Home » Archived » BIRT » BIRT in an Eclipse RCP application(Plugin dependencies issue)
BIRT in an Eclipse RCP application [message #808242] Mon, 27 February 2012 10:17 Go to next message
I am trying to use BIRT in an Eclipse RCP application, to run a report and export it as a DOC or PDF file.
I have got the following exception a lot:
org.eclipse.birt.report.engine.api.UnsupportedFormatException: The output format DOC is not supported.
at org.eclipse.birt.report.engine.api.impl.EngineTask.setupRenderOption(EngineTask.java:1941)
I also tried with the example RCP project I found here: wiki.eclipse.org/RCP_Example_%28BIRT%29_2.1#Download_Examples but I have the same error.
The only way I found to solve my problem so far is to include all the plugins that match org.eclipse.datatools* and org.eclipse.birt*, but this adds more than 300 plugins...
What plugins are actually needed to run BIRT in an Eclipse RCP application?
Thanks in advance.
David
Re: BIRT in an Eclipse RCP application [message #808560 is a reply to message #808242] Mon, 27 February 2012 17:39 Go to previous messageGo to next message
If you want to use the viewer here in an rcp app here is a product
config file:
http://www.birt-exchange.org/org/devshare/deploying-birt-reports/1194-eclipse-product-configuration-file-for-webviewer-in-rcp/
Just to use use the RE API, should be less.
For doc output make sure you have the
org.eclipse.birt.report.engine.emitter.wpml plugin.
Jason
On 2/27/2012 10:17 AM, David B. wrote:
> Hi, I am trying to use BIRT in an Eclipse RCP application, to run a
> at
> the same error.
> Thanks in advance.
> David
Re: BIRT in an Eclipse RCP application [message #808865 is a reply to message #808560] Tue, 28 February 2012 03:32 Go to previous messageGo to next message
Thank you Jason, now I have it working with much less plugins.
David
Re: BIRT in an Eclipse RCP application [message #1012981 is a reply to message #808560] Fri, 22 February 2013 10:05 Go to previous messageGo to next message
I have the same promble when I use birt 4.2.1 to build a Rcp application ,and I have import all the jars that related to birt .But still can't run the report.and the error massage is "PDF format is not supported".Did 4.2.1 different from 3.7.2 and other old version?
Re: BIRT in an Eclipse RCP application [message #1013173 is a reply to message #1012981] Fri, 22 February 2013 18:49 Go to previous messageGo to next message
That error message indicates that the pdf emitter is not in your runtime set of plugins.
Jason
Re: BIRT in an Eclipse RCP application [message #1013196 is a reply to message #1012981] Fri, 22 February 2013 20:30 Go to previous message
I think I can't find the emitter.config.pdf jar,where can I download it
Previous Topic:Trouble using Tribix Excel Emitter
Next Topic:I can't display the report using birt Rcp viewer
Current Time: Fri Apr 18 00:31:28 EDT 2025
Powered by FUDForum. Page generated in 0.04255 seconds
