Home » Archived » M2M (model-to-model transformation) » [QVTO] Black-box support
Re: [QVTO] Black-box support [message #97908 is a reply to message #97877] |
Tue, 20 January 2009 17:34 |
Radomil Dvorak Messages: 249 Registered: July 2009 |
Hi Hossam Karim,
As for 'org.eclipse.m2m.tests.qvt.oml.bbox.SimpleJavaLibrary', it's a
library which is a
part of QVTO unittests. It does not aim to be an example, but only a test
for one of
the deployment variants.
Looks like you have not installed 'Automated tests'.
It's unrelated to the 'Blackbox Library Example'.
The documentation of the blackbox extension point just mentions that as an
example of a simple library class. It does not refer to the same namespace,
so it's unrelated too. Sorry, if it sounds confusing.
Anyway, thanks for pointing out there!
I have to update the documentation and the example as well, as the provided
'org.eclipse.m2m.qvt.oml.examples.blackbox.UtilitiesLibrary' class
does not represent a real world example too much.
Rather a quick way how to start.
Except us ;), GMF uses it.
Feel free to ask questions in this newsgroup.
Perhaps, you could come up with your particular
usecase to solve, which might become a good example.
/Radek
On Tue, 20 Jan 2009 17:46:15 +0100, Hossam Karim <hossam.karim@gmail.com>
wrote:
> Hello everyone,
> I am not able to get the new annotation based black-box support to
> work. I had a look at the documentation, the example and the test cases
> but they seem inconsistent. The test case is referencing a library that
> I can't find: library
> Would someone who got this feature to work provide some guide please?
> Hossam Karim
Re: [QVTO] Black-box support [message #97922 is a reply to message #97908] |
Wed, 21 January 2009 07:00 |
Hossam Karim Messages: 26 Registered: July 2009 |
--------------050309030607090502040705
Thanks Radek for the answer.
Here is what I am trying to do:
I need to map the UML primitive types to Ecore primitive types before
starting the actual model instances mapping.
Currently this is what I have done to get it to work:
- Created a class in the top UML input model package as follows:
class PrimitiveTypes {
integer : UML::Integer;
string : UML::String;
boolean : UML::Boolean;
unlimitedNatural: UML::UnlimitedNatural;
- BTW, I couldn't create such class dynamically using QVTO syntax, I
couldn't manage to declare the attributes as primitive types.
- Using the attached use case, I was able to make the early binding,
then remove the 'PrimitiveTypes' class
This is basically a work around, I believe there is a better way to do
it. What I have in mind is to use the black-box support to load the
UMLPrimitiveTypes model library and do the early mapping through Java
calls without the 'PrimitiveTypes' class hack.
I failed to get the Java black-box unit support to work. Here is my
scenario:
- Created a Plug-in with the attached plugin.xml
- Added a dependency in my transformation project on the created plug-in
- Tried to import the library as:
import org.thinkmeta.qvt.uml.ThinkMetaLibrary;
, but it is not resolved.
I appreciate if you can point out the problem with my approach, or
suggest a better one.
