Home » Archived » BIRT » Setting data using JavaScript on BIRT DE
Re: Setting data using JavaScript on BIRT DE [message #810927 is a reply to message #810867] |
Thu, 01 March 2012 17:38 |
You should be able to do this by adding the script expression in the
QueryImpl
QueryImpl.create( "row[\"PRODUCTCODE\"] + \"my product\"" )
Jason
On 3/1/2012 11:21 AM, Claude B wrote:
> I've created a report which generates a chart using BIRT Designer 3.7.1 and now I want to create the same report with the design engine
> My chart contains 3 Bar series each one uses its JavaScript code (see the attached picture for more details)
> My question is how can I include a JavaScript code into my Design Engine???
> this is a part of my code which creates the chart:
> ChartWithAxes cwaLine = ChartWithAxesImpl.create();
> cwaLine.setType( "Line Chart" ); //$NON-NLS-1$
> cwaLine.setSubType( "Overlay" ); //$NON-NLS-1$
> cwaLine.getBlock().getBounds().setWidth(600);
> cwaLine.getBlock().getBounds().setHeight(400);
> // Plot
> cwaLine.getBlock().setBackground( ColorDefinitionImpl.WHITE() );
> Plot p = cwaLine.getPlot();
> p.getClientArea().setBackground( ColorDefinitionImpl.create( 255, 255,
> 225 ) );
> // Title
> cwaLine.getTitle().getLabel().getCaption().setValue("Overlay test Line Chart" );
> cwaLine.getTitle().setVisible(true);
> // Legend
> cwaLine.getLegend().setVisible( true );
> // X-Axis
> Axis xAxisPrimary = cwaLine.getPrimaryBaseAxes()[0];
> xAxisPrimary.setType( AxisType.TEXT_LITERAL );
> //xAxisPrimary.getMajorGrid().setTickStyle( TickStyle.BELOW_LITERAL );
> //xAxisPrimary.getOrigin().setType( IntersectionType.MIN_LITERAL );
> // Y-Axis
> Axis yAxisPrimary = cwaLine.getPrimaryOrthogonalAxis( xAxisPrimary );
> yAxisPrimary.setType(AxisType.LINEAR_LITERAL);
> //yAxisPrimary.getMajorGrid().setTickStyle( TickStyle.RIGHT_LITERAL );
> //yAxisPrimary.getLabel().getCaption().setValue("TEST");
> yAxisPrimary.getLabel().setVisible(true);
> // X-Series
> Series seCategory = SeriesImpl.create( );
> // seCategory.setDataSet( categoryValues );
> // Set category expression.
> seCategory.getDataDefinition( )
> .add( QueryImpl.create( "row[\"submit_date\"]" ) );
> SeriesDefinition sdX = SeriesDefinitionImpl.create( );
> sdX.getSeriesPalette( ).shift( 0 );
> sdX.setSorting(SortOption.ASCENDING_LITERAL);
> // Set default grouping.
> SeriesGrouping grouping = sdX.getGrouping( );
> grouping.getAggregateExpression();
> grouping.setEnabled( true );
> grouping.setGroupType( DataType.DATE_TIME_LITERAL );
> grouping.setGroupingUnit( GroupingUnitType.MONTHS_LITERAL );
> grouping.setGroupingInterval( 1 );
> grouping.setAggregateExpression( "Count" ); // Set Count aggregation. //$NON-NLS-1$
> xAxisPrimary.getSeriesDefinitions( ).add( sdX );
> sdX.getSeries( ).add( seCategory );
> // Y-Series
> //LineSeries bs1 = (LineSeries) LineSeriesImpl.create( );
> BarSeries bs1 = (BarSeries) BarSeriesImpl.create( );
> //AreaSeries bs1 = (AreaSeries) AreaSeriesImpl.create( );
> bs1.getDataDefinition( ).add( QueryImpl.create( "row[\"dbid\"]" ) );
> bs1.getLabel( ).setVisible( true );
> BarSeries bs2 = (BarSeries) BarSeriesImpl.create( );
> bs2.getDataDefinition( ).add( QueryImpl.create( "row[\"dbid\"]" ) );
> bs2.getLabel( ).setVisible( true );
> BarSeries bs3 = (BarSeries) BarSeriesImpl.create( );
> bs3.getDataDefinition( ).add( QueryImpl.create( "row[\"dbid\"]" ) );
> bs3.getLabel( ).setVisible( true );
> SeriesDefinition sdY = SeriesDefinitionImpl.create( );
> sdY.getGrouping().setEnabled(false);
> yAxisPrimary.getSeriesDefinitions( ).add( sdY );
> SeriesDefinition sdY2 = SeriesDefinitionImpl.create( );
> sdY2.getGrouping().setEnabled(false);
> yAxisPrimary.getSeriesDefinitions( ).add( sdY2 );
> SeriesDefinition sdY3 = SeriesDefinitionImpl.create( );
> sdY3.getGrouping().setEnabled(false);
> yAxisPrimary.getSeriesDefinitions( ).add( sdY3 );
> sdY.getSeries( ).add( bs1 );
> sdY2.getSeries( ).add( bs2 );
> sdY3.getSeries( ).add( bs3 );
> return cwaLine;
Re: Setting data using JavaScript on BIRT DE [message #811879 is a reply to message #811401] |
Fri, 02 March 2012 23:31 |
\"my product\" was just a string I added using the QueryImpl. You
should be able to put your expression in as a string. What error are yo
getting when you do this? BTW if you are only interested in row["dbid"]
when the stat value is one of those three values, why not just put a
filter on the chart for those three values?
