Widget is diposed Exception [message #805288] |
Thu, 23 February 2012 15:36 |
Lucy Sakhnenko Messages: 41 Registered: March 2011 |
Member |
I subclassed the CheckedTreeSelectionDialog to get the selected elements in the form of a tree:
public class MyTreeSelectionDialog extends CheckedTreeSelectionDialog {
public MyTreeSelectionDialog(Shell parent,
ILabelProvider labelProvider, ITreeContentProvider contentProvider) {
super(parent, labelProvider, contentProvider);
protected CheckboxTreeViewer createTreeViewer(Composite parent) {
// TODO Auto-generated method stub
return super.createTreeViewer(parent);
public Map<Object, List<Object>> getCheckedElementsMap() {
Map<Object, List<Object>> mapOfCheckedElements = new HashMap<Object, List<Object>>();
CheckboxTreeViewer checkboxTreeViewer = getTreeViewer();
org.eclipse.swt.widgets.Tree tree = checkboxTreeViewer.getTree();
for (TreeItem level1 : tree.getItems()) {
if (level1.getChecked()) {
List<Object> checkedChildren = new ArrayList<Object>();
for (TreeItem level2 : level1.getItems()) {
if (level2.getChecked()) {
checkedChildren.add(level2);
mapOfCheckedElements.put(level1, checkedChildren);
return mapOfCheckedElements;
But I'm getting the exception:
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Widget is disposed)
at org.eclipse.swt.SWT.error(SWT.java:4282)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.Widget.error(Widget.java:466)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:403)
at org.eclipse.swt.widgets.Tree.getItems(Tree.java:1610)
at myproject.ui.model.MyTreeSelectionDialog.getResult(MyTreeSelectionDialog.java:66)
at altagracia.plugin.popup.actions.ActionbuttonTest$1$2.run(ActionbuttonTest.java:247)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:164)
at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 23 more
The line where the exception occurs is:
Does anybody know what I can do?
Thank you very much for your help!
Re: Widget is diposed Exception [message #805542 is a reply to message #805288] |
Thu, 23 February 2012 22:05 |
Thorsten Meinl Messages: 85 Registered: July 2009 |
Member |
I have seen such errors when you are trying to access widgets when they
are no longer visible (i.e. disposed). Sometimes this is a timing issue
e.g. someone/something disposed the widget while you are still working
on it.
Am 23.02.2012 16:36, schrieb Lucy Mising name:
> contentProvider) {
> @Override
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> ... 23 more
FUDForum. Page generated in 0.01889 seconds
