Home » Eclipse Projects » EclipseLink » Native Query using function not finding primary key(When calling a function, EL unable to decode result correctly)
Native Query using function not finding primary key [message #807707] Sun, 26 February 2012 22:53 Go to next message
Hal Hildebrand is currently offline Hal HildebrandFriend
I create a simple function which selects all the rows in a table. I then create a Native query which calls this function, setting the resultClass to the entity that maps to the result of the function. When run, Eclipselink fails with the following error:
Exception Description: The primary key read from the row [ArrayRecord(
=> (2,bar,1))] during the execution of the query was detected to be null. Primary keys must not contain null.
Query: ReadAllQuery(name="relationship.getAll" referenceClass=Relationship sql="select r from test.get_relationships() as r")
Attached is a complete test case for this problem.
[Updated on: Mon, 27 February 2012 00:56]
Report message to a moderator
Re: Native Query using function not finding primary key [message #808265 is a reply to message #807707] Mon, 27 February 2012 15:42 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
Since I cannot see what the results from the function are and you didn't mention which database this is on, my guess is that it is returning the "ID" field as something else (possibly "id"?). If so, try using the "eclipselink.jpa.uppercase-column-names" persistence property with a value of true, as will allow EclipseLink to uppercase the column names in the returned results so the "ID" value can be found.
If this doesn't work, please try setting logging to finest and printing off the results.
Best Regards,
Chris
Re: Native Query using function not finding primary key [message #808310 is a reply to message #808265] Mon, 27 February 2012 16:36 Go to previous messageGo to next message
I have included the properties I'm using in the test case attached to the message. As that shows, I have set the property of which you speak to true. Will rerun with FINEST and upload the log results.
Re: Native Query using function not finding primary key [message #808321 is a reply to message #808265] Mon, 27 February 2012 16:54 Go to previous messageGo to next message
Here is the result of running the test with log level FINEST. As you can verify from the test case's persistence.xml, the property is set to true:
<property name="eclipselink.jdbc.uppercase-columns" value="true"/>
Running test.TestRelationship
[EL Finest]: 2012-02-27 08:52:19.576--ServerSession(55821173)--Thread(Thread[main,5,main])--Begin predeploying Persistence Unit test; session file:/Users/hhildebrand/git/eclipselink-function-query/target/classes/_test_url=jdbc:postgresql://localhost:5432/test_user=postgres; state Initial; factoryCount 0
[EL Finest]: 2012-02-27 08:52:19.59--ServerSession(55821173)--Thread(Thread[main,5,main])--property=eclipselink.orm.throw.exceptions; default value=true
[EL Finest]: 2012-02-27 08:52:19.59--ServerSession(55821173)--Thread(Thread[main,5,main])--property=eclipselink.multitenant.tenants-share-emf; default value=true
[EL Finest]: 2012-02-27 08:52:19.591--ServerSession(55821173)--Thread(Thread[main,5,main])--property=eclipselink.multitenant.tenants-share-cache; default value=false
[EL Finest]: 2012-02-27 08:52:19.609--ServerSession(55821173)--Thread(Thread[main,5,main])--property=eclipselink.metadata-source; default value=null
[EL Finer]: 2012-02-27 08:52:19.609--ServerSession(55821173)--Thread(Thread[main,5,main])--Searching for default mapping file in file:/Users/hhildebrand/git/eclipselink-function-query/target/classes/
[EL Finer]: 2012-02-27 08:52:19.611--ServerSession(55821173)--Thread(Thread[main,5,main])--Searching for default mapping file in file:/Users/hhildebrand/git/eclipselink-function-query/target/classes/
[EL Config]: 2012-02-27 08:52:19.746--ServerSession(55821173)--Thread(Thread[main,5,main])--The access type for the persistent class [class test.Relationship] is set to [FIELD].
[EL Config]: 2012-02-27 08:52:19.785--ServerSession(55821173)--Thread(Thread[main,5,main])--The target entity (reference) class for the one to one mapping element [field inverse] is being defaulted to: class test.Relationship.
[EL Config]: 2012-02-27 08:52:19.787--ServerSession(55821173)--Thread(Thread[main,5,main])--The alias name for the entity class [class test.Relationship] is being defaulted to: Relationship.
[EL Config]: 2012-02-27 08:52:19.816--ServerSession(55821173)--Thread(Thread[main,5,main])--The column name for element [id] is being defaulted to: ID.
[EL Config]: 2012-02-27 08:52:19.818--ServerSession(55821173)--Thread(Thread[main,5,main])--The column name for element [name] is being defaulted to: NAME.
[EL Config]: 2012-02-27 08:52:19.82--ServerSession(55821173)--Thread(Thread[main,5,main])--The sequence name for the sequence generator named [relationship_id_seq] defined on [class test.Relationship] from [class test.Relationship] is being defaulted to: relationship_id_seq.
