Home » Modeling » TMF (Xtext) » Non-LL1 Grammar handling with JvmTypes(Do you have any ideas?)
Non-LL1 Grammar handling with JvmTypes [message #810326] Thu, 01 March 2012 00:55 Go to next message
Jens-Uwe Moeller is currently offline Jens-Uwe MoellerFriend
i would like to define a kind of type definition using xtext, that may either refer to a JvmTypeReference or to an already defined type.
My first idea for the rule looks like
MyTypeDecl returns MyTypeDecl:
	{MyTypeDecl} 'type' name=ValidID
	(':' type=JvmTypeReference |
	 ':' typesuper=[PmDslTypeDecl]
I know, that a solution could be to use different keywords, like
	('is' type=JvmTypeReference |
	 'extends' typesuper=[PmDslTypeDecl]
but that is not the solution, I am looking for, as it delegates the problem to the user of my language.
In documentation chapter "The Grammar Language" was a hint to use backtracking, but it was not explained.
I suppose, that this problem is so common, that you already know an elegant solution.
Jens
Re: Non-LL1 Grammar handling with JvmTypes [message #810337 is a reply to message #810326] Thu, 01 March 2012 01:22 Go to previous messageGo to next message
Just meant LR1, not LL1, sorry. Jens
Re: Non-LL1 Grammar handling with JvmTypes [message #877500 is a reply to message #810326] Sat, 26 May 2012 21:56 Go to previous messageGo to next message
Christian Mauceri is currently offline Christian MauceriFriend
I have exactly the same problem and I would be very interested in a solution Smile
[Updated on: Sun, 27 May 2012 14:10]
Report message to a moderator
Re: Non-LL1 Grammar handling with JvmTypes [message #877764 is a reply to message #877500] Sun, 27 May 2012 17:15 Go to previous message
I found the solution in the excellent post : Five simple steps to your JVM language, I can't post the link here because I'm a newbie Sad
Make your objects part of JvmType using JvmModelInferrer.
[Updated on: Sun, 27 May 2012 17:30]
Previous Topic:Question concerning grammar
Next Topic:IOConsole Listener
Current Time: Tue Jan 26 19:45:10 GMT 2021
Powered by FUDForum. Page generated in 0.02119 seconds