Hossam Karim
Radek Dvorak wrote:
> Hi Hossam Karim,
> library which is a
> test for one of
> Regards,
> /Radek
> <hossam.karim@gmail.com> wrote:
>> Hello everyone,
>> cases but they seem inconsistent. The test case is referencing a
>> library that I can't find: library
>> Thanks,
>> Hossam Karim
name="usecase.qvto"
Content-Disposition: inline;
filename="usecase.qvto"
aW1wb3J0IGVtZi50b29sczsgCgoKbW9kZWx0eXBlIFVNTCB1c2VzICdodHRw Oi8vd3d3LmVj
bGlwc2Uub3JnL3VtbDIvMy4wLjAvVU1MJzsKbW9kZWx0eXBlIEVjb3JlIHVz ZXMgJ2h0dHA6
Ly93d3cuZWNsaXBzZS5vcmcvZW1mLzIwMDIvRWNvcmUnOwoJCgp0cmFuc2Zv cm1hdGlvbiB1
bWwyZWNvcmUoaW4gdW1sOlVNTCwgb3V0IGVjb3JlOkVjb3JlKTsKCmhlbHBl ciBlRGF0YVR5
cGVJbnN0YW5jZShuYW1lIDogU3RyaW5nKSA6IEVjb3JlOjpFRGF0YVR5cGUg ewogIHJldHVy
biBnZXREYXRhVHlwZUluc3RhbmNlKCdodHRwOi8vd3d3LmVjbGlwc2Uub3Jn L2VtZi8yMDAy
L0Vjb3JlJywgbmFtZSk7CQp9CgpoZWxwZXIgZUludCgpIDogRWNvcmU6OkVE YXRhVHlwZSB7
CglyZXR1cm4gZURhdGFUeXBlSW5zdGFuY2UoJ0VJbnQnKTsKfQoKaGVscGVy IGVCb29sZWFu
KCkgOiBFY29yZTo6RURhdGFUeXBlIHsKCXJldHVybiBlRGF0YVR5cGVJbnN0 YW5jZSgnRUJv
b2xlYW4nKTsKfQoKaGVscGVyIGVTdHJpbmcoKSA6IEVjb3JlOjpFRGF0YVR5 cGUgewoJcmV0
dXJuIGVEYXRhVHlwZUluc3RhbmNlKCdFU3RyaW5nJyk7Cn0KCmhlbHBlciBV TUw6OlByaW1p
dGl2ZVR5cGU6OmVEYXRhVHlwZSgpIDogRWNvcmU6OkVEYXRhVHlwZSB7Cgly ZXR1cm4gc3dp
dGNoIHsKICAJCWNhc2UgKHNlbGYubmFtZSA9ICdJbnRlZ2VyJykgZUludCgp OwogIAkJY2Fz
ZSAoc2VsZi5uYW1lID0gJ0Jvb2xlYW4nKSBlQm9vbGVhbigpOwogIAkJY2Fz ZSAoc2VsZi5u
YW1lID0gJ1N0cmluZycpIGVTdHJpbmcoKTsKICAJCWNhc2UgKHNlbGYubmFt ZSA9ICdVbmxp
bWl0ZWROYXR1cmFsJykgZUludCgpOwogIAkJZWxzZSBudWxsOwogIAl9Cn0K Cm1hcHBpbmcg
VU1MOjpQcmltaXRpdmVUeXBlOjpzcGVjaWFsUHJpbWl0aXZlVHlwZTJFRGF0 YVR5cGUoKSA6
IEVjb3JlOjpFRGF0YVR5cGUgewoJaW5pdCB7CgkgIHJlc3VsdCA6PSBzZWxm LmVEYXRhVHlw
ZSgpOwoJfQp9CgpoZWxwZXIgcGVyZm9ybVByaW1pdGl2ZVR5cGVNYXBwaW5n KCkgOiBVTUw6
OkNsYXNzIHsKCQogICAgdmFyIHByaW1pdGl2ZVR5cGVzQ2xhc3MgOiBVTUw6 OkNsYXNzIDo9
IAoJICB1bWwub2JqZWN0c09mVHlwZShVTUw6OkNsYXNzKVtuYW1lID0gJ1By aW1pdGl2ZVR5
cGVzJ10tPmFzU2VxdWVuY2UoKS0+Zmlyc3QoKTsKCSAgCgl2YXIgdW1sSW50 ZWdlciA6IFVN
TDo6UHJpbWl0aXZlVHlwZSA6PQoJICBwcmltaXRpdmVUeXBlc0NsYXNzLmF0 dHJpYnV0ZVtu
