Re: CompleteOCL errors against UML model. [message #804501 is a reply to message #804476] |
Wed, 22 February 2012 17:45 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi John
When you say 'use' your .ocl file, do you mean using the Java API and
the UML binding (nothing much changed in Juno), or the new neutral pivot
binding that underlies the interactive Xtext editors, Xtext Console, and
Code Generator?
Quite a lot of progress has been made in Juno M5 so that the OCL in the
upcoming UML 2.5 specification can be tool checked.
I'm not confident about use of Association names, qualifiers or profiles
in OCL yet, but other usages should be pretty good.
Can you provide an example that you find unsatisfactory?
Ed Willink
On 22/02/2012 17:13, John Mising name wrote:
> I have tried to use my ocl constraints (.ocl) against my UML model
> using the eclipse Indigo and recently the eclipse Juno M5 with
> OCLTools, but it seems that still contains a lot of errors regarding
> to UML. For instance, all the properties in my model cannot be
> resolved in my ocl constraints...
> Does Anyone know if the OCL binding to UML is completed?
> Regards,
> John
FUDForum. Page generated in 0.03431 seconds
