Home » Archived » Visual Editor (VE) » How do you create a Swing GUI application using VE?
How do you create a Swing GUI application using VE? [message #95429] Thu, 30 June 2005 14:55 Go to next message
Will someone show me what is needed to invoke the Java Bean Class build
using VE?
I followed the steps to build the Say Hello Bean class and is able to run
it successfully under Eclipse VE environment via the "Run as Java Bean"
menu item.
But how do I run it outside of the Eclipse envirment, like
java -cp d:\VEDemo; SayHello
Thanks for any info!
JML
Re: How do you create a Swing GUI application using VE? [message #95488 is a reply to message #95429] Thu, 30 June 2005 15:49 Go to previous messageGo to next message
I got it! What I was missing was the setVisible(true) method in the
initialize method.
Somehow the setVisible(true) was not need when invoked under Eclipse run
as Java bean.
jml
Re: How do you create a Swing GUI application using VE? [message #95515 is a reply to message #95488] Thu, 30 June 2005 16:08 Go to previous message
That's because the run as java bean is simply to see how it looks. So it
makes sure it is visible. In fact if it was a JPanel, we would of
created a JFrame to go around it for the run as java bean.
> initialize method.
> as Java bean.
> jml
Rich Kulp
Re: How do you create a Swing GUI application using VE? [message #608132 is a reply to message #95429] Thu, 30 June 2005 15:49 Go to previous message
initialize method.
as Java bean.
jml
Re: How do you create a Swing GUI application using VE? [message #608873 is a reply to message #95488] Thu, 30 June 2005 16:08 Go to previous message
> initialize method.
> as Java bean.
> jml
Rich Kulp
Previous Topic:Create Remote VM for Visual Editor for Java
Next Topic:Start of a data binding framework released--help requested
Current Time: Thu Jul 17 06:21:45 EDT 2025
Powered by FUDForum. Page generated in 0.30271 seconds