Jason
On 3/2/2012 4:54 AM, Claude B wrote:
> Sorry about the pictures' order: the file "BirtDE2": chart after adding
> scripts
> the file "BirtDE1": chart before adding scripts
> I want to add that I tried
> QueryImpl.create("if(row[\"state\"]==16778022) {row[\"dbid\"]}");
> but I got a bad result (the same as BirtDE1.JPG)
> I tried other ones like QueryImpl.create("row[\"dbid\"] +
> if(row[\"state\"]==16778022) {row[\"dbid\"]}"); but I've got syntax
> errors in the viewer
Re: Setting data using JavaScript on BIRT DE [message #813975 is a reply to message #813422] |
Mon, 05 March 2012 22:37 |
Filters where for the chart datset, so that will not help in this case.
Look at the attached example. I use an expression on in the query. I
also add a filter to the chart extended item handle(although you
probably will not use this approach). Bear in mind that all series have
to have the same number of data points. So if you are filtering in an
expression there still has to be the same number of data points. The
example was done in 2.6.1, remove the setting of birt home if you are
using 3.7 or greater:
Jason
package DEAPI;
import java.io.IOException;
import java.io.InputStream;
import java.net.URLEncoder;
import org.eclipse.birt.chart.integrate.SimpleActionHandle;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.ActionType;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LegendItemType;
import org.eclipse.birt.chart.model.attribute.MultiURLValues;
import org.eclipse.birt.chart.model.attribute.Palette;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.TriggerCondition;
import org.eclipse.birt.chart.model.attribute.URLValue;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionImpl;
import org.eclipse.birt.chart.model.attribute.impl.MultiURLValuesImpl;
import org.eclipse.birt.chart.model.attribute.impl.PaletteImpl;
import org.eclipse.birt.chart.model.attribute.impl.TextImpl;
import org.eclipse.birt.chart.model.attribute.impl.TooltipValueImpl;
import org.eclipse.birt.chart.model.attribute.impl.URLValueImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Label;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.LabelImpl;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.BaseSampleData;
import org.eclipse.birt.chart.model.data.DataFactory;
import org.eclipse.birt.chart.model.data.OrthogonalSampleData;
import org.eclipse.birt.chart.model.data.SampleData;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.Trigger;
import org.eclipse.birt.chart.model.data.impl.ActionImpl;
import org.eclipse.birt.chart.model.data.impl.QueryImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.data.impl.TriggerImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.ActionHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.DesignFileException;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.Expression;
import org.eclipse.birt.report.model.api.ExpressionType;
import org.eclipse.birt.report.model.api.ExtendedItemHandle;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.ModuleUtil;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.SimpleMasterPageHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException;
import org.eclipse.birt.report.model.api.command.ContentException;
import org.eclipse.birt.report.model.api.command.NameException;
import org.eclipse.birt.report.model.api.elements.DesignChoiceConstants;
import org.eclipse.birt.report.model.api.elements.structures.Action;
import
org.eclipse.birt.report.model.api.elements.structures.FilterCondition;
import
org.eclipse.birt.report.model.api.elements.structures.PropertyBinding;
import org.eclipse.birt.report.model.parser.DesignSchemaConstants;
import com.ibm.icu.util.ULocale;
public class SimpleChart
private ReportDesignHandle reportDesignHandle = null;
private ElementFactory elementFactory = null;
private OdaDataSourceHandle odaDataSourceHandle = null;
private String dataSourceName = "datasource";
private String dataSetName = "maindataset";
private SessionHandle sessionHandle =null;
org.eclipse.birt.report.model.api.elements.structures.ComputedColumn
cs1, cs2, cs3 = null;
public static void main(String args[])
try {
new SimpleChart().createReport();
} catch (Exception e) {
e.printStackTrace();
public void createReport() throws SemanticException, IOException
System.out.println("Start");
init();
createMasterPages();
buildDataSource();
buildDataSet();
createBody();
// reportDesignHandle.set
reportDesignHandle.saveAs("output/desample/simplechart.rptdesign");
reportDesignHandle.close( );
Platform.shutdown();
System.out.println("Finished");
private void init(){
DesignConfig config = new DesignConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_6_1/birt-runtime-2_6_1/ReportEngine");
IDesignEngine engine = null;
try {
Platform.startup(config);
IDesignEngineFactory factory = (IDesignEngineFactory)
Platform.createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY);
engine = factory.createDesignEngine(config);
} catch (Exception ex) {
ex.printStackTrace();
// we need a handle of session of design engine
sessionHandle = engine.newSessionHandle(ULocale.ENGLISH);
reportDesignHandle = sessionHandle.createDesign();
reportDesignHandle.setCreatedBy( "created by Birt 2.6.1" );
reportDesignHandle.getModule().getVersionManager( ).setVersion(
DesignSchemaConstants.REPORT_VERSION );
elementFactory = reportDesignHandle.getElementFactory();
private void createMasterPages() throws ContentException, NameException
SimpleMasterPageHandle simpleMasterPage =
elementFactory.newSimpleMasterPage("Master Page");
reportDesignHandle.getMasterPages().add(simpleMasterPage);