YW1lID0gJ2ludGVnZXInXS50eXBlLm9jbEFzVHlwZShVTUw6OlByaW1pdGl2 ZVR5cGUpLT5h
c1NlcXVlbmNlKCktPmZpcnN0KCk7CQoJdmFyIGVjb3JlSW50ZWdlciA6IEVj b3JlOjpFRGF0
YVR5cGUgOj0gdW1sSW50ZWdlci5tYXAgc3BlY2lhbFByaW1pdGl2ZVR5cGUy RURhdGFUeXBl
KCk7CQoJCgl2YXIgdW1sU3RyaW5nIDogVU1MOjpQcmltaXRpdmVUeXBlIDo9 CgkgIHByaW1p
dGl2ZVR5cGVzQ2xhc3MuYXR0cmlidXRlW25hbWUgPSAnc3RyaW5nJ10udHlw ZS5vY2xBc1R5
cGUoVU1MOjpQcmltaXRpdmVUeXBlKS0+YXNTZXF1ZW5jZSgpLT5maXJzdCgp OwkKCXZhciBl
Y29yZVN0cmluZyA6IEVjb3JlOjpFRGF0YVR5cGUgOj0gdW1sU3RyaW5nLm1h cCBzcGVjaWFs
UHJpbWl0aXZlVHlwZTJFRGF0YVR5cGUoKTsKCQoJdmFyIHVtbEJvb2xlYW4g OiBVTUw6OlBy
aW1pdGl2ZVR5cGUgOj0KCSAgcHJpbWl0aXZlVHlwZXNDbGFzcy5hdHRyaWJ1 dGVbbmFtZSA9
ICdib29sZWFuJ10udHlwZS5vY2xBc1R5cGUoVU1MOjpQcmltaXRpdmVUeXBl KS0+YXNTZXF1
ZW5jZSgpLT5maXJzdCgpOwkKCXZhciBlY29yZUJvb2xlYW4gOiBFY29yZTo6 RURhdGFUeXBl
IDo9IHVtbEJvb2xlYW4ubWFwIHNwZWNpYWxQcmltaXRpdmVUeXBlMkVEYXRh VHlwZSgpOwoJ
Cgl2YXIgdW1sVW5saW1pdGVkTmF0dXJhbCA6IFVNTDo6UHJpbWl0aXZlVHlw ZSA6PQoJICBw
cmltaXRpdmVUeXBlc0NsYXNzLmF0dHJpYnV0ZVtuYW1lID0gJ3VubGltaXRl ZE5hdHVyYWwn
XS50eXBlLm9jbEFzVHlwZShVTUw6OlByaW1pdGl2ZVR5cGUpLT5hc1NlcXVl bmNlKCktPmZp
cnN0KCk7CQoJdmFyIGVjb3JlVW5saW1pdGVkTmF0dXJhbCA6IEVjb3JlOjpF RGF0YVR5cGUg
Oj0gdW1sVW5saW1pdGVkTmF0dXJhbC5tYXAgc3BlY2lhbFByaW1pdGl2ZVR5 cGUyRURhdGFU
eXBlKCk7CgkKCXJldHVybiBwcmltaXRpdmVUeXBlc0NsYXNzOwkKfQoKCm1h aW4oKSB7Cgl1
bWwucmVtb3ZlRWxlbWVudChwZXJmb3JtUHJpbWl0aXZlVHlwZU1hcHBpbmco KSk7CgktLXVt
bC5vYmplY3RzKClbVU1MOjpQYWNrYWdlXS0+bWFwIHBhY2thZ2UyRVBhY2th Z2UoKTsKfQo=
Content-Type: text/xml;
name="plugin.xml"
filename="plugin.xml"
<?eclipse version="3.2"?>
<plugin>
<extension
point="org.eclipse.m2m.qvt.oml.javaBlackboxUnits">
<unit
name="ThinkMetaLibrary"
namespace="org.thinkmeta.qvt.uml">
<library
class="org.thinkmeta.qvt.uml.ThinkMetaLibrary"
name="ThinkMetaLibrary">
<metamodel
nsURI="http://www.eclipse.org/uml2/3.0.0/UML">
</metamodel>
</library>
</unit>
</extension>
</plugin>
--------------050309030607090502040705--
Re: [QVTO] Black-box support [message #98015 is a reply to message #97922] |
Wed, 21 January 2009 13:12 |
See inlined responses bellow.
