AGR - Run several test suites all together [message #96992] |
Wed, 25 April 2007 12:13 |
Originally posted by: sluhay.magenta-technology.ru
Hi All,
I am using TPTP AGR, version 4.3.0. I would like to ask the question
concerning to run several test suites all together.
I have the following folders structure:
Root Folder
Folder 1
TestSuite11.testsuite
TestSuite1N.testsuite
Folder 2
TestSuite21.testsuite
TestSuite2N.testsuite
I create AllTest test suite under Root Folder and add test suites from
Folder 1 and Folder 2 to the behavior section of AllTests test suite. As
a result, I get inconclusive execution verdict in history after
AllTest test suite running.
Does TPTP allow me to run multiple of these consecutively, sort of an
aggregate testsuite so that I dont have to manually kick off each one?
If yes then what does incorrect or missing in my case?
Thanks a lot,
Olesya
Re: AGR - Run several test suites all together [message #97927 is a reply to message #97471] |
Sun, 06 May 2007 14:47 |
Barbara Rosi-Schwartz Messages: 448 Registered: July 2009 |
True in principle, unworkable in practice (or at least it is for me)!...
I tried exactly your
suggestion, Ali, but had to give up on the whole idea due to two
fundamental problems:
1) when I ran the and driver with more than about ten short test
scripts, it kept on failing in the middle complaining of insufficient
heap. Even bringing the heap space up to 1024M did not help;
2) when launching the ant driver, one out of three consecutive times the
driver would fall over at the very beginning of its execution with an
exception, corrupting the workspace.
(Versions used: 4.3.0 of TPTP and 3.2.2 of Eclipse)
So, back to waiting for the AGR bug to be resolved...
Cheerio,
B.
Ali Mehregani wrote:
> Keep in mind that you can use an ANT script to kick start all your test
> suites. To read more about how you can use an ANT script, see the following
> help content:
> Test applications > Test applications > Launching tests from scripts and
> applications
> "Olesya" <sluhay@magenta-technology.ru> wrote in message
> news:dd11150ab94bea7cfe5bbfce125986c9$1@www.eclipse.org...
>> Hi All,
>> Root Folder
>> Folder 1
>> Folder 2
>> I create “AllTest” test suite under Root Folder and add test suites from
>> Folder 1 and Folder 2 to the behavior section of “AllTests” test suite. As
>> a result, I get “inconclusive” execution verdict in history after
>> “AllTest” test suite running.
>> “aggregate testsuite” so that I don’t have to manually kick off each one?
>> If “yes” then what does incorrect or missing in my case?
>> Thanks a lot,
>> Olesya
Re: AGR - Run several test suites all together [message #98529 is a reply to message #97927] |
Mon, 14 May 2007 11:31 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Barbara,
These appear to be defects. Can you open two defects
( https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=T PTP >> TPTP
Testing >> Test.Execution) with any relevant information including your
configuration?
Thanks.
Paul
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:f1kpp9$64l$2@build.eclipse.org...
> True in principle, unworkable in practice (or at least it is for me)!... I
> tried exactly your
> Cheerio,
> B.
>> following help content:
>> applications
>>> Hi All,
>>> Root Folder
>>> Folder 1
FUDForum. Page generated in 0.02094 seconds