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = elementFactory.newOdaDataSource(
"Data Source", "org.eclipse.birt.report.data.oda.jdbc" );
dsHandle.setProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver" );
dsHandle.setProperty( "odaURL", "jdbc:classicmodels:sampledb" );
dsHandle.setProperty( "odaUser", "ClassicModels" );
dsHandle.setProperty( "odaPassword", "" );
PropertyBinding pb = new PropertyBinding();
reportDesignHandle.getDataSources( ).add( dsHandle );
void buildDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle = elementFactory.newOdaDataSet(
dataSetName,
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select PRODUCTCODE, QUANTITYORDERED from
orderdetails where ordernumber = 10104";
dsHandle.setQueryText( qry );
reportDesignHandle.getDataSets( ).add( dsHandle );
private void createBody() throws SemanticException
ExtendedItemHandle extendedItemHandle =
elementFactory.newExtendedItem("Simple Chart", "Chart");
extendedItemHandle.setWidth("700px");
extendedItemHandle.setHeight("500px");
extendedItemHandle.setProperty(ExtendedItemHandle.DATA_SET_PROP,
dataSetName);
extendedItemHandle.setProperty("outputFormat","PNG");
Chart c = createChart();
extendedItemHandle.getReportItem().setProperty(
"chart.instance", c );
reportDesignHandle.getBody().add(extendedItemHandle);
//PropertyHandle computedSet =
extendedItemHandle.getColumnBindings( );
//computedSet.clearValue();
cs1 = StructureFactory.createComputedColumn( );
cs1.setName( "PRODUCTCODE" );
cs1.setExpression( "dataSetRow[\"PRODUCTCODE\"]");
cs1.setDataType( "string" );
cs1.setAggregateOn(null);
cs2 = StructureFactory.createComputedColumn( );
cs2.setName( "QUANTITYORDERED" );
cs2.setExpression( "dataSetRow[\"QUANTITYORDERED\"]");
cs2.setDataType( "integer" );
extendedItemHandle.addColumnBinding(cs1, true);
extendedItemHandle.addColumnBinding(cs2, true);
addFilterCondition(extendedItemHandle);
private Chart createChart() {
// Plot
255, 255,
225 ) );
// Title
test Line Chart" );
// Legend
Legend lg = cwaLine.getLegend();
lg.setItemType(LegendItemType.CATEGORIES_LITERAL);
// X-Axis
// Y-Axis
xAxisPrimary );
SampleData sd = DataFactory.eINSTANCE.createSampleData( );
BaseSampleData sdBase =
DataFactory.eINSTANCE.createBaseSampleData( );
sdBase.setDataSetRepresentation( "Category-A, Category-B"
);//$NON-NLS-1$
sd.getBaseSampleData( ).add( sdBase );
OrthogonalSampleData sdOrthogonal =
DataFactory.eINSTANCE.createOrthogonalSampleData( );
sdOrthogonal.setDataSetRepresentation( "4,12" );//$NON-NLS-1$
sdOrthogonal.setSeriesDefinitionIndex( 0 );
sd.getOrthogonalSampleData( ).add( sdOrthogonal );
cwaLine.setSampleData( sd );
// X-Series
.add( QueryImpl.create( "row[\"PRODUCTCODE\"]" ) );
Palette palx = PaletteImpl.create(10, false);
//sdY.getSeriesPalette( ).shift(1);
sdX.setSeriesPalette(palx);
//sdX.getSeriesPalette( ).shift( 1 );
//sdX.setSorting(SortOption.ASCENDING_LITERAL);
//SeriesGrouping grouping = sdX.getGrouping( );
//grouping.getAggregateExpression();
//grouping.setEnabled( false );
//grouping.setGroupType( DataType.TEXT_LITERAL );
//grouping.setGroupingUnit(
GroupingUnitType.STRING_PREFIX_LITERAL );
//grouping.setGroupingInterval( 1 );
//grouping.setAggregateExpression( "Sum" ); // Set Count
// Y-Series
bs1.getDataDefinition( ).add( QueryImpl.create( "if(
row[\"QUANTITYORDERED\"] > 30 ){row[\"QUANTITYORDERED\"]}" ) );
try {
Action tst = StructureFactory.createAction( );
MultiURLValues muv = MultiURLValuesImpl.create( );
ActionHandle actionHandle =
ModuleUtil.deserializeAction((InputStream)null);
actionHandle.setLinkType(DesignChoiceConstants.ACTION_LINK_TYPE_HYPERLINK);
//String lnk = "row[\"hyper\"]";
String lnk =
"\"http://www.google.com/#q=\"+row[\"QUANTITYORDERED\"]";
Expression myexpression = new Expression( lnk,
ExpressionType.JAVASCRIPT );
actionHandle.setExpressionProperty("uri", myexpression);
String sBaseUrl = ModuleUtil.serializeAction(actionHandle);
URLValue uv =
URLValueImpl.create(sBaseUrl,null,null,null,null);
Label l = LabelImpl.create( );
l.setCaption( TextImpl.create( "www.google.com" )
);//$NON-NLS-1$
uv.setLabel( l );
muv.getURLValues( ).add( uv );
Trigger triger = TriggerImpl.create(
TriggerCondition.ONCLICK_LITERAL,
ActionImpl.create( ActionType.URL_REDIRECT_LITERAL,
muv ));
bs1.getTriggers( ).add( triger );
} catch (SemanticException e) {
} catch (DesignFileException e) {
} catch (IOException e) {
//Palette pal = PaletteImpl.create(10, false);
//sdY.setSeriesPalette(pal);
return cwaLine;
void addFilterCondition(ExtendedItemHandle eh){
try{
FilterCondition fc = StructureFactory.createFilterCond();
fc.setExpr("row[\"QUANTITYORDERED\"]");
fc.setOperator(DesignChoiceConstants.MAP_OPERATOR_GT);
fc.setValue1("25");
PropertyHandle ph = eh.getPropertyHandle(ExtendedItemHandle.FILTER_PROP);
ph.addItem(fc);
}catch (Exception e){
On 3/5/2012 3:43 AM, Claude B wrote:
> Hi Jason,
> I tried to put a filter at first but the problem is that I had many
> series, each one had its own condition and actually I don't now how to
> do that so I tried to but the condition as a JavaScript code for each
> series and that worked using the designer so I'm asking how to do it
> using code in the Design Engine.
> Can you tell me how to put a filter for each series in a chart???
Re: Setting data using JavaScript on BIRT DE [message #817024 is a reply to message #813975] |
Fri, 09 March 2012 14:44 |
Claude B Messages: 32 Registered: February 2012 |
Member |
Hi Jason,
Thanks for your answer, I brought some modifications to my old code to solve the problem and to satisfy new needs.
