Birt fails on report with strings [message #810795] |
Thu, 01 March 2012 15:12 |
Ludwig Moser Messages: 476 Registered: July 2009 |
i noticed the following.
i have POJO's mapped to birt.
when i go to preview everything is fine and dispayed correct.
when i run the report i sometimes get errors about "cannot map blabla to integer" when i check the xml it says the field is mapped as String (correct)
in the error message i noticed that the text reported as blabla always is in middle
my string might be:
Quote:somewhere /over the rainbow
so the reported error is "cannot map 'over the rainbow' to integer"
i am reporting as html in eclipse plugin (browser)
any ideas?
EDIT: i tried (just to test) to urlencode all my strings... still happens, although no slash is there...
so now i do not know what causes this strange behaviour
EDIT: i just noticed that PREVIEW in designer does work, but when i finally generate the report in viewer it fails...???
FULL ERROR example:
The following items have errors:
Data (id = 35):
+ Can not convert the value of Kals+am+Gro%C3%9Fglockner to Integer type. (Element ID:35)
CONVERT_FAILS ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Can not convert the value of Kals+am+Gro%C3%9Fglockner to Integer type. (Element ID:35)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1214)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1193)
at org.eclipse.birt.report.engine.internal.document.v4.DataItemExecutor.doExecute(DataItemExecutor.java:97)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.execute(ReportItemExecutor.java:294)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.prepareChildExecutor(ContainerExecutor.java:226)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.hasNextChild(ContainerExecutor.java:110)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.hasNextChild(WrappedReportItemExecutor.java:86)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:62)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.layoutChildren(HTMLTableBandLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:681)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:294)
at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1547)
at org.eclipse.birt.report.service.BirtViewerReportService.getPage(BirtViewerReportService.java:204)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.doExecution(AbstractGetPageActionHandler.java:238)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:105)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:322)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.core.exception.CoreException: Can not convert the value of Kals+am+Gro%C3%9Fglockner to Integer type.
at org.eclipse.birt.core.data.DataTypeUtil.toInteger(DataTypeUtil.java:276)
at org.eclipse.birt.core.data.DataTypeUtil.convert(DataTypeUtil.java:104)
at org.eclipse.birt.data.engine.impl.document.util.ExprDataReader1.getValueMap(ExprDataReader1.java:324)
at org.eclipse.birt.data.engine.impl.document.util.ExprDataReader1.getRowValue(ExprDataReader1.java:226)
at org.eclipse.birt.data.engine.impl.document.util.ExprResultSet.getValue(ExprResultSet.java:187)
at org.eclipse.birt.data.engine.impl.document.ResultIterator.getValue(ResultIterator.java:167)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.getValue(QueryResultSet.java:403)
at org.eclipse.birt.report.engine.internal.document.v4.DataItemExecutor.doExecute(DataItemExecutor.java:86)
... 76 more
+ Can not convert the value of Tue Oct 30 16:16:39 CET 2007 to Integer type. (Element ID:35)
detail : org.eclipse.birt.report.engine.api.EngineException: Can not convert the value of Tue Oct 30 16:16:39 CET 2007 to Integer type. (Element ID:35)
Caused by: org.eclipse.birt.core.exception.CoreException: Can not convert the value of Tue Oct 30 16:16:39 CET 2007 to Integer type.
at org.eclipse.birt.core.data.DataTypeUtil.toInteger(DataTypeUtil.java:239)
... 76 more
+ Retrieving binding data error. (Element ID:35)
Error.BindDataRetrivingError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Retrieving binding data error. (Element ID:35)
at org.eclipse.birt.report.engine.internal.document.v4.DataItemExecutor.doExecute(DataItemExecutor.java:102)
Caused by: java.lang.NumberFormatException
at java.math.BigDecimal.<init>(Unknown Source)
at org.eclipse.birt.core.data.DataTypeUtil.toBigDecimal(DataTypeUtil.java:357)
at org.eclipse.birt.core.data.DataTypeUtil.convert(DataTypeUtil.java:106)
... 76 more
Data (id = 33):
+ Retrieving binding data error. (Element ID:33)
detail : org.eclipse.birt.report.engine.api.EngineException: Retrieving binding data error. (Element ID:33)
... 76 more
Data (id = 37):
+ Retrieving binding data error. (Element ID:37)
probably i should also note that although i have plenty of properties on my object
i only report THREE but on the report it tries to put ALL of em!!!
[Updated on: Thu, 01 March 2012 15:50] Report message to a moderator
Re: Birt fails on report with strings [message #810866 is a reply to message #810795] |
Thu, 01 March 2012 16:18 |
Can you look at the binding tab of the table where you use the string.
Does the binding column show it as a string or an integer?
