Re: Agent Controller is unavailable under port 10002 [message #97819 is a reply to message #97087] |
Sun, 06 May 2007 04:19 |
Originally posted by: flounder.microsoft.com
I agree with andreas that the feature is confusing, from what I understand
most developers don't need an agent as shouldn't the "integrated agent", or
the "direct connection" be all thats needed for profiling a runtime
instance?
"Andreas Warberg" <andreas@warberg.net> wrote in message
news:c37a250d908ab06ac3539c79035a6269$1@www.eclipse.org...
> All right I found out that you have to install an auxiliary program, the
> Agent Controller, by itself.
> (Btw why don't you provide a simple, step-by-step, howto setup the system?
> This seems to be a general shortcoming for all the eclipse projects I've
> seen so far! Weird...)
> So I did this but having installed the controller I still get errors, this
> time it is:
> Error occurred during initialization of VM
> Could not find agent library on the library path or in the local
> directory: JPIBootLoader
> What is the next step?
> Thank you.
> Regards
> Andreas
Re: Agent Controller is unavailable under port 10002 [message #97988 is a reply to message #97819] |
Mon, 07 May 2007 11:14 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi John,
Yes, the Integrated Agent Controller is sufficient for all local use
cases (e.g. logging, profiling, test execution, etc.). This is covered in
our product documentation:
http://help.eclipse.org/help32/topic/org.eclipse.tptp.platfo rm.agentcontroller.doc.user/concepts/ac/c_ac_ovr.html
Specific to this problem on Vista, I was under the impression that
Andreas was using the Agent Controller. However, I would suggest following
the analogous work-around for the Integrated Agent Controller:
http://www.eclipse.org/tptp/home/downloads/releasenotes/rele asenotes4_3_0.html#3_AC_19
Also, whenever there is an issue with the Integrated Agent Controller,
we like to verify the symptoms by running the same scenario using the Agent
Controller.
Paul
"John Smith" <flounder@microsoft.com> wrote in message
news:f1jkvv$kgk$1@build.eclipse.org...
>instance?
>> system? This seems to be a general shortcoming for all the eclipse
>> projects I've seen so far! Weird...)
>> this time it is:
>> Thank you.
>> Regards
>> Andreas
FUDForum. Page generated in 0.03381 seconds