[EL Config]: 2012-02-27 08:52:19.85--ServerSession(55821173)--Thread(Thread[main,5,main])--The primary key column name for the mapping element [field inverse] is being defaulted to: ID.
[EL Finest]: 2012-02-27 08:52:19.851--ServerSession(55821173)--Thread(Thread[main,5,main])--End predeploying Persistence Unit test; session file:/Users/hhildebrand/git/eclipselink-function-query/target/classes/_test_url=jdbc:postgresql://localhost:5432/test_user=postgres; state Predeployed; factoryCount 0
[EL Finer]: 2012-02-27 08:52:19.851--Thread(Thread[main,5,main])--JavaSECMPInitializer - transformer is null.
[EL Finest]: 2012-02-27 08:52:19.851--ServerSession(55821173)--Thread(Thread[main,5,main])--Begin predeploying Persistence Unit test; session file:/Users/hhildebrand/git/eclipselink-function-query/target/classes/_test_url=jdbc:postgresql://localhost:5432/test_user=postgres; state Predeployed; factoryCount 0
[EL Finest]: 2012-02-27 08:52:19.852--ServerSession(55821173)--Thread(Thread[main,5,main])--End predeploying Persistence Unit test; session file:/Users/hhildebrand/git/eclipselink-function-query/target/classes/_test_url=jdbc:postgresql://localhost:5432/test_user=postgres; state Predeployed; factoryCount 1
[EL Finest]: 2012-02-27 08:52:19.859--ServerSession(55821173)--Thread(Thread[main,5,main])--Begin deploying Persistence Unit test; session file:/Users/hhildebrand/git/eclipselink-function-query/target/classes/_test_url=jdbc:postgresql://localhost:5432/test_user=postgres; state Predeployed; factoryCount 1
[EL Finer]: 2012-02-27 08:52:19.873--ServerSession(55821173)--Thread(Thread[main,5,main])--Could not initialize Validation Factory. Encountered following exception: java.lang.NoClassDefFoundError: javax/validation/Validation
[EL Finest]: 2012-02-27 08:52:19.904--ServerSession(55821173)--Thread(Thread[main,5,main])--property=eclipselink.logging.level; value=FINEST; translated value=FINEST
[EL Finest]: 2012-02-27 08:52:19.904--ServerSession(55821173)--Thread(Thread[main,5,main])--property=eclipselink.jdbc.bind-parameters; value=false
[EL Finest]: 2012-02-27 08:52:19.904--ServerSession(55821173)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.user; value=postgres
[EL Finest]: 2012-02-27 08:52:19.904--ServerSession(55821173)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.password; value=xxxxxx
[EL Finest]: 2012-02-27 08:52:20.168--ServerSession(55821173)--Thread(Thread[main,5,main])--property=eclipselink.target-database; value=POSTGRESQL; translated value=org.eclipse.persistence.platform.database.PostgreSQLPlatform
[EL Finest]: 2012-02-27 08:52:20.169--ServerSession(55821173)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.url; value=jdbc:postgresql://localhost:5432/test
[EL Finest]: 2012-02-27 08:52:20.17--ServerSession(55821173)--Thread(Thread[main,5,main])--property=eclipselink.jdbc.uppercase-columns; value=true
[EL Info]: 2012-02-27 08:52:20.171--ServerSession(55821173)--Thread(Thread[main,5,main])--EclipseLink, version: Eclipse Persistence Services - 2.3.2.v20111125-r10461
[EL Config]: 2012-02-27 08:52:20.181--ServerSession(55821173)--Connection(1550766882)--Thread(Thread[main,5,main])--connecting(DatabaseLogin(
platform=>PostgreSQLPlatform
user name=> "postgres"
datasource URL=> "jdbc:postgresql://localhost:5432/test"
[EL Config]: 2012-02-27 08:52:20.25--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connected: jdbc:postgresql://localhost:5432/test
User: postgres
Database: PostgreSQL Version: 9.1.2
Driver: PostgreSQL Native Driver Version: PostgreSQL 9.0 JDBC4 (build 801)
[EL Finest]: 2012-02-27 08:52:20.251--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connection acquired from connection pool [default].
[EL Finest]: 2012-02-27 08:52:20.251--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connection released to connection pool [default].
[EL Finest]: 2012-02-27 08:52:20.256--ServerSession(55821173)--Thread(Thread[main,5,main])--sequencing connected, state is Preallocation_NoTransaction_State
[EL Finest]: 2012-02-27 08:52:20.256--ServerSession(55821173)--Thread(Thread[main,5,main])--sequence relationship_id_seq: preallocation size 1
[EL Info]: 2012-02-27 08:52:20.291--ServerSession(55821173)--Thread(Thread[main,5,main])--file:/Users/hhildebrand/git/eclipselink-function-query/target/classes/_test_url=jdbc:postgresql://localhost:5432/test_user=postgres login successful
[EL Finer]: 2012-02-27 08:52:20.305--ServerSession(55821173)--Thread(Thread[main,5,main])--Canonical Metamodel class [test.Relationship_] not found during initialization.