Jason
> (correct)
> is behind a slash
> so my string might be:
> Quote:
> any ideas?
Re: Birt fails on report with strings [message #811309 is a reply to message #811300] |
Fri, 02 March 2012 07:13 |
i am looking through the xml now.
i look at the current errors i get.
reports error on all id's i placed in my report.
28 = ID (Integer) <- this one is the big stacktrace
26 = Catalog (String)
30 = Name (String)
so what birt tries is to put different fields in (first error comes from Coordinates Origin second from an Date field...
what i absolutely do not understand is - its working in PREVIEW!!!
[Updated on: Fri, 02 March 2012 07:13] Report message to a moderator
Re: Birt fails on report with strings [message #811400 is a reply to message #811309] |
Fri, 02 March 2012 09:52 |
jason, the last sample i mailed to you.
i updated the code and had a look if i can reproduce the problem.
the problem also shows up in my updated example.
if you want i can mail it to you so you can have a look on whats going on (to proof that its working in designer preview and not working in viewer)
log says:
VIEWER:
11:47:48.412 [26256809@qtp-29360182-3 - /viewer/run?__report=D%3A%5CJAVA%5Cruntime-Example.product%5CReports%5CnewReport.rpttemplate&__format=html&__svg=false&__locale=de_DE&__timezone=Europe%2FBerlin&__masterpage=true&__rtl=false&__maxrows=500&__maxrowlevels=50&__maxcolumnlevels=50&__cubememsize=10&__resourceFolder=D%3A%5CJAVA%5Cruntime-Example.product%5CReports&__dpi=96&1413761156&__sessionId=20120302_114742_980] DEBUG org.mortbay.log - RESPONSE /viewer/run 200
DESIGNER
11:51:18.631 [11064890@qtp-30338559-1 - /viewer/frameset?__report=D%3A%2FJAVA%2Fruntime-Example.product%2FReports%2FnewReport.rpttemplate&__format=html&__svg=false&__locale=de_DE&__timezone=Europe%2FBerlin&__masterpage=true&__rtl=false&__cubememsize=10&__resourceFolder=&__dpi=96&__parameterpage=false&Top%20Percentage=15&Top%20Count=6&-1142991550&__sessionId=20120302_115113_497] DEBUG org.mortbay.log - RESPONSE /viewer/frameset 200
[Updated on: Fri, 02 March 2012 10:53] Report message to a moderator
Re: Birt fails on report with strings [message #811755 is a reply to message #811471] |
Fri, 02 March 2012 19:34 |
Ludwig,
It would be good if you can send me a report that I can run and shows
the issue. BTW take a look at this post:
http://birtworld.blogspot.com/2010/07/whats-difference-between.html
Jason
On 3/2/2012 6:37 AM, Ludwig Moser wrote:
> i still try to find out what is happening.
> so i investigated into table binding.
> when i add a table automatically all fields defined in my data set get
> bound.
> when i then try to create the report in viewer i receive the errors.
> when i remove all unneeded bindings the report gets valid.
> so i tried to find out why it fucks up at a given binding.
> i created another report without table and outputting each and every
> defined entry on the binding.
> and it DID NOT FUCK UP.
> so the issue seems only to be alive when i use a table with binding.
> does the table receive data different?
> whats the difference between row["name"] in the FETCH function and
> rowDataSet["name"] in the table?
Re: Birt fails on report with strings [message #814199 is a reply to message #813965] |
Tue, 06 March 2012 06:40 |
how do i set log details?
i start the viewer like this:
public void loadReport(String reportName) {
System.out.println("loading report '"+reportName+"'");
HashMap<String, Object> myparms = new HashMap<String, Object>();
HashMap<String, String> emitmap = new HashMap<String, String>();
myparms.put("SERVLET_NAME_KEY", "frameset");
myparms.put("FORMAT_KEY", "html");
//myparms.put("RESOURCE_FOLDER_KEY", "c:/myresources");
myparms.put("ALLOW_PAGE", "false");
myparms.put("SHOW_PARAMETER_PAGE", "false");
//Report Parameters
emitmap.put("Top Count", "6");
emitmap.put("Top Percentage", "15");
myparms.put("EMITTER_OPTIONS_KEY", emitmap);
//myparms.put("MAX_ROWS_KEY", "500");
WebViewer.display(reportName, browser, myparms);
update: i tried to add
myparms.put("BIRT_VIEWER_LOG_LEVEL", "FINE");
myparms.put("BIRT_VIEWER_LOG_DIR", "c:/temp/java/birt/");
but i am not sure if this is correct.
although i do get plenty of logs it does not give me an error nor warning in the VIEWER
(i have no clue why appying other settings to the viewer does affect the preview in the designer?!)
when i change from HTML to PDF and use preview in the DESIGNER i get this:
Quote:!ENTRY org.eclipse.core.filebuffers 4 2 2012-03-06 08:29:24.216
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.filebuffers".