In fact what I want to do now is:
- create a simple report using BIRT DE (with connection to an SQL server database) and extract data into a JAVA structure (a vector)
- Make some modifications to data in the JAVA structure
- create a new report using data in the JAVA structure as a data set
I've done the first step successfully and now I've my data saved into a vector which contains Java objects having 3 columns:
Column Count =3
Column Name =submit_date
Column Type =DateTime
Column Name =dbid
Column Type =Integer
Column Name =state
01-04-2011 13:21:39 , 33557279 , 16778024
01-05-2011 12:44:35 , 33557282 , 16778024
01-05-2011 15:58:05 , 33557287 , 16778024
01-06-2011 07:13:21 , 33557289 , 16778024
01-07-2011 13:01:21 , 33557301 , 16778024
01-17-2011 12:39:26 , 33557326 , 16778024
01-19-2011 16:00:44 , 33557335 , 16778024
01-11-2011 09:20:30 , 33557308 , 16778024
I'll ignore the second step for the moment
Now I've problems with the third step: creating chart from JAVA objects datasets
Here is my code:
//config.setBIRTHome("C:/K/ReportEngine");
try {
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
ExtendedItemHandle extendedItemHandle = elementFactory.newExtendedItem("Simple Chart", "Chart");
extendedItemHandle.setProperty(ExtendedItemHandle.DATA_SET_PROP, dataSetName);
bindChart((ChartWithAxes) c);
extendedItemHandle.getReportItem().setProperty( "chart.instance", c );
reportDesignHandle.saveAs("rapports/rapport3.rptdesign");
System.out.println("End");
I didn't changed the createChart() method
and here is the bindChart() method
public static void bindChart(ChartWithAxes cmb){
Vector V = new Vector();
try {
V = DataExtract.executeReport();
} catch (EngineException e) {
System.out.println(V);
CDateTime[] col1Value = new CDateTime[V.size()];
double[] col2Value = new double[V.size()];
for(int j=0;j<V.size();j++)
col1Value[j] = ((SupportRequest)V.elementAt(j)).getSubmit_date();
System.out.println("-------" + col1Value[j]);
col2Value[j] = ((SupportRequest)V.elementAt(j)).getDbid();
System.out.println("-------" + col2Value[j]);
System.out.println("-------" + col1Value);
System.out.println("-------" + col2Value);
DateTimeDataSet categoryValues = DateTimeDataSetImpl.create(col1Value);
NumberDataSet orthoValuesDataSet1 = NumberDataSetImpl.create(col2Value);
Axis xaxis = cmb.getPrimaryBaseAxes()[0];
Axis yaxis = cmb.getPrimaryOrthogonalAxis(xaxis);
SeriesDefinition sdx = (SeriesDefinition)xaxis.getSeriesDefinitions().get(0);
SeriesDefinition sdy = (SeriesDefinition)yaxis.getSeriesDefinitions().get(0);
((Series)sdx.getSeries().get(0)).setDataSet(categoryValues);
((Series)sdy.getSeries().get(0)).setDataSet(orthoValuesDataSet1);
//((Series)sdy.getSeries().get(1)).setDataSet(orthoValues2);
When I execute my program I get a NullPointerException in this line:
here is the Stack Trace:
01-09-java.lang.NullPointerException
at org.eclipse.birt.chart.factory.Generator.getRowExpressions(Generator.java:1659)
at org.eclipse.birt.chart.factory.Generator.getRowExpressions(Generator.java:520)
at org.eclipse.birt.chart.reportitem.ChartReportItemImpl.getRowExpressions(ChartReportItemImpl.java:963)
at org.eclipse.birt.report.model.util.BoundColumnsMgr.dealExtendedItem(BoundColumnsMgr.java:219)
at org.eclipse.birt.report.model.writer.BoundColumnsWriterMgr.dealExtendedItem(BoundColumnsWriterMgr.java:426)
at org.eclipse.birt.report.model.writer.ModuleWriterImpl.visitExtendedItem(ModuleWriterImpl.java:1869)
at org.eclipse.birt.report.model.elements.ExtendedItem.apply(ExtendedItem.java:136)
at org.eclipse.birt.report.model.writer.ModuleWriterImpl.writeChildren(ModuleWriterImpl.java:2917)
at org.eclipse.birt.report.model.writer.ModuleWriterImpl.writeContents(ModuleWriterImpl.java:2902)
at org.eclipse.birt.report.model.writer.ModuleWriterImpl.writeContents(ModuleWriterImpl.java:2936)
at org.eclipse.birt.report.model.writer.DesignWriterImpl.writeSlot(DesignWriterImpl.java:172)
at org.eclipse.birt.report.model.writer.DesignWriterImpl.visitReportDesign(DesignWriterImpl.java:77)
at org.eclipse.birt.report.model.elements.ReportDesign.apply(ReportDesign.java:65)
at org.eclipse.birt.report.model.writer.ModuleWriterImpl.writeFile(ModuleWriterImpl.java:326)
at org.eclipse.birt.report.model.writer.ModuleWriterImpl.write(ModuleWriterImpl.java:294)
at org.eclipse.birt.report.model.api.ModuleHandleImpl.save(ModuleHandleImpl.java:1451)
at org.eclipse.birt.report.model.api.ModuleHandleImpl.saveAs(ModuleHandleImpl.java:1471)
at calcul.FinalCreateChart.createReport(FinalCreateChart.java:225)
at calcul.FinalCreateChart.main(FinalCreateChart.java:128)
2012 15:09:02
Please help me to fix this error or if you have an other idea about how to generate a report from data in local classes using BIRT Design Engine 3.7.1
Re: Setting data using JavaScript on BIRT DE [message #817248 is a reply to message #817024] |
Fri, 09 March 2012 21:01 |
Are the java objects available at the time the report runs? BTW why not
just create a scripted data set and use the chart normal binding. See
the attached file.
Jason
On 3/9/2012 9:44 AM, Claude B wrote:
> Hi Jason,
> Column Count =3
> Column Name =dbid
> Column Name =state
> datasets
> Here is my code:
> try {
> dataSetName);
> try {
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 2012 15:09:02
> 3.7.1
Re: Setting data using JavaScript on BIRT DE [message #832899 is a reply to message #832482] |
Fri, 30 March 2012 18:31 |
Look at this sample.