[EL Finest]: 2012-02-27 08:52:20.305--ServerSession(55821173)--Thread(Thread[main,5,main])--End deploying Persistence Unit test; session file:/Users/hhildebrand/git/eclipselink-function-query/target/classes/_test_url=jdbc:postgresql://localhost:5432/test_user=postgres; state Deployed; factoryCount 1
[EL Finer]: 2012-02-27 08:52:20.319--ServerSession(55821173)--Thread(Thread[main,5,main])--client acquired: 375652924
[EL Finer]: 2012-02-27 08:52:20.334--ClientSession(375652924)--Thread(Thread[main,5,main])--acquire unit of work: 21006994
[EL Finest]: 2012-02-27 08:52:20.334--UnitOfWork(21006994)--Thread(Thread[main,5,main])--persist() operation called on: test.Relationship@344977e2.
[EL Finest]: 2012-02-27 08:52:20.335--ClientSession(375652924)--Thread(Thread[main,5,main])--Execute query ValueReadQuery(sql="select nextval('test.relationship_id_seq')")
[EL Finest]: 2012-02-27 08:52:20.336--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connection acquired from connection pool [default].
[EL Fine]: 2012-02-27 08:52:20.336--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--select nextval(test.relationship_id_seq)
[EL Finest]: 2012-02-27 08:52:20.356--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connection released to connection pool [default].
[EL Finest]: 2012-02-27 08:52:20.357--UnitOfWork(21006994)--Thread(Thread[main,5,main])--assign sequence to the object (1 -> test.Relationship@344977e2)
[EL Finest]: 2012-02-27 08:52:20.359--UnitOfWork(21006994)--Thread(Thread[main,5,main])--persist() operation called on: test.Relationship@21c783c5.
[EL Finest]: 2012-02-27 08:52:20.36--ClientSession(375652924)--Thread(Thread[main,5,main])--Execute query ValueReadQuery(sql="select nextval('test.relationship_id_seq')")
[EL Finest]: 2012-02-27 08:52:20.36--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connection acquired from connection pool [default].
[EL Fine]: 2012-02-27 08:52:20.36--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--select nextval(test.relationship_id_seq)
[EL Finest]: 2012-02-27 08:52:20.362--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connection released to connection pool [default].
[EL Finest]: 2012-02-27 08:52:20.362--UnitOfWork(21006994)--Thread(Thread[main,5,main])--assign sequence to the object (2 -> test.Relationship@21c783c5)
[EL Finer]: 2012-02-27 08:52:20.363--UnitOfWork(21006994)--Thread(Thread[main,5,main])--begin unit of work commit
[EL Finest]: 2012-02-27 08:52:20.368--UnitOfWork(21006994)--Thread(Thread[main,5,main])--Execute query InsertObjectQuery(test.Relationship@21c783c5)
[EL Finest]: 2012-02-27 08:52:20.368--UnitOfWork(21006994)--Thread(Thread[main,5,main])--Execute query WriteObjectQuery(test.Relationship@344977e2)
[EL Finest]: 2012-02-27 08:52:20.369--UnitOfWork(21006994)--Thread(Thread[main,5,main])--Execute query WriteObjectQuery(test.Relationship@21c783c5)
[EL Finest]: 2012-02-27 08:52:20.37--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connection acquired from connection pool [default].
[EL Finer]: 2012-02-27 08:52:20.37--ClientSession(375652924)--Connection(1742392524)--Thread(Thread[main,5,main])--begin transaction
[EL Fine]: 2012-02-27 08:52:20.371--ClientSession(375652924)--Connection(1742392524)--Thread(Thread[main,5,main])--INSERT INTO test.relationship (ID, NAME, inverse) VALUES (2, bar, NULL)
[EL Fine]: 2012-02-27 08:52:20.374--ClientSession(375652924)--Connection(1742392524)--Thread(Thread[main,5,main])--INSERT INTO test.relationship (ID, NAME, inverse) VALUES (1, foo, 2)
[EL Fine]: 2012-02-27 08:52:20.377--ClientSession(375652924)--Connection(1742392524)--Thread(Thread[main,5,main])--UPDATE test.relationship SET inverse = 1, NAME = bar WHERE (ID = 2)
[EL Finer]: 2012-02-27 08:52:20.389--ClientSession(375652924)--Connection(1742392524)--Thread(Thread[main,5,main])--commit transaction
[EL Finest]: 2012-02-27 08:52:20.392--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connection released to connection pool [default].
