Riena with OSGi-Bridge-Servlet? [message #8926] |
Mon, 25 August 2008 15:39 |
Originally posted by: ronde.hitdorf.com
Hi guys,
the last days I was playing around with riena and now I like to deploy a
small sample application into an existing application server (JBoss).
Should I use the OSGi-Bridgeservlet to expose the hessian service? Or is
there any other configuration file? Unfortunately I could not find any
information how to deploy.
Greets
Dominique
Re: Riena with OSGi-Bridge-Servlet? [message #8967 is a reply to message #8947] |
Wed, 27 August 2008 06:58 |
Hi Christian,
do you know what servlet dispatch the reqests for riena? If I understand
the documentation of the BridgeServlet right, I have to use the
extension point org.eclipse.equinox.http.registry.servlets
Dominique
Christian Campo schrieb:
> Hi Dominique,
> if you like to deploy it into a regular webcontainer, you need to deploy
> it using the BridgeServlet.
> christian
> Rondé, Dominique schrieb:
>> Hi guys,
>> a small sample application into an existing application server (JBoss).
>> is there any other configuration file? Unfortunately I could not find
>> any information how to deploy.
>> Greets
>> Dominique
Re: Riena with OSGi-Bridge-Servlet? [message #573824 is a reply to message #8947] |
Hi Christian,
Dominique
> Hi Dominique,
> christian
>> Hi guys,
>> Greets
>> Dominique
FUDForum. Page generated in 0.03891 seconds
