote:
> Do you have something in the code that looks like this:
> String foo = "something" ;
> foo = foo.toLowerCase() // or something like this.
> We have just fixed a problem, where the creation of an allocation tree went
into an infinite loop (like the stack above),
> because something like foo that was created using foo itself.
Hi Gili,
I think the internal code have no relation with the VE. I have, for
example, a string process to duplicate apostrophes:
String ref = getEfReferencia().getStringValue();
ref = ref.replaceAll("'", "''");
into the search() method but this have no effects over GUI.
The field efReferencia is a subclass of an abstract subclass of a
JFormattedTextField. This works fine in other dialogs.
The source code of my dialog haves aprox. 1500 lines, so is difficult
to search and/or try all string opperations.
But the VE 1.0.2.2 driver works fine, so there is a problem with
VE 1.1 drivers.
If you need inspect the code, I can send it to you by mail or I can
grant read access to my Subversion server.
Thanks for your help,
Francesc
Re: VE I20050719: Unable to open a visual class [message #99044 is a reply to message #98957] |
Thu, 21 July 2005 11:20  |
We just changed recently to process just about everything, before we
ignored lines like
foo = foo.toLowerCase();
But now we process these too. But we didn't realize this recursive
problem so we didn't have tests for it.
This method you showed is exactly a recursive that we were talking
about. We are trying to catch these styles and for now ignore them.
Rich Kulp
Re: VE I20050719: Unable to open a visual class [message #609113 is a reply to message #98480] |
Wed, 20 July 2005 05:26  |
Hi Francesc,
> class created with the VE I20050715 diver and I can open it without
> problems with VE 1.0.2.2 driver.
> Visual Editor"'.
Not totally sure why the error occurs - Rich knows most about EMF and
might be able to help, but in the meantime can you use the pull down
menu option Project>Clean and see if that gets rid of the error ?
Joe Winchester
Re: VE I20050719: Unable to open a visual class [message #609117 is a reply to message #98538] |
Wed, 20 July 2005 06:35  |
Joe Winchester wrote:
> Hi Francesc,
>> Visual Editor"'.
> Best regards,
> Joe Winchester
Hi Joe,
Unfortunately, Clean don't solves the problem. May be Rich haves a good
idea...
Francesc Rosés
Re: VE I20050719: Unable to open a visual class [message #609122 is a reply to message #98593] |
Wed, 20 July 2005 09:31  |
We have just fixed a problem, where the creation of an allocation tree went into an infinite loop (like the stack above),
Re: VE I20050719: Unable to open a visual class [message #609157 is a reply to message #98667] |
Hi Gili,
VE 1.1 drivers.
Francesc
Re: VE I20050719: Unable to open a visual class [message #609168 is a reply to message #98957] |
ignored lines like
Rich Kulp
FUDForum. Page generated in 0.06471 seconds