[EL Finer]: 2012-02-27 08:52:20.395--UnitOfWork(21006994)--Thread(Thread[main,5,main])--end unit of work commit
[EL Finer]: 2012-02-27 08:52:20.396--UnitOfWork(21006994)--Thread(Thread[main,5,main])--resume unit of work
[EL Finer]: 2012-02-27 08:52:20.398--UnitOfWork(21006994)--Thread(Thread[main,5,main])--initialize identitymaps
[EL Finer]: 2012-02-27 08:52:20.398--UnitOfWork(21006994)--Thread(Thread[main,5,main])--release unit of work
[EL Finer]: 2012-02-27 08:52:20.398--ClientSession(375652924)--Thread(Thread[main,5,main])--client released
[EL Finer]: 2012-02-27 08:52:20.398--ServerSession(55821173)--Thread(Thread[main,5,main])--client acquired: 142515426
[EL Finer]: 2012-02-27 08:52:20.399--ClientSession(142515426)--Thread(Thread[main,5,main])--acquire unit of work: 812498377
[EL Finer]: 2012-02-27 08:52:20.4--UnitOfWork(812498377)--Thread(Thread[main,5,main])--begin unit of work flush
[EL Finer]: 2012-02-27 08:52:20.4--UnitOfWork(812498377)--Thread(Thread[main,5,main])--end unit of work flush
[EL Finest]: 2012-02-27 08:52:20.401--UnitOfWork(812498377)--Thread(Thread[main,5,main])--Execute query ReadAllQuery(name="relationship.getAll" referenceClass=Relationship sql="select r from test.get_relationships() as r")
[EL Finest]: 2012-02-27 08:52:20.401--ServerSession(55821173)--Connection(1742392524)--Thread(Thread[main,5,main])--Connection acquired from connection pool [default].
[EL Finer]: 2012-02-27 08:52:20.401--ClientSession(142515426)--Connection(1742392524)--Thread(Thread[main,5,main])--begin transaction
[EL Fine]: 2012-02-27 08:52:20.402--ClientSession(142515426)--Connection(1742392524)--Thread(Thread[main,5,main])--select r from test.get_relationships() as r
[EL Warning]: 2012-02-27 08:52:20.421--UnitOfWork(812498377)--Thread(Thread[main,5,main])--Local Exception Stack:
Exception [EclipseLink-6044] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.QueryException
=> (1,foo,2))] during the execution of the query was detected to be null. Primary keys must not contain null.
at org.eclipse.persistence.exceptions.QueryException.nullPrimaryKeyInBuildingObject(QueryException.java:895)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:584)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:560)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:717)
at org.eclipse.persistence.queries.ReadAllQuery.registerResultInUnitOfWork(ReadAllQuery.java:769)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:433)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1081)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:844)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1040)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:392)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1128)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2871)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1516)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1498)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1463)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:485)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultList(EJBQueryImpl.java:742)
at test.TestRelationship.testFunction(TestRelationship.java:53)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:35)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:146)
at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:97)
at org.apache.maven.surefire.booter.ProviderFactory$ClassLoaderProxy.invoke(ProviderFactory.java:103)
at $Proxy0.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireStarter.invokeProvider(SurefireStarter.java:145)
at org.apache.maven.surefire.booter.SurefireStarter.runSuitesInProcess(SurefireStarter.java:87)
at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:69)
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.081 sec <<< FAILURE!
Results :
Re: Native Query using function not finding primary key [message #808386 is a reply to message #808321] Mon, 27 February 2012 18:30 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
Executing a native SQL query with a class, requires that the native query returns a result set that matches what the class requires.
The native query you are executing does not appear to return a matching result set.
From the error the row returned is,
ArrayRecord(
=> (1,foo,2))
Which seems to be a result with no column name at all, and the value is some kind of array structure.
What you need to be returned, to be able to map it is,
ArrayRecord(
ID => 1, NAME='foo', inverse=2)
Try something like,
select r.id as ID, r.name as NAME, r.inverse as inverse from test.get_relationships() as r
You could also try executing the SQL through an SQL tool, or with the class and a Map result to see exactly what it returns.
James : Wiki : Book : Blog : Twitter
Re: Native Query using function not finding primary key [message #808409 is a reply to message #808386] Mon, 27 February 2012 18:59 Go to previous message
Your suggestion of:
Fixed the problem. Thanks a million Wink
Previous Topic:Recommended Practise: Consistent Timestamp for Unit of Work
Next Topic:NOT NULL and NOT NULL FK constraints
Current Time: Mon Feb 17 22:37:49 GMT 2020
Powered by FUDForum. Page generated in 0.01981 seconds