Jason
On 3/30/2012 3:48 AM, Ritu Goel wrote:
> Hi Jason,
> I had created a sample_chart.rptdesign file and had put a bar chart in that without creating Data Sources and Data Sets.
> Now with API/ java coding, I am opening this design file and creating data sources and data sets there. Both data sources and data sets are creating successfully but the problem is I am not able to bind columns with X and Y series.
> Its showing error :
> Errors in Report
> Line 78: A data definition entry for X Series is undefined.
> Line 78: A data definition entry for Y Series is undefined.
> Please find attachment for java class file.
> Please help me in this regard.
> Thanks in advance
Re: Setting data using JavaScript on BIRT DE [message #841334 is a reply to message #817024] |
Wed, 11 April 2012 07:04 |
SMHJamali Missing name Messages: 3 Registered: April 2012 |
I'm using birt-runtime-2_6_2.
I want to build rptdesign file from code by using design engine API. I don't use eclipse designer.
When control of application reach to this line
design.saveAs("path/sample.rptdesign")
my application throw an unknown exception with no stacktrace and current executing method return; so that rest of method isn't executed.
i had same situation with method
odaDS.setStringProperty("odaPassword", getText("db-password"));
on another pc. I changed my pc and run the code again. now when I call saveAs method of design Engin, execution of current method breaks and an exception throws with no stack trace.
Any help appreciated
S.M.H.Jamali
[Updated on: Wed, 11 April 2012 07:05] Report message to a moderator
Re: Setting data using JavaScript on BIRT DE [message #841671 is a reply to message #832899] |
Wed, 11 April 2012 16:04 |
It is not a lot different to modify a chart in the report. For example
in the following snippet I change the grouping on an existing chart:
SessionHandle sessionHandle = engine.newSessionHandle( (ULocale) null );
try
designHandle = sessionHandle.openDesign(
"report/NonGroupOnXSeries.rptdesign" );//$NON-NLS-1$
catch ( DesignFileException e )
e.printStackTrace( );
ExtendedItemHandle eih = (ExtendedItemHandle) designHandle.getBody( )
.getContents( ).get( 0 );
Chart cm = null;
try
cm = (Chart) eih.getReportItem( ).getProperty( "chart.instance" );
//$NON-NLS-1$
catch ( ExtendedElementException e )
cm.getTitle( ).getLabel( ).getCaption( ).setValue( "Group On X Series"
);//$NON-NLS-1$
cm.getTitle( ).getLabel( ).getCaption( ).getFont().setSize(12);
cm.getTitle( ).getLabel( ).getCaption( ).getFont().setRotation(45);
SeriesDefinition sdX = (SeriesDefinition) ( (Axis) ( (ChartWithAxes) cm )
.getAxes( ).get( 0 ) ).getSeriesDefinitions( ).get( 0 );
sdX.setSorting( SortOption.ASCENDING_LITERAL );
sdX.getGrouping( ).setEnabled( true );
sdX.getGrouping( ).setAggregateExpression( "Sum" );//$NON-NLS-1$
sdX.getGrouping( ).setGroupType( DataType.NUMERIC_LITERAL );
sdX.getGrouping( ).setGroupingInterval( 1 );
try
designHandle.saveAs( "report/GroupOnXSeries.rptdesign" );//$NON-NLS-1$
catch ( IOException e )
You can see I get the chart model from chart.instance. In your case you
should use my previous example to create your data source and use this
example to get the extended item handle and add your bindings to it
first, then use chart.inistance to get the chart model. Then use the
previous example to see how to set the query for the category and bar
series values.
Jason
> Jason
>> Hi Jason,
>> Its showing error :
>> Errors in Report
>> Thanks in advance
Re: Setting data using JavaScript on BIRT DE [message #841678 is a reply to message #841334] |
Wed, 11 April 2012 16:06 |
Can you post your code?
Jason
On 4/11/2012 3:04 AM, SMHJamali Mising name wrote:
> Hi I'm using birt-runtime-2_6_2.
> S.M.H.Jamali
Re: Setting data using JavaScript on BIRT DE [message #841795 is a reply to message #841701] |
Wed, 11 April 2012 18:34 |
It does not look like you set up the bindings on the table. Take a look
at this example:
package DEAPI;
//Java Libraries
import java.io.BufferedInputStream;
import java.util.ArrayList;
import java.util.List;
import java.util.Iterator;
//BIRT Libraries
import org.eclipse.birt.report.model.api.CellHandle;
import org.eclipse.birt.report.model.api.ColumnHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DesignElementHandle;
import org.eclipse.birt.report.model.api.DesignEngine;
import org.eclipse.birt.report.model.api.GridHandle;
import org.eclipse.birt.report.model.api.ImageHandle;
import org.eclipse.birt.report.model.api.JoinConditionHandle;
import org.eclipse.birt.report.model.api.JointDataSetHandle;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.ReportElementHandle;
import org.eclipse.birt.report.model.api.RowHandle;
import org.eclipse.birt.report.model.api.ScalarParameterHandle;
import org.eclipse.birt.report.model.api.SortKeyHandle;
import org.eclipse.birt.report.model.api.StyleHandle;
import
org.eclipse.birt.report.model.api.elements.structures.AggregationArgument;
import org.eclipse.birt.report.model.api.elements.structures.ComputedColumn;
import org.eclipse.birt.report.model.api.elements.structures.EmbeddedImage;
import
import org.eclipse.birt.report.model.api.elements.structures.HideRule;
import org.eclipse.birt.report.model.api.elements.structures.HighlightRule;
import org.eclipse.birt.report.model.api.elements.structures.IncludeScript;
import org.eclipse.birt.report.model.api.elements.structures.JoinCondition;
import org.eclipse.birt.report.model.api.elements.structures.MapRule;
import org.eclipse.birt.report.model.api.elements.structures.ParamBinding;
import
import org.eclipse.birt.report.model.api.elements.structures.SortKey;
import org.eclipse.birt.report.model.api.elements.structures.TOC;
import org.eclipse.birt.report.model.elements.interfaces.IJointDataSetModel;
import org.eclipse.birt.report.model.elements.JointDataSet;
import org.eclipse.birt.report.model.elements.ReportDesign;
import org.eclipse.birt.report.model.elements.ReportItem;
import org.eclipse.birt.report.model.elements.Style;
import org.apache.commons.codec.binary.Base64;
public class SimpleTable
ReportDesignHandle designHandle = null;
ElementFactory designFactory = null;
StructureFactory structFactory = null;
public static void main( String[] args )
try
SimpleTable de = new SimpleTable();
de.buildReport();
catch ( SemanticException e )
public void setup()
// Setup code here
public void processAll()
// Running code here
try
buildReport( );
private void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = designFactory.newOdaDataSource("Data
designHandle.getDataSources( ).add( dsHandle );
long currid = dsHandle.getID();
//pb.setName("odaUser");
//pb.setID(currid);
//pb.setValue("params[\"NewParameter\"].value");
//PropertyHandle ph = designHandle.getPropertyHandle("propertyBindings");
//ph.addItem(pb);
private void buildDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle = designFactory.newOdaDataSet(
"ds","org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
String qry = "Select * from customers";
designHandle.getDataSets( ).add( dsHandle );
private void buildReport( ) throws IOException, SemanticException
// Create a session handle. This is used to manage all open designs.
