Home » Modeling » EMF » [CDO / Hibernate Store] "Cannot modify a frozen revision"(problem when using hibernate store and teneo.jpa .@id annotation)
[CDO / Hibernate Store] "Cannot modify a frozen revision" [message #811389] |
Fri, 02 March 2012 09:38 |
Hi forks,
after updating to CDO 4.0 we are facing the problem that we cannot insert things through HibernateStore. Every transaction that inserts a new / already existing object causes a IllegalStateException thrown in org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl.checkFrozen(int, Object).
Here is the annotation on the ID feature of our MM: @model id="true" annotation="teneo.jpa appinfo='@Id\r\n@GeneratedValue'".
When we remove this we are fine in using CDO and hibernateStore but unfortunately we are heavily using HQL with statements where we do want to find Objects by ID. For that reason we need to know the ID of the same. As Eike already mentioned this seams to be a problem with Hibernate Store and not CDO.
@Martin As I read in older posts from July or October you mentioned that this issue is fixed in 4.1? After we updated to an integration build we are facing the same problem. I'll give the latest weekly a try also but it would be really cool if you could give us a hint?
Thanks in advice,
Holger
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: [CDO / Hibernate Store] "Cannot modify a frozen revision" [message #813078 is a reply to message #811389] |
Sun, 04 March 2012 20:18 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Holger,
Just to let you know that I have seen your post but have not had time to check it out. Indeed the checkFrozen should not
occur, I remember I solved something there. I hope to come back to asap, give me a few days...
gr. Martin
On 03/02/2012 10:38 AM, Holger Schill wrote:
> Hi forks,
> org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl.checkFrozen(int, Object). Here is the annotation on the ID
> mentioned this seams to be a problem with Hibernate Store and not CDO. @Martin As I read in older posts from July or
> Thanks in advice,
> Holger
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO / Hibernate Store] "Cannot modify a frozen revision" [message #813968 is a reply to message #813078] |
Mon, 05 March 2012 22:23 |
Hi Holger,
I checked the source tree and the log, but I did something related to frozen about a year ago, but that seems different.
Can you post the stacktrace?
Can you try without the generatedvalue annotation but with the Id annotation?
gr. Martin
On 03/04/2012 09:18 PM, Martin Taal wrote:
> Hi Holger,
> gr. Martin
>> Hi forks,
>> Thanks in advice,
>> Holger
The Netherlands
Re: [CDO / Hibernate Store] "Cannot modify a frozen revision" [message #815179 is a reply to message #813968] |
Wed, 07 March 2012 10:21 |
Hi Martin,
here the complete stackstrace without removing @GeneratedValue with the latest weekly from CDO.
Hibernate: insert into [hilfeartengruppe] ([nr], [bezeichnung], [ablaufdatum], resource_id, container_id, version, commit_TimeStamp, dtype) values (?, ?, ?, ?, ?, ?, ?, 'HilfeartenGruppe')
2012-03-07 11:16:50.341 DEBUG [Thread-5 ] (IdentifierGeneratorHelper.java:87) - Natively generated identity: 1
2012-03-07 11:16:50.341 DEBUG [Thread-5 ] (AbstractBatcher.java:418) - about to close PreparedStatement (open PreparedStatements: 1, globally: 1)
!ENTRY org.eclipse.emf.cdo.server.hibernate 4 0 2012-03-07 11:16:50.341
!MESSAGE Cannot modify a frozen revision
!STACK 0
java.lang.IllegalStateException: Cannot modify a frozen revision
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl.checkFrozen(CDORevisionImpl.java:135)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl.setValue(CDORevisionImpl.java:89)
at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.setValue(BaseCDORevision.java:610)
at org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOPropertySetter.set(CDOPropertySetter.java:135)
at org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOIDPropertySetter.set(CDOIDPropertySetter.java:84)
at org.hibernate.tuple.entity.AbstractEntityTuplizer.setIdentifier(AbstractEntityTuplizer.java:267)
at org.hibernate.persister.entity.AbstractEntityPersister.setIdentifier(AbstractEntityPersister.java:3865)
at org.hibernate.action.EntityIdentityInsertAction.execute(EntityIdentityInsertAction.java:77)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:273)
at org.hibernate.event.def.AbstractSaveEventListener.performSaveOrReplicate(AbstractSaveEventListener.java:320)
at org.hibernate.event.def.AbstractSaveEventListener.performSave(AbstractSaveEventListener.java:203)
at org.hibernate.event.def.AbstractSaveEventListener.saveWithGeneratedId(AbstractSaveEventListener.java:129)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.saveWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener.java:210)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.entityIsTransient(DefaultSaveOrUpdateEventListener.java:195)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.performSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:117)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:93)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl.java:685)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java:677)
at org.hibernate.engine.CascadingAction$5.cascade(CascadingAction.java:252)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:392)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java:335)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:204)
at org.hibernate.engine.Cascade.cascadeCollectionElements(Cascade.java:425)
at org.hibernate.engine.Cascade.cascadeCollection(Cascade.java:362)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java:338)
at org.hibernate.engine.Cascade.cascade(Cascade.java:161)
at org.hibernate.event.def.AbstractSaveEventListener.cascadeAfterSave(AbstractSaveEventListener.java:475)
at org.hibernate.event.def.AbstractSaveEventListener.performSaveOrReplicate(AbstractSaveEventListener.java:353)
at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:684)
at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:487)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:43)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:262)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:96)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:84)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:326)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:63)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
[ERROR] Cannot modify a frozen revision
!ENTRY org.eclipse.emf.cdo.server 4 0 2012-03-07 11:16:50.358
!STACK 0
2012-03-07 11:16:50.358 DEBUG [Thread-5 ] (JDBCTransaction.java:182) - rollback
2012-03-07 11:16:50.358 DEBUG [Thread-5 ] (JDBCTransaction.java:193) - rolled back JDBC Connection
2012-03-07 11:16:50.358 DEBUG [Thread-5 ] (ConnectionManager.java:427) - aggressively releasing JDBC connection
2012-03-07 11:16:50.358 DEBUG [Thread-5 ] (ConnectionManager.java:464) - releasing JDBC connection [ (open PreparedStatements: 0, globally: 0) (open ResultSets: 0, globally: 0)]
Re: [CDO / Hibernate Store] "Cannot modify a frozen revision" [message #815385 is a reply to message #815179] |
Wed, 07 March 2012 15:39 |
Hi Holger,
Clear I can see what happens, can you enter a bugzilla for this (GeneratedValue does not work with CDO HibernateStore)?
