Home » Modeling » M2T (model-to-text transformation) » [Acceleo] quick question on acceleo
[Acceleo] quick question on acceleo [message #808004] Mon, 27 February 2012 09:32 Go to next message
Belqassim Djafer is currently offline Belqassim DjaferFriend
Hi everyone,
I transformed a set of model activity diagram to ATN models with ATL.
These ATN models are written in XMI, and they are consistent with a meta-model of ATN.
Is it possible to generate Java code for all the resulting models with Acceleo?
cordially.
[Updated on: Mon, 27 February 2012 09:32]
Report message to a moderator
Re: [Acceleo] quick question on acceleo [message #808929 is a reply to message #808004] Tue, 28 February 2012 09:51 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
Yes (since ATL uses EMF models)
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: [Acceleo] quick question on acceleo [message #809036 is a reply to message #808929] Tue, 28 February 2012 12:19 Go to previous messageGo to next message
Merci monsieur,
So, is it possible to program a template for my metamodel ATN ?
in other words, change the module '...emf/2002/Ecore' by the meta-model ATN ?
Merci d'avance.
Re: [Acceleo] quick question on acceleo [message #809129 is a reply to message #809036] Tue, 28 February 2012 14:11 Go to previous messageGo to next message
ou can start your generator with a module like this:
[comment encoding=utf-8/]
[module myModyke()]
[template public hello(o: MyType)]
[comment @main/]
[file('stuff.txt', false, 'utf-8')]
Hello World !
[/file]
[/template]
Re: [Acceleo] quick question on acceleo [message #809169 is a reply to message #809129] Tue, 28 February 2012 15:03 Go to previous messageGo to next message
Hi, above all I thank you for your help
[module myModyke()] this means the path of my meta-model ?
for example, [module /projet/MetaModeles/ATNdiagram.ecore()] ??
Regards.
Re: [Acceleo] quick question on acceleo [message #811365 is a reply to message #809169] Fri, 02 March 2012 08:46 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
Please take a look at the Acceleo documentation available on the wiki, at least the quick start.
"myModyke" (actually, Stephane wanted to write "myModule") is the name of your module. The metamodel URI goes inside of the parenthesis.
Laurent Goubet
Obeo
Previous Topic:[XPAND] Problem with token names
Next Topic:[XPAND] Generating More Than One Instance
Current Time: Thu Mar 04 10:25:14 GMT 2021
Powered by FUDForum. Page generated in 0.02346 seconds