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.ui.texteditor.spelling.SpellingReconcileStrategy.<init>(SpellingReconcileStrategy.java:156)
at org.eclipse.ui.editors.text.TextSourceViewerConfiguration.getReconciler(TextSourceViewerConfiguration.java:389)
at org.eclipse.wst.sse.ui.StructuredTextEditor.handleElementContentReplaced(StructuredTextEditor.java:2442)
at org.eclipse.ui.texteditor.AbstractTextEditor$5.run(AbstractTextEditor.java:468)
at org.eclipse.ui.texteditor.AbstractTextEditor$ElementStateListener.execute(AbstractTextEditor.java:599)
at org.eclipse.ui.texteditor.AbstractTextEditor$ElementStateListener.elementContentReplaced(AbstractTextEditor.java:471)
at org.eclipse.ui.editors.text.TextFileDocumentProvider$FileBufferListener.bufferContentReplaced(TextFileDocumentProvider.java:265)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager$5.run(TextFileBufferManager.java:730)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager.fireBufferContentReplaced(TextFileBufferManager.java:728)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer.handleFileContentChanged(ResourceTextFileBuffer.java:517)
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer$2.execute(ResourceFileBuffer.java:151)
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer$SafeFileChange.run(ResourceFileBuffer.java:86)
at org.eclipse.ui.internal.editors.text.UISynchronizationContext.run(UISynchronizationContext.java:34)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager.execute(TextFileBufferManager.java:629)
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer$FileSynchronizer.resourceChanged(ResourceFileBuffer.java:180)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:395)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1530)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2353)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.WorkspaceOperationRunner.run(WorkspaceOperationRunner.java:71)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.WorkspaceOperationRunner.run(WorkspaceOperationRunner.java:63)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.IDEFileReportProvider.saveFile(IDEFileReportProvider.java:377)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.IDEFileReportProvider.saveReport(IDEFileReportProvider.java:145)
at org.eclipse.birt.report.designer.internal.ui.ide.adapters.IDEFileReportProvider.saveReport(IDEFileReportProvider.java:122)
at org.eclipse.birt.report.designer.ui.preview.editors.ReportPreviewEditor.doSave(ReportPreviewEditor.java:111)
at org.eclipse.birt.report.designer.ui.preview.editors.ReportPreviewFormPage.onBroughtToTop(ReportPreviewFormPage.java:98)
at org.eclipse.birt.report.designer.ui.editors.MultiPageReportEditor.prePageChanges(MultiPageReportEditor.java:906)
at org.eclipse.birt.report.designer.ui.editors.IDEMultiPageReportEditor.prePageChanges(IDEMultiPageReportEditor.java:525)
at org.eclipse.birt.report.designer.ui.editors.MultiPageReportEditor.pageChange(MultiPageReportEditor.java:830)
at org.eclipse.ui.part.MultiPageEditorPart$2.widgetSelected(MultiPageEditorPart.java:290)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:2745)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1432)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:257)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at lumo.application.Application.start(Application.java:21)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
[Updated on: Tue, 06 March 2012 07:33] Report message to a moderator
Re: Birt fails on report with strings [message #814715 is a reply to message #814199] |
Tue, 06 March 2012 19:57 |
Ludwig,
When you run it and get the error can you check the workspace folder:
\.metadata\.plugins\org.eclipse.birt.report.viewer\logs
to see if any errors show up in the log file?
Jason
> //Report Parameters
Re: Birt fails on report with strings [message #815027 is a reply to message #814715] |
Wed, 07 March 2012 06:11 |
ok in that folder there is one file (i ceaned up before starting the app)
Quote:ReportEngine_2012_03_07_07_07_45.log
and its 0KB -> empty
can it be a problem that i give birt an ContactImpl.class whereat it only knows its a Contact.class
so i handle an implementation whereat i tell him its an interface (i do that everywhere in my program) to seperate implementation from defined interfaces...
[Updated on: Wed, 07 March 2012 09:51] Report message to a moderator
Re: Birt fails on report with strings [message #815536 is a reply to message #815027] |
Wed, 07 March 2012 19:46 |
Any way you can re-create the issue in a report I can run?
Jason
> Quote:
Re: Birt fails on report with strings [message #816503 is a reply to message #815878] |
Thu, 08 March 2012 23:29 |
Ludwig,
Email a complete sample so I can test it out.
Jason
On 3/8/2012 1:27 AM, Ludwig Moser wrote:
> if you mean create an report that runs without any of my java files?
> i doubt so. but i can provide you a complete sample.
FUDForum. Page generated in 0.06455 seconds
