Re: localize dataset value [message #813942 is a reply to message #813219] |
Mon, 05 March 2012 21:43 |
You could always add a computed column to the dataset that has an
expression similar to:
reportContext.getMessage(row["YOURCOLUMNNAME"]);
As long as the value of YOURCOLUMNAME is in a resource file associated
with the report it should convert it for you.
Jason
On 3/4/2012 8:34 PM, Anthony Farrell wrote:
> I have a urgent question ,e.g.
> If the sudo SQL in the data set was something like (i.e. it generated
> derived data)
> select case (age > 55 then 'Old' else 'young') from person
> I would need to localise the values 'old ' and 'young', how would we do
> this ?
> I would like to use the same property files used to localize the report
> title, chart xaxis title ...etc
> Is it possible to some-how map the sql data values that comes back from
> a column in a SQL query to a property name in a localized text file ?
> Can I create a map or rule of some kind to "'old' maps to key
> "report.age.old=Old"
> Many thanks.
> Anthony.
Re: localize dataset value [message #813978 is a reply to message #813942] |
Mon, 05 March 2012 22:42 |
You can also use that same code in an oncreate of the data element like:
this.setDisplayValue(reportContext.getMessage(this.getValue());
Jason
> Jason
>> derived data)
>> this ?
>> Many thanks.
>> Anthony.
Re: localize dataset value [message #815482 is a reply to message #814747] |
Wed, 07 March 2012 18:16 |
That is correct.
Jason
On 3/6/2012 4:04 PM, Anthony Farrell wrote:
> Many thanks for your prompt reply, we will go with the computed column
> approach :
> reportContext.getMessage(row["CASESTATUS"]);
> All you need are property values for each CASESTATUS value,e.g. if there
> were only 2 case status then the property file would only need open=Open
> Status
> close=Close Status
> with a property localised to French containing:
> open=Open in french
> closed=close in french.
FUDForum. Page generated in 0.03384 seconds