// Your app need create the session only once.
//Set the Platform Context in Design Config
IDesignEngine designEngine = null;
// Startup the Platform and use factory object to create the Design Engine
try
Platform.startup( config );
IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
designEngine = factory.createDesignEngine( config );
catch( Exception ex)
// Create session handle to open, create, modify report designs
SessionHandle session = designEngine.newSessionHandle( ULocale.ENGLISH );
// Build Report Design
try
// Create a new report design handle.
designHandle = session.createDesign( );
// The element factory creates instances of the various BIRT elements.
designFactory = designHandle.getElementFactory( );
// Create a simple master page that describes how the report will
// appear when printed.
// Note: The report will fail to load in the BIRT designer
// unless you create a master page.
SimpleMasterPageHandle element = designFactory.newSimpleMasterPage(
"Page Master" ); //$NON-NLS-1$
designHandle.getMasterPages( ).add( element );
// Build DataSource
try
buildDataSource();
buildDataSet();
catch (Exception e)
TableHandle table = designFactory.newTableItem( "table", 3 );
table.setWidth( "100%" );
table.setDataSet( designHandle.findDataSet( "ds" ) );
PropertyHandle computedSet = table.getColumnBindings( );
ComputedColumn cs1, cs2, cs3, cs4, cs5;
// Colum 1 : CustomerName
cs1 = StructureFactory.createComputedColumn();
cs1.setName("CustomerName");
cs1.setExpression("dataSetRow[\"CUSTOMERNAME\"]");
computedSet.addItem(cs1);
// Colum 2 : CustomerCity
cs2 = StructureFactory.createComputedColumn();
cs2.setName("CustomerCity");
cs2.setExpression("dataSetRow[\"CITY\"]");
//cs2.setDataType(dataType)
computedSet.addItem(cs2);
// Colum 3 : CustomerCountry
cs3 = StructureFactory.createComputedColumn();
cs3.setName("CustomerCountry");
cs3.setExpression("dataSetRow[\"COUNTRY\"]");
computedSet.addItem(cs3);
// Colum 4 : CustomerCreditLimit
cs4 = StructureFactory.createComputedColumn();
cs4.setName("CustomerCreditLimit");
cs4.setExpression("dataSetRow[\"CREDITLIMIT\"]");
computedSet.addItem(cs4);
// Colum 5 : CustomerCreditLimitSum
cs5 = StructureFactory.createComputedColumn();
cs5.setName("CustomerCreditLimitSum");
cs5.setExpression("dataSetRow[\"CREDITLIMIT\"]");
cs5.setAggregateFunction("sum");
computedSet.addItem(cs5);
// table header
RowHandle tableheader = (RowHandle) table.getHeader( ).get( 0 );
ColumnHandle ch = (ColumnHandle)table.getColumns().get(0);
ch.setProperty("width", "50%");
LabelHandle label1 = designFactory.newLabel("Label1" );
label1.setText("Customer");
CellHandle cell = (CellHandle) tableheader.getCells( ).get( 0 );
cell.getContent( ).add( label1 );
LabelHandle label2 = designFactory.newLabel("Label2" );
label2.setText("City");
cell = (CellHandle) tableheader.getCells( ).get( 1 );
cell.getContent( ).add( label2 );
LabelHandle label3 = designFactory.newLabel("Label3" );
label3.setText("Credit Limit");
cell = (CellHandle) tableheader.getCells( ).get( 2 );
cell.getContent( ).add( label3 );
// table detail (Detail Row)
RowHandle tabledetail = (RowHandle) table.getDetail( ).get( 0 );
cell = (CellHandle) tabledetail.getCells( ).get( 0 );
DataItemHandle data = designFactory.newDataItem( "data1" );
//designFactory.newTextItem(name)
data.setResultSetColumn("CustomerName");
cell.getContent( ).add( data );
cell = (CellHandle) tabledetail.getCells( ).get( 1 );
data = designFactory.newDataItem( "data2" );
data.setResultSetColumn("CustomerCity");
cell = (CellHandle) tabledetail.getCells( ).get( 2 );
data = designFactory.newDataItem( "data3" );
data.setResultSetColumn("CustomerCreditLimit");
designHandle.getBody().add(table);
// Save the design and close it.
designHandle.saveAs( "output/desample/simpletable.rptdesign" );
//$NON-NLS-1$
designHandle.close( );
public void cleanup()
public String propertyBase() {
return "ls.brain.node";
Jason
On 4/11/2012 12:36 PM, SMHJamali Mising name wrote:
> I attach my code. can you please review it. I think this code is like yours but saveAs method that is wrote at the end of method doesn't work.
