Home » Eclipse Projects » EclipseLink » stackOverFlowError
stackOverFlowError [message #803823] Tue, 21 February 2012 21:35 Go to next message
Chris V is currently offline Chris VFriend
Getting a stackOverflowError. We support an insurance application that
has several lines of business. Each line of business is in it's own
WAR file while our JPA code is in a utility JAR file. It's all inside
an EAR file.
What I pasted below will probably not be enough info,
so please let me know what else I can provide. Thanks. Chris.
persistence.xml
<persistence xmlns="httpp://java.sun.com/xml/ns/persistence"
xmlns:xsi="httpp://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="httpp://java.sun.com/xml/ns/persistence
httpp://java.sun.com/xml/ns/persistence/persistence_1_0.xsd" version="1.0">
<persistence-unit name="cpsjpa" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<non-jta-data-source>jdbc/Grinnell</non-jta-data-source>
<mapping-file>META-INF/cps-orm.xml</mapping-file>
<class>---------</class>
<exclude-unlisted-classes>true</exclude-unlisted-classes>
<properties>
<property name="eclipselink.target-server" value="WebSphere_7"/>
<property name="eclipselink.target-database" value="DB2"/>
<property name="eclipselink.logging.level" value="FINEST"/>
<property name="eclipselink.logging.file" value="./logs/eclipselink.log"/>
</properties>
</persistence-unit>
</persistence>
Info about class suspected of causing problem:
@Entity
@Table(name = "CP_LOCATION")
@Cache(alwaysRefresh = true)
@SecondaryTable(name = "CP_LOCATION_PKG")
@Converter(name = "boolean", converterClass = com.gmrc.jpa.domain.mappings.converters.BooleanYNConverter.class)
public class CpLocation extends BaseDomain implements Comparable<CpLocation> {
@OneToMany(cascade = CascadeType.ALL, mappedBy = "cpLocation")
@PrivateOwned
private Set<CpBuilding> cpBuildings = new HashSet<CpBuilding>(0);
@PrivateOwned
private Set<CpClassification> cpClassifications = new TreeSet<CpClassification>();
// bi-directional many-to-many association to CpLobs
private Set<CpLobLocation> cpLobLocations = new HashSet<CpLobLocation>(0);
@PrivateOwned
private Set<CpLocationInterestLink> cpLocationInterestLinks = new HashSet<CpLocationInterestLink>();
//Certain Additional Interest Name Types are premium bearing.
//For these, we are creating a coverage on the premise
@PrivateOwned
private Set<CpLocationCoverage> cpLocationCoverages = new HashSet<CpLocationCoverage>(0);
StackTrace:
2012-02-21 14:20:48,786 ERROR com.gmrc.cpp.struts.actions.CppBaseAction (dispatchMethod:973) Dispatch[/Policy/AuditInitiate] to method 'saveTermSelection' returned an exception
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.gmrc.cpp.struts.actions.CppBaseAction.dispatchMethod(CppBaseAction.java:962)
at com.gmrc.cpp.struts.actions.CppBaseAction.execute(CppBaseAction.java:330)
at org.springframework.web.struts.DelegatingActionProxy.execute(DelegatingActionProxy.java:110)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:711)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:831)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1657)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1597)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:131)
at org.ajaxanywhere.AAFilter.doFilter(AAFilter.java:46)
at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:188)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:116)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(WebAppFilterChain.java:77)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:908)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:934)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:502)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:179)
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:91)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:864)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1592)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:186)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:452)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:511)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:305)
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:83)
at com.ibm.ws.tcp.channel.impl.WorkQueueManager.requestComplete(WorkQueueManager.java:557)
at com.ibm.ws.tcp.channel.impl.WorkQueueManager.attemptIO(WorkQueueManager.java:607)
at com.ibm.ws.tcp.channel.impl.WorkQueueManager.workerRun(WorkQueueManager.java:984)
at com.ibm.ws.tcp.channel.impl.WorkQueueManager$Worker.run(WorkQueueManager.java:1069)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1604)
Caused by: java.lang.StackOverflowError
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerExistingObject(UnitOfWorkImpl.java:3864)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerExistingObject(UnitOfWorkImpl.java:3826)
at org.eclipse.persistence.mappings.ObjectReferenceMapping.buildUnitofWorkCloneForPartObject(ObjectReferenceMapping.java:96)
at org.eclipse.persistence.mappings.ObjectReferenceMapping.buildCloneForPartObject(ObjectReferenceMapping.java:70)
