Home » Modeling » UML2 » URI.createURI
URI.createURI [message #809015] |
Tue, 28 February 2012 11:41 |
here is very newbie question, why we need uri in the following example?
> Map uriMap = resourceSet.getURIConverter().getURIMap();
> URI uri = URI.createURI("jar:file:<path_to_resource_jar_file>/org.eclipse.uml2.uml.resources_<version>.jar!/");
> uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
> uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
> uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
Seems, that <version> here determines which xmi documents i can parse,
for example, if i specify 3.0.0.v200906011111 (and i have
org.eclipse.uml2.uml.resources_3.0.0.v200906011111.jar file) i can later
read xmi files which contain
> <xmi:XMI xmi:version="2.1" ... xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML">
and not files with xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
is it possible to "configure" resourceSet, so that it can handle both
xmi files?
honestly, i'm not quite comfortable with all stuff around eclipse uml2,
emf, xmi and maybe also xml
for example i understand, that xmlns:uml defines a namespace, but the
following snipped of code which i have confuses me and i don't
understand it fully:
> private void initializeEditingDomain() {
> String path = "lib/xmihandlerjars/org.eclipse.uml2.uml.resources_3.0.0.v200906011111.jar";
> BasicCommandStack commandStack = new BasicCommandStack() {
> @Override
> protected void handleError(Exception exception) {
> super.handleError(exception);
> throw new RuntimeException(exception);
> List<AdapterFactory> factories = new ArrayList<AdapterFactory>();
> factories.add(new UMLResourceItemProviderAdapterFactory());
> factories.add(new UMLItemProviderAdapterFactory());
> factories.add(new EcoreItemProviderAdapterFactory());
> factories.add(new UMLReflectiveItemProviderAdapterFactory());
> ComposedAdapterFactory adapterFactory = new ComposedAdapterFactory(
> factories);
> editingDomain = new UML2AdapterFactoryEditingDomain(adapterFactory,
> commandStack);
> ResourceSet resourceSet = editingDomain.getResourceSet();
> Map<String, Object> extensionToFactoryMap = resourceSet
> .getResourceFactoryRegistry().getExtensionToFactoryMap();
> Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
> try {
> FileInputStream in = new FileInputStream(path);
> in.close();
> } catch (IOException e) {
> throw (new RuntimeException(e));
> path = path.replace('\\', '/');
> URI uri = URI.createURI("jar:file:" + path + "!/");
> Log.debug("eUML.resource URI --> " + uri);
> Registry packageRegistry = resourceSet.getPackageRegistry();
> packageRegistry.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
> packageRegistry.put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
> // for other xmi files with further namespaces:
> packageRegistry.put(XMI212UMLResource.UML_METAMODEL_2_1_1_NS_URI,
> packageRegistry.put(XMI212UMLResource.UML_METAMODEL_2_1_1_URI,
> packageRegistry.put(XMI212UMLResource.UML_METAMODEL_2_1_NS_URI,
> packageRegistry.put(XMI212UMLResource.UML_METAMODEL_2_1_URI,
> packageRegistry.put(XMI212UMLResource.UML_METAMODEL_2_2_NS_URI,
> packageRegistry.put(XMI212UMLResource.UML_METAMODEL_NS_URI,
> packageRegistry.put(XMI212UMLResource.UML_METAMODEL_URI,
> // eclipse namespaces:
> packageRegistry.put(UML212UMLResource.UML_METAMODEL_NS_URI,
> packageRegistry.put("http://www.eclipse.org/uml2/3.0.0/UML",
> // For the .uml files in the eclipse jar files, we need this:
> extensionToFactoryMap.put(UMLResource.FILE_EXTENSION,
> UMLResource.Factory.INSTANCE);
> extensionToFactoryMap.put(UML22UMLResource.FILE_EXTENSION,
> UML22UMLResource.Factory.INSTANCE);
> extensionToFactoryMap.put(XMI2UMLResource.FILE_EXTENSION,
> XMI2UMLResource.Factory.INSTANCE);
> uriMap.putAll(UML22UMLExtendedMetaData.getURIMap());
> uriMap.putAll(XMI2UMLExtendedMetaData.getURIMap());
in the code above, why we need
if namespace http://www.eclipse.org/uml2/3.0.0/UML is already defined
via uri and uriMap?
what is the role of editing domain? Do i need it to just simply parse
xmi files?
i know, questions above are all spontaneous and most likely wrong
formulated, but i'll be very glad if someone help to clarify all that stuff.
thanks in advance!