gr. Martin
On 03/07/2012 11:21 AM, Holger Schill wrote:
> Hi Martin,
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: [CDO / Hibernate Store] "Cannot modify a frozen revision" [message #820096 is a reply to message #819947] |
Tue, 13 March 2012 18:15 |
Hi Holger,
I myself am moving away from these numeric generated id's to generated uuids. The uuids are supposed to be always unique
and can be generated on the client. So if I can give an advice I would go that way, use a string id efeature and
generate the id on the client when creating a new object.
gr, Martin
On 03/13/2012 03:31 PM, Holger Schill wrote:
> Hi Martin,
> is there a way to have an own implementation to calculate the IDs in the server component? Something like an
> implementation of org.hibernate.id.IdentifierGenerator?
> Holger
The Netherlands
Re: [CDO / Hibernate Store] "Cannot modify a frozen revision" [message #822310 is a reply to message #820096] |
Fri, 16 March 2012 13:04 |
Hi Martin,
I just tried out the company example from you and I am wondering that even there the org.eclipse.emf.cdo.examples.hibernate.client.CustomIDGeneratorTest is failing with Cannot modify a frozen revision. The IDGenerator is doeing his job and creates a UUID but than it leads to the same behaviour that we are facing in our case.
Generating the UUID with a custom IDGenerator is a really nice way to go but not usable as it seams.
Any conclusions?
Regars and thanks,
Holger
Re: [CDO / Hibernate Store] "Cannot modify a frozen revision&qu [message #823914 is a reply to message #822310] |
Sun, 18 March 2012 14:49 |
Hi Holger,
Okay, this test case is normally not run. I need to check with Eike on how to solve this.
One thing I tried is just have the @Id annotation and assign the id in the client. That worked fine for me. So you can
generate the id on the client using a uuid generator, for now.
gr. Martin
On 03/16/2012 02:04 PM, Holger Schill wrote:
> Hi Martin,
> Any conclusions?
> Regars and thanks,
> Holger
The Netherlands
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [CDO / Hibernate Store] "Cannot modify a frozen revision&qu [message #824193 is a reply to message #823914] |
Mon, 19 March 2012 11:21 |
Hi Holger,
I had a chat with Eike and the issue is a bit less trivial. Although we can prevent this exception from being thrown,
the id-feature value is not sent back to the client. To do that requires more work and a more fundamental change (to
allow the server to make changes to an object and sent the changes back to the client).
This requires more thought and design.
So for now I would follow this approach:
- annotate your id-efeature just with @Id
- on the client generate a unique UUID using a uuid generator and set that in the efeature
This should work fine afaics and the result would be the same (a unique id for each object).
Let me know if you have any questions/remarks.
gr. Martin
On 03/18/2012 03:49 PM, Martin Taal wrote:
> Hi Holger,
> gr. Martin
>> Hi Martin,
>> Any conclusions?
>> Regars and thanks,
>> Holger
The Netherlands
Re: [CDO / Hibernate Store] "Cannot modify a frozen revision&am [message #825009 is a reply to message #824959] |
Tue, 20 March 2012 10:48 |
Hi Holger,
Yes, that's also what Eike and I found it is not difficult to prevent the exception, but the id is not filled on the
client which seems strange. But the eventual solution will anyway consist of 2 parts: one to prevent the exception, and
two to send back the data to the client.
I will chat with Eike if the first thing can already be done now.
gr. Martin
On 03/20/2012 10:37 AM, Holger Schill wrote:
> Hi Martin,
> after debugging the frameworkcode looking for a usefull fix I have the same feeling. I tried it out some time ago and it
> worked fine with a IDGenerated at the clinet side. Unfortunately my customer does not want this. I will do my best to
> convince them. A UUID should be as unique as possible even on the client. :)
> Thanks for you help. Please let me know If I can help to fix this issue.
> By the way. I observed that when the exception is prevented everything is fine except the sent back to the client.
> Actually in CDO / HibernateStore 3.x this is the behavior. I think a first fix to prevent the exection is fine for most
> of the cases. I tried to hack this my setting the frozen attribute in the revision to false in the IDGenerator on the
> server. This solves my issue by is really ugly. :)
> Thanks for your time and support.
> Holger
The Netherlands
Current Time: Thu Apr 25 05:15:38 GMT 2024
Powered by FUDForum. Page generated in 0.03807 seconds
