Home » Modeling » M2T (model-to-text transformation) » [Acceleo] How to generate a sequence (bag) of consecutive integers starting at 1(Need to determine if a bag of integers retrieved from modeling elements equals the series 1, 2, 3, ...)
[Acceleo] How to generate a sequence (bag) of consecutive integers starting at 1 [message #813218] |
Mon, 05 March 2012 01:34  |
Hello
I hope anyone can help me. I am assigning numbers as names of input pins in an action in an activity diagram. From this collection of input pins I am successfully computing a sequence (or bag) of integers (instances of Integer). What I need to determine now is whether such sequence (or bag) equals the sequence {1, 2, 3, 4, ... , n}.
My strategy is to generate the sequence {1, 2, 3, 4, ... , n} by using an expression like
Integer.allInstances()
->collect(i: Integer | i <= [an expression to compute the value of n])
->asBag()
and then compare this bag to the one I computed from the input pins.
My problem is that the expression that computes {1, 2, 3, 4, ... , n} illustrated above does not seem to work.
Any idea to generate the sequence of integers {1, 2, 3, 4, ... , n}? Any idea to determine if a sequence of integers equals the sequence {1, 2, 3, 4, ... , n} in a more elegant way?
Thank you very much.
UPDATE: I used select instead of collect in the expresion and it did not work either:
->select(i: Integer | i <= [an expresion to compute the value of n])
I get nothing when trying to generate text from the result of this expression
/T
/TB
[Updated on: Mon, 05 March 2012 03:18] Report message to a moderator
Re: [Acceleo] How to generate a sequence (bag) of consecutive integers starting at 1 [message #813390 is a reply to message #813218] |
Mon, 05 March 2012 07:47   |
Ed Willink Messages: 7051 Registered: July 2009 |
Try Sequence{1..n}.
Ed Willink
On 05/03/2012 01:34, Tomas Balderas wrote:
> Hello
> an expresion like
> ->collect(i: Integer | i <= [an expresion to compute the value of n])
> ->asBag()
> My problem is that the expresion that computes {1, 2, 3, 4, ... , n}
> /T
Current Time: Thu Mar 04 01:36:26 GMT 2021
Powered by FUDForum. Page generated in 0.02154 seconds
