Home » Modeling » TMF (Xtext) » referencing other xtext files in standalone execution of IGenerator
referencing other xtext files in standalone execution of IGenerator [message #803564] Tue, 21 February 2012 14:09 Go to next message
Thomas Hergenröder is currently offline Thomas HergenröderFriend
We have created a xtext-dsl that generates JAVA (source-)code.
Our XText-Plugins for this dsl are distributed in the development-team and works fine.
To use our dsl in a project we need a way to generate the Java-Artifacts from the DSL-Modelfile via Maven-Build (we don't want to change the XText-DSL-Plugin-development to Maven).
Right now we have to commit the via Eclipse generated files to SVN.
This way works mostly:
zarnekow.blogspot.com/2010/06/how-to-deploy-xtext-standalone.html
But we have some profile information, in a dsl file on the classpath which is not used when compiling the other files.
Everything works fine if used in eclipse itself.
But not in the maven build.
We have tried to parse the profile information first, but that did not help.
Any help would be appreciated.
Re: referencing other xtext files in standalone execution of IGenerator [message #803843 is a reply to message #803564] Tue, 21 February 2012 22:21 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
how do you read the model file? do you use the org.eclipse.xtext.mwe.Reader workflow component? if yes do you use it with the UseJavaClassPath option set to true
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
icon14.gif  Re: referencing other xtext files in standalone execution of IGenerator [message #805018 is a reply to message #803843] Thu, 23 February 2012 08:52 Go to previous message
Before we did not use org.eclipse.xtext.mwe.Reader.
Now we do - with UseJavaClassPath.
And it works!
Thank you for your help.
Previous Topic:Editor -> Compiler
Next Topic:Integration with GMF Editor
Current Time: Sun May 31 13:49:50 GMT 2020
Powered by FUDForum. Page generated in 0.01948 seconds