Re: URI.createURI [message #809042 is a reply to message #809015] |
Tue, 28 February 2012 12:26 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Emil
My sympathies; I find it hard too and the support routines are not as
helpful as they might be.
The basic problem is that there are many dramatically different contents
for a *.xmi file, and subtly different contents for a *.uml file.
Whereas for a *.ecore file there is only ever Ecore content, unless you
want to have a really hard time. So for UML, extensions do not define
file content. It is therefore necessary to use content type, so on
encountering an *.xmi file or *.uml file the XML namespace is used to
select the appropriate EMF model handling.
You appear to be using Indigo for which the UML versions have been stuck
at 2.2 for some years. The good/bad news is that in Juno there is
support for UML 2.4 and 2.4.1 so there are now about nine different UML
dialects. Yes, you can (and should) register all at once.
/org.eclipse.ocl.examples.pivot/src/org/eclipse/ocl/examples/pivot/uml/UMLUtils.java
in the OCL GIT is my attempt to do so.
UML has profiles that allow you to tailor your models, These are
generally shared so it cannot be assumed that they are in a similar
location to the model, so where are they? pathmap:'s give a
reconfigurable indirection which is flexible but also inconvenient
because until they are correctly configured not much works.
A Resource supports usage of one model. A ResourceSet set supports usage
of many models. An EditingDomain supports many models in the context of
an editor and on a good day may be shared across editors and tools so
that when a model is edited in one place everything else updates
accordingly.
UriMap redirects the pathmaps to somewhere useful. Resource registration
facilitates the location of a Resource for loading. Extension and
content registration facilitates the use of appropriate
ResourceFactories to create Resources.
Ed Willink
On 28/02/2012 11:41, Emil Huseynli wrote:
> Hello,
>> URI uri =
> later read xmi files which contain
> xmi files?
> uml2, emf, xmi and maybe also xml
>> String path =
>> @Override
>> factories);
>> commandStack);
>> try {
>> in.close();
>> uri.appendSegment(
>> uri.appendSegment(
> via uri and uriMap?
> xmi files?
> stuff.
> thanks in advance!
Re: URI.createURI [message #809056 is a reply to message #809042] |
Tue, 28 February 2012 12:44 |
thanks a lot! i'll take a look at your code
On 28.02.2012 13:26, Ed Willink wrote:
> Hi Emil
> accordingly.
> Regards
> Ed Willink
>> Hello,
>>> URI uri =
>> xmi files?
>>> String path =
>>> @Override
>>> factories);
>>> commandStack);
>>> try {
>>> in.close();
>>> uri.appendSegment(
>>> uri.appendSegment(
>> via uri and uriMap?
>> xmi files?
>> stuff.
>> thanks in advance!
Re: URI.createURI [message #809087 is a reply to message #809042] |
Tue, 28 February 2012 13:13 |
in UMLUtils.java you use URI.createPlatformPluginURI, does it load all
available jar files with resources? i.e.
where <version> are 3.0.0.v200906011111 or 2.0.0v20080702111 or whatever
else
should i do URI.createURI multiple times for different jar files in
order to support xmi files with different namespaces?
or are the instructions like
which determine how many different xmi-types will be available?
> Hi Emil
> accordingly.
> Regards
> Ed Willink
>> Hello,
>>> URI uri =
>> xmi files?
>>> String path =
>>> @Override
>>> factories);
>>> commandStack);
>>> try {
>>> in.close();
>>> uri.appendSegment(
>>> uri.appendSegment(
>> via uri and uriMap?
>> xmi files?
>> stuff.
>> thanks in advance!
Re: URI.createURI [message #809099 is a reply to message #809087] |
Tue, 28 February 2012 13:27 |
You may need
/org.eclipse.ocl.examples.domain/src/org/eclipse/ocl/examples/domain/utilities/ProjectMap.java
to scan the classpath for all possible JARs.
Ed Willink
> whatever else
>> Hi Emil
>> accordingly.
>> Regards
>> Ed Willink
>>> Hello,
>>>> URI uri =
>>> xmi files?
>>>> String path =
>>>> @Override
>>>> factories);
>>>> commandStack);
>>>> try {
>>>> in.close();
>>>> uri.appendSegment(
>>>> uri.appendSegment(
>>> via uri and uriMap?
>>> xmi files?
>>> stuff.
>>> thanks in advance!