> Thanks
Re: Setting data using JavaScript on BIRT DE [message #847268 is a reply to message #841671] |
Tue, 17 April 2012 06:38 |
Ritu Goel Messages: 6 Registered: March 2012 |
Hi Jason
I am attaching code, please take a look at that. In this code, I am opening design file and creating data sources ans data sets. Then I am binding data of resultset wit X and Y series of Bar chart created during design time. But Its still showing error that:
Data definition for X and Y series is undefined.
Please let me know what steps I am missing here.
public class RenderChart {
static IDesignEngine dEngine = null;
EngineConfig conf = null;
ReportEngine eng = null;
conf = new EngineConfig();
//Create new Report engine based off of the configuration
eng = new ReportEngine( conf );
// Create a design engine configuration object.
DesignConfig dConfig = new DesignConfig( );
SessionHandle session = null;
String name = "C:/Users/456144/Desktop/BIRT Program/BIRT Report/src/chart_report.rptdesign";
try {
Platform.startup(dConfig);
dEngine = factory.createDesignEngine(dConfig);
session = dEngine.newSessionHandle(null);
reportDesignHandle = session.openDesign(name);
System.out.println("File is opened");
try
String qry = "SELECT CLASSICMODELS.HOST1.OS_TYPE, COUNT(CLASSICMODELS.HOST1.OS_TYPE) AS NOS FROM HOST1 GROUP BY CLASSICMODELS.HOST1.OS_TYPE";
String dataSourceName = "Sample Derby";
String dataSetName ="OS Utilization";
//Adding Data Source method
addDataSource(reportDesignHandle,dataSourceName,"org.apache.derby.jdbc.EmbeddedDriver","jdbc:derby:C:/Users/456144/Desktop/BIRT Program/BirtSample","ClassicModels","");
System.out.println("Datasource is set"+dataSourceName);
//Building and binding dataset
buildDataSet(reportDesignHandle,dataSetName,dataSourceName,qry);
System.out.println("Dataset is set"+dataSetName);
ExtendedItemHandle eih = (ExtendedItemHandle) reportDesignHandle.getBody().getContents().get(0);
//opening bar chart and binding data sets
editingChart(reportDesignHandle,eih );
System.out.println("Called MutiYserieschart");
catch(Exception e)
public static void addDataSource(ReportDesignHandle hdl,String dsName,String driver,String url,String user, String pwd)
OdaDataSourceHandle dataSetHandle = OdaDataSourceHandle)hdl.findDataSource(dsName);
if (dataSetHandle == null )
dataSetHandle = hdl.getElementFactory().newOdaDataSource(
dsName, "org.eclipse.birt.report.data.oda.jdbc" );
dataSetHandle.setProperty( "odaDriverClass",driver);
dataSetHandle.setProperty( "odaURL", url);
dataSetHandle.setProperty( "odaUser", user);
dataSetHandle.setProperty( "odaPassword", pwd );
hdl.getDataSources().add(dataSetHandle);
void print(String msg)
System.out.println(msg);
* Build the query ( data set to use in the report).
static void buildDataSet(ReportDesignHandle reportDesignHandle,String dataSetName,String dataSourceName,String qry)
OdaDataSetHandle dataSetHandle = reportDesignHandle.getElementFactory().newOdaDataSet(
dataSetName,"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dataSetHandle.setDataSource( dataSourceName );
dataSetHandle.setQueryText( qry );
PropertyHandle computedSet = dataSetHandle.getPropertyHandle( OdaDataSetHandle.COMPUTED_COLUMNS_PROP );
reportDesignHandle.getDataSets( ).add( dataSetHandle );
//Editing Chart method
static void editingChart(ReportDesignHandle reportDesignHandle ,ExtendedItemHandle eih)
Chart cwaBar=null;
try
eih.setDataSet(reportDesignHandle.findDataSet("OS Utilization"));
System.out.println("This is the Multiyaxis chart");
cwaBar = (Chart) eih.getReportItem().getProperty("chart.instance");
// X-Axis
Axis xAxisPrimary = ((ChartWithAxes) cwaBar).getPrimaryBaseAxes()[0];
//Y axis
Axis yAxisPrimary = ((ChartWithAxes) cwaBar).getPrimaryOrthogonalAxis(xAxisPrimary);
yAxisPrimary.getLabel().getCaption().setValue("Osvalue");
// Create sample data.
SampleData sdt = DataFactory.eINSTANCE.createSampleData();
BaseSampleData sdBase = DataFactory.eINSTANCE.createBaseSampleData();
sdBase.setDataSetRepresentation("Category-A, Category-B" );
sdt.getBaseSampleData().add( sdBase );
OrthogonalSampleData sdOrthogonal = DataFactory.eINSTANCE.createOrthogonalSampleData();
sdOrthogonal.setDataSetRepresentation("4,12");
sdOrthogonal.setSeriesDefinitionIndex(0);
sdt.getOrthogonalSampleData().add( sdOrthogonal );
cwaBar.setSampleData(sdt);
// X-Series
seCategory.setSeriesIdentifier("Type");
Query query = QueryImpl.create( "row[\"OS_TYPE\"]" );//$NON-NLS-1$
seCategory.getDataDefinition( ).add( query );
System.out.println(seCategory.getDataDefinition().get(0));
SeriesDefinition sdX = SeriesDefinitionImpl.create();
//Grouping
grouping.setGroupingUnit( GroupingUnitType.STRING_PREFIX_LITERAL );
grouping.setAggregateExpression( "Sum" ); // Set Count aggregation.