So far, we have only implemented intermediate classes and properties.
A regular EMF based metamodel can be defined outside QVTo, so we focus
on other features first.
You can take a look at my response to "[QVTO] Early mapping of metamodel
elements".
It shows how to get access to the EcorePackage instance programmatically
in QVTo.
The crucial part is actually getting access to the EcorePackage instance
as an ECORE model
in QVTo, in which you can look for the predefined types.
The access you could get also via a blackbox library and do the
actual mapping in QVT source code, if a more flexible decision making is
needed there.
> scenario:
Check please the compilation error message on the import.
It might also be:
"Failed to load black-box library
'org.thinkmeta.qvt.uml.ThinkMetaLibrary'. See error log for details"
which means it has been resolved but some operations may have failed to
load.
It depends on how you define your library java class.
I have just tried that and all works fine.
plugin.xml:
<plugin>
<extension point="org.eclipse.m2m.qvt.oml.javaBlackboxUnits">
<unit name="ThinkMetaLibrary" namespace="org.thinkmeta.qvt.uml">
<library name="ThinkMetaLibrary"
class="org.thinkmeta.qvt.uml.ThinkMetaLibrary">
<metamodel nsURI="http://www.eclipse.org/emf/2002/Ecore"/>
<metamodel nsURI="http://www.eclipse.org/uml2/3.0.0/UML"/>
</library>
</unit>
</extension>
</plugin>
ThinkMetaLibrary.java:
package org.thinkmeta.qvt.uml;
import org.eclipse.emf.ecore.EClassifier;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.m2m.qvt.oml.blackbox.java.Operation;
import org.eclipse.uml2.uml.PrimitiveType;
public class ThinkMetaLibrary {
public ThinkMetaLibrary() {
super();
* non-contextual operation variant
public EClassifier getEPrimitiveType(PrimitiveType umlType) {
if("String".equals(umlType.getName())) {
return EcorePackage.eINSTANCE.getEString();
// other cases
return null;
* contextual operation variant
@Operation(contextual=true)
public EClassifier getEPrimitiveType2(PrimitiveType self) {
return getEPrimitiveType2(self);
In QVT importing compilation unit you can refer to it as the following:
main() {
var umlType : UML::PrimitiveType;
getEPrimitiveType(umlType);
umlType.getEPrimitiveType2();
/Radek
Re: [QVTO] Black-box support [message #689293 is a reply to message #98015] |
Mon, 27 June 2011 11:13 |
Tom2000 Messages: 6 Registered: May 2011 |
Hi at all,
(Step 1)
i tried to implement these example but i get the following error (Log):
- Failed to load java black-box unit 'org.thinkmeta.qvt.uml.ThinkMetaLibrary'
-- Loading Java module diagnostics 'ThinkMetaLibrary, javaClass: org.thinkmeta.qvt.uml.ThinkMetaLibrary, bundle:
--- Can't resolve 'interface org.eclipse.uml2.uml.PrimitiveType' as OCL type in java method 'public
-- Can't resolve metamodel nsURI='...www.eclipse.org/uml2/3.0.0/UML"'
so i checked my MetamodelExplorer and the plugin.xml, discovered some typing error and corrected it.
(Step 2)
But after plugin exportation, copying it into Eclipse/plugin folder (replacing the plugin from step 1) and restart the IDE, suprisingly i got the same Error Message with a current Date. I repeat this Process again and again but the Error occurs , as recently as i shut down my pc and restartet the whole System it works (with out changing the Code in Step 2). In an other project i got the same message Can't resolve metamodel nsURI='someMetamodel' before and after deleting it in plugin.xml.
Could anybody tell me how to avoid it, is there an internal memory in QVTO or something?
Thanks a lot Tom
(Eclipse Helios Version: 3.6.2,
Operational QVT 3.0.1)
Current Time: Thu Apr 18 15:19:23 GMT 2024
Powered by FUDForum. Page generated in 0.02168 seconds
