Home » Eclipse Projects » Babel » Basic Eclipse Strings(How to translate strings like "data set", "data qube", "variables"?)
Basic Eclipse Strings [message #810636] Thu, 01 March 2012 11:04 Go to next message
Sebastian Hä älä is currently offline Sebastian Hä äläFriend
I am looking for a way to translate basic Strings from Eclipse/BIRT like "Data Set", "Data Qube" or "Variables". Data Set and Data Qube are translated already (for german) but I think they are wrong! In the Outline view Variables isn't translated (German) for me!
I tryed to search these but couldn't find them.
Re: Basic Eclipse Strings [message #810969 is a reply to message #810636] Thu, 01 March 2012 19:01 Go to previous messageGo to next message
Denis Roy is currently offline Denis RoyFriend
Babel doesn't support searching for an English string and translating it, but that does sound like a great feature to add. Can you open a feature request against Technology > Babel > Server ?
Denis Roy
Eclipse Webmaster -- webmaster@eclipse.org
Re: Basic Eclipse Strings [message #811002 is a reply to message #810969] Thu, 01 March 2012 20:06 Go to previous messageGo to next message
If you have the MySQL data dump, you can use this SQL statement to generate completely usable URLs for English strings:
select distinct CONCAT("http://babel.eclipse.org/babel/translate.php?project=", f.project_id, "&version=", f.version, "&file=", f.name, "&string=", s.name) AS URL from files as f inner join strings as s on s.file_id = f.file_id where s.value IN("Data Cube", "Data Set") and s.is_active = 1;
Denis Roy
Re: Basic Eclipse Strings [message #811085 is a reply to message #811002] Thu, 01 March 2012 23:06 Go to previous messageGo to next message
Satoru Yoshida is currently offline Satoru YoshidaFriend
Today I find several strings that You may have interest when I searching '---%' strings.
There are ----------Data Sets----------, ---------Data Cubes--------- and ---Data Cubes--- strings in org.eclipse.birt.chart.reportitem.ui/org/eclipse/birt/chart/reportitem/ui/i18n/nls.properties .
Thanks.
Re: Basic Eclipse Strings [message #811345 is a reply to message #811085] Fri, 02 March 2012 08:14 Go to previous message
Thank you for your responses! I filed a feature request.
Also I found some of the string here:
babel.eclipse.org/babel/translate.php?project=birt&version=3.7.0&file=org.eclipse.birt.report.designer.ui.cubebuilder/org/eclipse/birt/report/designer/ui/cubebuilder/nls/messages.properties
EDIT: I would have postet it as a link but they won't let me post links so just type a http:/ / infront Smile
[Updated on: Fri, 02 March 2012 08:15]
Report message to a moderator
Previous Topic:Search and translate
Next Topic:Terminology Lists or Glossary Lists for Eclipse Platform?
Current Time: Tue Apr 16 10:11:49 GMT 2024
Powered by FUDForum. Page generated in 0.07759 seconds
