Home » Modeling » M2T (model-to-text transformation) » [XPAND] Generating More Than One Instance
[XPAND] Generating More Than One Instance [message #808859] Tue, 28 February 2012 08:23 Go to next message
sbl Missing name is currently offline sbl Missing nameFriend
Member
I have some problems about generating more than one instance elements.
I have 3 distinct instance "input" elements in my model. I want to generate a file and put all instance element's name in it. For example:
Sample.txt:
input1
input2
input3
Unfortunally I see only one of them in my generated files with these codes:
Xtext file:
main:
(input+=Input|output+=Output)*
Input:
'Input' name=ID ';' ;
Output:
'Output' name=ID ';';
Template file:
«IMPORT org::xtext::example::mydsl2::myDsl»
«EXTENSION templates::Extensions»
«DEFINE main FOR Input»
«FOREACH ((main)eContainer()).input AS in»
«FOREACH ((main)eContainer()).output AS out»
«FILE name+".txt"»
This is an example of a generated file.
«in.name»
«out.name»
«ENDFILE-»
«ENDDEFINE»
Re: [XPAND] Generating More Than One Instance [message #808915 is a reply to message #808859] Tue, 28 February 2012 09:30 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi either the file statement is at the wrong place or you have to
configure your outlet to work in append mode
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: [XPAND] Generating More Than One Instance [message #808936 is a reply to message #808915] Tue, 28 February 2012 09:59 Go to previous messageGo to next message
Member
I replaced the file statement, the program does not give errors but it only gives one instance's name.
Re: [XPAND] Generating More Than One Instance [message #808967 is a reply to message #808936] Tue, 28 February 2012 10:33 Go to previous messageGo to next message
How do workflow and template look like
Re: [XPAND] Generating More Than One Instance [message #808975 is a reply to message #808967] Tue, 28 February 2012 10:41 Go to previous messageGo to next message
Member
template is :
Template file:
«FILE name+".txt"»
«in.name»
«out.name»
«ENDFILE-»
«ENDDEFINE»
workflow is:
module workflow.MyDslGenerator
import org.eclipse.emf.mwe.utils.*
var targetDir = "src-gen"
var fileEncoding = "Cp1254"
var modelPath = "src/model"
Workflow {
component = org.eclipse.xtext.mwe.Reader {
// lookup all resources on the classpath
// useJavaClassPath = true
// or define search scope explicitly
path = modelPath
// this class will be generated by the xtext generator
register = org.xtext.example.mydsl2.MyDslStandaloneSetup {}
load = {
slot = "slot1"
type = "main"
component = org.eclipse.xpand2.Generator {
expand = "templates::Template::main FOREACH slot1"
outlet = {
path = targetDir
fileEncoding = fileEncoding
Re: [XPAND] Generating More Than One Instance [message #809033 is a reply to message #808975] Tue, 28 February 2012 12:18 Go to previous messageGo to next message
you call your workflow for inputs
=> it will be called foreach input
you have the file within the foreachs (the partial template you posted indicates that)
you will call the file foreach output
=> it will not work
you have as i said (3) options
(1) restructure the templates to take a main (root of your dsl) as generation root
(you might have to trick cause it does not have a name - but the solution for that is described 1000 times in the forum - you wíll see if you google for the errror message)
(2) restructure the template (but beeing inefficient)
«FILE name+".txt"»
«in.name»
«ENDFOREACH»
«out.name»
«ENDFOREACH»
«ENDFILE-»
«ENDDEFINE»
(3) or you configure the outlet with append=true in the workflow
Re: [XPAND] Generating More Than One Instance [message #810551 is a reply to message #809033] Thu, 01 March 2012 08:37 Go to previous messageGo to next message
Member
Thank you for yor replies.
1. main is root of my DSL? Unfortunally I could not understand the solution.
2. I tried the second solution but it didn't help me because I want to invoke «in.name» in several places and several times.
3. How can I add append=true in my workflow?
Do I need add this statement for both input and output?
Thank you very much.
Re: [XPAND] Generating More Than One Instance [message #810918 is a reply to message #810551] Thu, 01 March 2012 17:28 Go to previous messageGo to next message
it is quite easy
(1) if you change the template to
«DEFINE main FOR main-»
«FILE "test.txt"-»
«FOREACH input AS i»
«i.name»
«ENDFOREACH»
«FOREACH output AS o»
«o.name»
«ENDFOREACH»
«ENDFILE-»
«ENDDEFINE»
and the workflow to
		path = modelPath
		register = org.xtext.example.mydsl1.MyDslStandaloneSetup {}
		load = {
			slot = "main"
			type = "main"
		expand = "templates::Template::main FOREACH main"
		outlet = {
			path = targetDir
you will get the error message
0    [main] DEBUG        org.eclipse.xtext.mwe.Reader  - Resource Pathes : [src/model]
0    [main] INFO         org.eclipse.xpand2.Generator  - No meta models configured, using JavaBeans as default.
141  [main] DEBUG xt.validation.ResourceValidatorImpl  - Syntax check OK! Resource: file:/C:/work/xtext/Xtext102/ws_xxxxx/org.xtext.example.mydsl1.generator/src/model/Example.mydsl1
219  [main] WARN      org.eclipse.xtext.mwe.SlotEntry  - Could not find any exported element of type 'main' -> Slot 'main' is empty.
251  [main] INFO  .emf.mwe2.runtime.workflow.Workflow  - Done.
you can work arround this (this is the place where i asked you to google)
e.g. using a IQualifiedNameProvider that gives the main a name
btw you should have go this error message anyway. at least with the workflow you posted
(2) since you example is very very simple and you did not say anything regarding your problem i still do not understand why you cannot do something like
«FILE name+".txt"»
«in.name»
«ENDFOREACH»
«out.name»
«ENDFOREACH»
«in.name»
«ENDFOREACH»
«out.name»
«ENDFOREACH»
«in.name»
«ENDFOREACH»
«out.name»
«ENDFOREACH»
«ENDFILE-»
«ENDDEFINE»
(3)
what about simple
		outlet = {
			path = targetDir
			append = true
[Updated on: Thu, 01 March 2012 17:29]
Report message to a moderator
Re: [XPAND] Generating More Than One Instance [message #813418 is a reply to message #810918] Mon, 05 March 2012 08:38 Go to previous messageGo to next message
Member
Thanks for replies. My essential problem is I do not know how many instance "input" or "output" elements in the instance model. I mean, I can not use
«in.name»
«ENDFOREACH»
because I do not know how many times do I have to use it. There may be one input1 or 5 inputs(input1, input2, ... , input5)
Re: [XPAND] Generating More Than One Instance [message #813425 is a reply to message #813418] Mon, 05 March 2012 08:44 Go to previous message
I still do not see why this is a problem
Previous Topic:[Acceleo] quick question on acceleo
Next Topic:[Acceleo] How to generate a sequence (bag) of consecutive integers starting at 1
Current Time: Tue Nov 29 22:27:55 GMT 2022
Powered by FUDForum. Page generated in 0.02919 seconds