//$NON-NLS-1$
sdX.getQuery().setDefinition(seCategory.getSeriesIdentifier().toString());
xAxisPrimary.getSeriesDefinitions( ).add(sdX);
// Y-Series (1)
BarSeries bs = (BarSeries) BarSeriesImpl.create( );
//$NON-NLS-1$
Query query1 = QueryImpl.create( "row[\"NOS\"]" );//$NON-NLS-1$
bs.getDataDefinition( ).add( query1 );
Boolean test1 = bs.getDataDefinition( ).add( query1 );
System.out.println( bs.getDataDefinition( ).get(0));
System.out.println("value is:"+test1);
System.out.println(bs.getDataSet());
SeriesDefinition sdY1 = SeriesDefinitionImpl.create();
sdY1 = yAxisPrimary.getSeriesDefinitions().get(0);
sdY1.getGrouping().setEnabled(true);
sdY1.getQuery().setDefinition( bs.getSeriesIdentifier().toString());
yAxisPrimary.getSeriesDefinitions( ).add( sdY1 );
sdY1.getSeries( ).add( bs );
System.out.println("Everything is added");
try
reportDesignHandle.saveAs( "C:/Users/456144/Desktop/BIRT Program/BIRT Report/chart_report3.rptdesign" );
System.out.println("File is saved");
catch(Exception e)
Please help in this regard.
Ritu
Re: Setting data using JavaScript on BIRT DE [message #847725 is a reply to message #847268] |
Tue, 17 April 2012 15:38 |
What error are you getting? I noticed in your code you are not adding
column bindings to your chart extended report item like:
dataSetName);
Jason
On 4/17/2012 2:38 AM, Ritu Goel wrote:
> Hi Jason
> Data definition for X and Y series is undefined. Please let me know what
> try {
> try
> catch(Exception e)
> dsName,String driver,String url,String user, String pwd) throws
> SemanticException
> dataSetName,String dataSourceName,String qry) throws SemanticException
> Chart cwaBar=null;
> try
> // X-Axis
> //Y axis
> // X-Series
> //Grouping
> //$NON-NLS-1$
> // Y-Series (1)
> //$NON-NLS-1$
> try
> catch(Exception e)
> Thanks
> Ritu
Re: Setting data using JavaScript on BIRT DE [message #849102 is a reply to message #848281] |
Wed, 18 April 2012 22:13 |
That is most likely because you did not set the bindings on the chart.
If you open the birt designer and build a report that contains a chart
you will see in addition to your columns on the data set that the chart
will have a set of bindings in the properties view for columns that are
available to the chart. Run your code and post the rptdesign.
Jason
On 4/18/2012 12:43 AM, Ritu Goel wrote:
> Hi Jason,
> Regarding column bindings, I am getting these column bindings in my
> result.rpt design file but error coming is :
> Errors in Report
> Line 66: A data definition entry for X Series is undefined.
> Line 66: A data definition entry for Y Series is undefined.
> I am not able to bind data with series value
> Help me in this regard
> Thanks Ritu
Re: Setting data using JavaScript on BIRT DE [message #850418 is a reply to message #849374] |
Fri, 20 April 2012 02:54 |
Ritu,
If you are opening an existing chart you will have to clear at least the
category seriesdefintion as a chart can only have one. I took your code
changed the data set a bit so I could run it and cleared the
definitions. See below.
package DEAPI;
import org.eclipse.birt.chart.model.attribute.DataType;
import org.eclipse.birt.chart.model.attribute.GroupingUnitType;
import org.eclipse.birt.chart.model.data.Query;
import org.eclipse.birt.chart.model.data.SeriesGrouping;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.ReportEngine;
import
static
org.eclipse.birt.report.model.api.elements.structures.ComputedColumn cs1;
static
org.eclipse.birt.report.model.api.elements.structures.ComputedColumn cs2
= null;
String name = "output/desample/chart_report.rptdesign";
try {
..createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY);
try
qry = "Select * from orderdetails where ordernumber = 10101";
catch(Exception e)
SemanticException
//OdaDataSourceHandle dataSetHandle =
(OdaDataSourceHandle)hdl.findDataSource(dsName);
//if (dataSetHandle == null )
//dataSetHandle = hdl.getElementFactory().newOdaDataSource(
// dsName, "org.eclipse.birt.report.data.oda.jdbc" );
//dataSetHandle.setProperty( "odaDriverClass",driver);
//dataSetHandle.setProperty( "odaURL", url);
//dataSetHandle.setProperty( "odaUser", user);
//dataSetHandle.setProperty( "odaPassword", pwd );
//PropertyBinding pb = new PropertyBinding();
//hdl.getDataSources().add(dataSetHandle);
OdaDataSourceHandle dsHandle = hdl.getElementFactory().newOdaDataSource(
hdl.getDataSources().add(dsHandle);
Chart cwaBar=null;
try
eih.setProperty(ExtendedItemHandle.DATA_SET_PROP, "OS
Utilization");//reportDesignHandle.findDataSet("OS Utilization"));
cs1.setName( "NOS" );
cs1.setExpression( "dataSetRow[\"QUANTITYORDERED\"]");
cs1.setDataType( "integer" );
cs2.setName( "OS_TYPE" );
cs2.setExpression( "dataSetRow[\"PRODUCTCODE\"]");
cs2.setDataType( "string" );
eih.addColumnBinding(cs1, true);
eih.addColumnBinding(cs2, true);
// X-Axis
//Y axis
//Clear existing definitions
xAxisPrimary.getSeriesDefinitions( ).clear();
yAxisPrimary.getSeriesDefinitions( ).clear();
// X-Series
//Grouping
//$NON-NLS-1$
// Y-Series (1)
//$NON-NLS-1$
//bs.getDataDefinition( ).add( query1 );
sdY1.getSeriesPalette( ).shift(1);
try
reportDesignHandle.saveAs( "output/desample/chart_report3.rptdesign" );
catch(Exception e)
Jason
n 4/19/2012 1:02 AM, Ritu Goel wrote:
> Hi Jason
> I am attaching output .rpt design file after running code. Please check this and let me know what I am missing in code.
> Thanks in advance.
> Ritu
Current Time: Thu Apr 25 19:29:25 GMT 2024
Powered by FUDForum. Page generated in 0.05608 seconds