at org.eclipse.persistence.internal.indirection.NoIndirectionPolicy.cloneAttribute(NoIndirectionPolicy.java:76)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.buildClone(ForeignReferenceMapping.java:250)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.populateAttributesForClone(ObjectBuilder.java:3285)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.populateAndRegisterObject(UnitOfWorkImpl.java:3622)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.cloneAndRegisterObject(UnitOfWorkImpl.java:987)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.cloneAndRegisterObject(UnitOfWorkImpl.java:916)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerExistingObject(UnitOfWorkImpl.java:3877)
- ********** Looping Code **********
at org.eclipse.persistence.internal.sessions.UnitOfWorkIdentityMapAccessor.getAndCloneCacheKeyFromParent(UnitOfWorkIdentityMapAccessor.java:181)
at org.eclipse.persistence.internal.sessions.UnitOfWorkIdentityMapAccessor.getFromIdentityMap(UnitOfWorkIdentityMapAccessor.java:120)
at org.eclipse.persistence.internal.sessions.IdentityMapAccessor.getFromIdentityMap(IdentityMapAccessor.java:367)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.checkExistence(UnitOfWorkImpl.java:782)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalRegisterObject(UnitOfWorkImpl.java:2879)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerObject(UnitOfWorkImpl.java:4305)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerObject(UnitOfWorkImpl.java:4263)
at org.eclipse.persistence.mappings.CollectionMapping.buildElementUnitOfWorkClone(CollectionMapping.java:267)
at org.eclipse.persistence.mappings.CollectionMapping.buildElementClone(CollectionMapping.java:277)
at org.eclipse.persistence.internal.queries.ContainerPolicy.addNextValueFromIteratorInto(ContainerPolicy.java:210)
at org.eclipse.persistence.mappings.CollectionMapping.buildCloneForPartObject(CollectionMapping.java:203)
at org.eclipse.persistence.internal.indirection.TransparentIndirectionPolicy.cloneAttribute(TransparentIndirectionPolicy.java:149)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.cloneAndRegisterNewObject(RepeatableWriteUnitOfWork.java:571)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalRegisterObject(UnitOfWorkImpl.java:2883)
at org.eclipse.persistence.mappings.ObjectReferenceMapping.buildUnitofWorkCloneForPartObject(ObjectReferenceMapping.java:99)
at org.eclipse.persistence.internal.sessions.MergeManager.registerObjectForMergeCloneIntoWorkingCopy(MergeManager.java:932)
at org.eclipse.persistence.internal.sessions.MergeManager.mergeChangesOfCloneIntoWorkingCopy(MergeManager.java:492)
at org.eclipse.persistence.internal.sessions.MergeManager.mergeChanges(MergeManager.java:263)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.mergeCloneWithReferences(UnitOfWorkImpl.java:3467)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.mergeCloneWithReferences(RepeatableWriteUnitOfWork.java:363)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.mergeCloneWithReferences(UnitOfWorkImpl.java:3427)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.mergeInternal(EntityManagerImpl.java:452)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.merge(EntityManagerImpl.java:429)
at sun.reflect.GeneratedMethodAccessor296.invoke(Unknown Source)
at org.springframework.orm.jpa.SharedEntityManagerCreator$SharedEntityManagerInvocationHandler.invoke(SharedEntityManagerCreator.java:198)
at $Proxy23.merge(Unknown Source)
at com.gmrc.jpa.domain.controller.CpTransactionManagerImpl.update(CpTransactionManagerImpl.java:1171)
at sun.reflect.GeneratedMethodAccessor283.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.springframework.dao.support.PersistenceExceptionTranslationInterceptor.invoke(PersistenceExceptionTranslationInterceptor.java:138)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:106)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy49.update(Unknown Source)
at $Proxy50.update(Unknown Source)
at com.gmrc.cpp.managers.CppPolicyManager.buildAuditTransactions(CppPolicyManager.java:2064)
at com.gmrc.cpp.struts.actions.PolicyAuditAction.saveTermSelection(PolicyAuditAction.java:300)
Re: stackOverFlowError [message #804399 is a reply to message #803823] Wed, 22 February 2012 15:25 Go to previous message
James Sutherland is currently offline James SutherlandFriend
What version are you using, did you try the latest version?
Can you try removing @Cache(alwaysRefresh = true) to see if it is related to the issue.
What is the object you are merging? Is it new or existing. Check that it has a valid id.
Try to isolated the issue by merging simpler objects until you find the object causing the issue.
James : Wiki : Book : Blog : Twitter
Previous Topic:Exception Description: Null primary key encountered in unit of work clone
Next Topic:Can I create database sessions from an external file?
Current Time: Sat Dec 07 00:26:39 GMT 2024
Powered by FUDForum. Page generated in 0.03452 seconds