Re: URI.createURI [message #809131 is a reply to message #809099] |
Tue, 28 February 2012 14:09 |
I'm trying to load resource from standalone application, and one
important thing is not clear:
in order to support different xmi versions, do i need also different
versions of org.eclipse.uml2.uml.resources_<version>.jar ? Or only
latest version and support for different xmi is achieved with following?
> packageRegistry.put("http://www.eclipse.org/uml2/2.0.0/UML",
On 28.02.2012 14:27, Ed Willink wrote:
> Hi
> You may need
> Regards
> Ed Willink
>> whatever else
>>> Hi Emil
>>> accordingly.
>>> Regards
>>> Ed Willink
>>>> Hello,
>>>>> URI uri =
>>>> xmi files?
>>>>> String path =
>>>>> @Override
>>>>> factories);
>>>>> commandStack);
>>>>> try {
>>>>> in.close();
>>>>> uri.appendSegment(
>>>>> uri.appendSegment(
>>>> via uri and uriMap?
>>>> xmi files?
>>>> stuff.
>>>> thanks in advance!
Re: URI.createURI [message #809157 is a reply to message #809131] |
Tue, 28 February 2012 14:38 |
The latest version should support all UML versions. There is subtle code
in the meta-model loading that enables the one meta-model to support all
dialects.
If you use plugins you should never need to worry about _<version>.
Ed Willink
>> Hi
>> You may need
>> Regards
>> Ed Willink
>>> whatever else
>>>> Hi Emil
>>>> contents
>>>> you
>>>> stuck
>>>> UML
>>>> usage
>>>> context of
>>>> accordingly.
>>>> registration
>>>> Regards
>>>> Ed Willink
>>>>> Hello,
>>>>> example?
>>>>>> URI uri =
>>>>> parse,
>>>>> xmi files?
>>>>>> String path =
>>>>>> @Override
>>>>>> factories);
>>>>>> commandStack);
>>>>>> try {
>>>>>> in.close();
>>>>>> uri.appendSegment(
>>>>>> uri.appendSegment(
>>>>> via uri and uriMap?
>>>>> xmi files?
>>>>> stuff.
>>>>> thanks in advance!
Re: URI.createURI [message #809206 is a reply to message #809042] |
Tue, 28 February 2012 15:42 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
FYI, there is a related enhancement request open (364419) which I hope
to have addressed in time for Juno...
Kenn
On 12-02-28 7:26 AM, Ed Willink wrote:
> Hi Emil
> accordingly.
> Regards
> Ed Willink
>> Hello,
>>> URI uri =
>> xmi files?
>>> String path =
>>> @Override
>>> factories);
>>> commandStack);
>>> try {
>>> in.close();
>>> uri.appendSegment(
>>> uri.appendSegment(
>> via uri and uriMap?
>> xmi files?
>> stuff.
>> thanks in advance!
Re: URI.createURI [message #809207 is a reply to message #809157] |
Tue, 28 February 2012 15:47 |
if i use plugins? which plugins do you mean?
On 28.02.2012 15:38, Ed Willink wrote:
> Hi
> dialects.
> Regards
> Ed Willink
>>> Hi
>>> You may need
>>> Regards
>>> Ed Willink
>>>> whatever else
>>>>> Hi Emil
>>>>> contents
>>>>> you
>>>>> stuck
>>>>> UML
>>>>> usage
>>>>> context of
>>>>> accordingly.
>>>>> registration
>>>>> Regards
>>>>> Ed Willink
>>>>>> Hello,
>>>>>> example?
>>>>>>> URI uri =
>>>>>> parse,
>>>>>> xmi files?
>>>>>>> String path =
>>>>>>> @Override
>>>>>>> factories);
>>>>>>> commandStack);
>>>>>>> try {
>>>>>>> in.close();
>>>>>>> uri.appendSegment(
>>>>>>> uri.appendSegment(
>>>>>> via uri and uriMap?
>>>>>> xmi files?
>>>>>> stuff.
>>>>>> thanks in advance!
Re: URI.createURI [message #809277 is a reply to message #809240] |
Tue, 28 February 2012 17:15 |
understood :)
thanks a lot!
On 28.02.2012 17:25, Ed Willink wrote:
> Hi
> I mean place your code in a Plugin (Java) project rather than a Java
> Project so that MANIFEST.MF sorts out the classpath.
> Regards
> Ed Willink
Current Time: Fri Apr 19 03:42:11 GMT 2024
Powered by FUDForum. Page generated in 0.02474 seconds
