Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo/Hibernate Column Annotation Column
Re: Teneo/Hibernate Column Annotation Column [message #95423 is a reply to message #95247] |
Sun, 02 September 2007 10:01 |
Hi Phaneesh,
The first method you tried did not follow the format (source should be teneo.jpa, key should be
value) as described here:
http://www.elver.org/hibernate/ejb3_format.html
Your second method won't work with Teneo, tou have to set the annotation in the ecore model (or xsd)
or in a separate xml file (see also the link noted above).
gr. Martin
Phaneesh wrote:
> I am trying to use the column annotation to change the length. The attribute
> datatype is EString and the Class that has this attribute is in a
> sub-package. I tried the model annotation. Through the generated code has
> the annotation it is not getting picked up. The column length remains the
> same. I also tries to use the JPA annotation directly on the getter method
> for that attribute. This also has no effect.
> Here is the details of methods that I have tried.
> 1. Model Annotation:
> Source : http://annotation.elver.org/Column
> Key: length
> Value: 500
> In the generated code I see this:
> * Returns the value of the '<em><b>Value</b></em>' attribute.
> * <!-- begin-user-doc -->
> * <p>
> * If the meaning of the '<em>Value</em>' attribute isn't clear,
> * there really should be more of a description here...
> * </p>
> * <!-- end-user-doc -->
> * @return the value of the '<em>Value</em>' attribute.
> * @see #setValue(String)
> * @see
> org.eclipse.hyades.models.common.interactions.Common_Behavio r_InteractionsPackage#getBVRArgument_Value()
> * @model annotation="http://annotation.elver.org/Column length='500'"
> * @generated
> String getValue();
> 2. JPA annotation
> * <p>
> * </p>
> * @see
> @Column(length=500)
> String getValue();
> Both of these methods fail to change the column length. Please help me in
> resolving this issue.
> Regards
> Phaneesh
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo/Hibernate Column Annotation Column [message #95576 is a reply to message #95423] |
Mon, 03 September 2007 03:34 |
Phaneesh Messages: 16 Registered: July 2009 |
Hi Martin,
I tried source=teneo.jpa and value=@Column(length=500) and source=teneo.jpa
appinfo=@Column(length=500) both these have no effect on the teneo created
hibernate mapping file. It does not put the length attribute to the target
column.
The generated model code in both cases:
1. Source=teneo.jpa and value=@Column(length=500)
* <p>
* </p>
* @see
* @model annotation="teneo.jpa value='@Column(length=500)'"
* @generated
String getValue();
2. Source=teneo.jpa and appinfo=@Column(length=500)
* <p>
* </p>
* @see
* @model annotation="teneo.jpa appinfo='@Column(length=500)'"
* @generated
String getValue();
Here is the generated mapping file for the same:
<property name="value" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`VALUE`"/>
</property>
Please tell me if I am missing something.
Phaneesh
"Martin Taal" <mtaal@elver.org> wrote in message
news:fbe1m9$a8q$1@build.eclipse.org...
> Hi Phaneesh,
> teneo.jpa, key should be value) as described here:
> in the ecore model (or xsd) or in a separate xml file (see also the link
> noted above).
> gr. Martin
> Phaneesh wrote:
>> Hi,
>> attribute datatype is EString and the Class that has this attribute is in
>> a sub-package. I tried the model annotation. Through the generated code
>> has the annotation it is not getting picked up. The column length remains
>> the same. I also tries to use the JPA annotation directly on the getter
>> method for that attribute. This also has no effect.
>> Key: length
>> Value: 500
>> * <p>
>> * </p>
>> * @see
>> * @generated
>> String getValue();
>> 2. JPA annotation
>> * <p>
>> * </p>
>> * @see
>> @Column(length=500)
>> String getValue();
>> Regards
>> Phaneesh
> The Netherlands
Re: Teneo/Hibernate Column Annotation Column [message #95617 is a reply to message #95576] |
Mon, 03 September 2007 09:17 |
--------------070501080601070404000102
Hi Phaneesh,
I have attached the ecore file which is used (in Teneo) as a testcase for the column annotation.
This works for Teneo. Can you check if you have specified the annotation in the same way (in the
ecore file or xsd)?
gr. Martin
Phaneesh wrote:
> Hi Martin,
> column.
> * <p>
> * </p>
> * @see
> * @generated
> String getValue();
> * <p>
> * </p>
> * @see
> * @generated
> String getValue();
> </property>
> Regards
> Phaneesh
>> Hi Phaneesh,
>> noted above).
>> gr. Martin
>> Phaneesh wrote:
>>> Hi,
>>> Key: length
>>> Value: 500
>>> * <p>
>>> * </p>
>>> * @see
>>> * @generated
>>> String getValue();
>>> 2. JPA annotation
>>> * <p>
>>> * </p>
>>> * @see
>>> @Column(length=500)
>>> String getValue();
>>> Regards
>>> Phaneesh
>> The Netherlands
The Netherlands
Content-Type: text/xml;
name="column.ecore"
Content-Disposition: inline;
filename="column.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="column"
nsURI=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/col umn" nsPrefix="column">
<eClassifiers xsi:type="ecore:EClass" name="Book">
<eAnnotations source="teneo.jpa">
<details key="appinfo" value="@Table(name="mybooktable")"/>
</eAnnotations>
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="Book"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="title" unique="false" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
<details key="appinfo" value="@Column(name="titel" unique="true" length="25")"/>
</eAnnotations>
<details key="kind" value="element"/>
<details key="name" value="title"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="pages" unique="false" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Int" unsettable="true">
<details key="appinfo" value="@Column(updatable="false" insertable="false")"/>
</eAnnotations>
<details key="name" value="pages"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="weight" unique="false"
lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Decimal">
<details key="appinfo" value="@Column(name="gewicht" nullable="true" precision="5" scale="2")"/>
</eAnnotations>
<details key="name" value="weight"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="author" unique="false"
lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
<details key="name" value="author"/>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
--------------070501080601070404000102--
Re: Teneo/Hibernate Column Annotation Column [message #95747 is a reply to message #95617] |
Mon, 03 September 2007 14:46 |
Hi Martin,
Thanks for the update. I was using a single quote in the annotation.
Instead of @Column(length=500) I was using @Column(length='500').
Now it is working!!. The hibernate mapping file has the length attribute set
to the target column. But, the problem now is the schema is not getting
updated.
I have hibernate.hbm2ddl.auto = update in hbernate configuration, and in
teneo config I have set teneo.runtime.update_schema=true. But the table is
not getting updated in the database. I am using oracle 10 database. If I
change the hibernate.hbm2ddl.auto to create and then run it on a new schema
the column length is set to the desired value. May be there is a sync issue.
Please tell me whether I have set any other option in teneo?
Phaneesh
news:fbgjf0$snn$1@build.eclipse.org...
> Hi Phaneesh,
> ecore file or xsd)?
> gr. Martin
> Phaneesh wrote:
>> Hi Martin,
>> source=teneo.jpa
>> created
>> target
>> column.
>> * <p>
>> * </p>
>> * @see
>> * @generated
>> String getValue();
>> * <p>
>> * </p>
>> * @see
>> * @generated
>> String getValue();
>> </property>
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> noted above).
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> in
>>>> remains
>>>> Key: length
>>>> Value: 500
>>>> * <p>
>>>> * </p>
>>>> * @see
>>>> * @generated
>>>> String getValue();
>>>> 2. JPA annotation
>>>> * <p>
>>>> * </p>
>>>> * @see
>>>> @Column(length=500)
>>>> String getValue();
>>>> in
>>>> Regards
>>>> Phaneesh
>>> The Netherlands
> The Netherlands
> nsPrefix="column">
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
Re: Teneo/Hibernate Column Annotation Column [message #95781 is a reply to message #95747] |
Mon, 03 September 2007 17:48 |
Hi Phaneesh
I don't think that this has to do with Teneo but more with how hibernate updates the schema. For
example my experience is that new indexes are also only added in a create mode. So it seems to be a
hibernate 'feature'.
gr. Martin
Phaneesh wrote:
> Hi Martin,
> updated.
> Regards
> Phaneesh
>> Hi Phaneesh,
>> ecore file or xsd)?
>> gr. Martin
>> Phaneesh wrote:
>>> Hi Martin,
>>> source=teneo.jpa
>>> created
>>> target
>>> column.
>>> * <p>
>>> * </p>
>>> * @see
>>> * @generated
>>> String getValue();
>>> * <p>
>>> * </p>
>>> * @see
>>> * @generated
>>> String getValue();
>>> </property>
>>> Regards
>>> Phaneesh
>>>> Hi Phaneesh,
>>>> noted above).
>>>> gr. Martin
>>>> Phaneesh wrote:
>>>>> Hi,
>>>>> in
>>>>> remains
>>>>> Key: length
>>>>> Value: 500
>>>>> * <p>
>>>>> * </p>
>>>>> * @see
>>>>> * @generated
>>>>> String getValue();
>>>>> 2. JPA annotation
>>>>> * <p>
>>>>> * </p>
>>>>> * @see
>>>>> @Column(length=500)
>>>>> String getValue();
>>>>> in
>>>>> Regards
>>>>> Phaneesh
>>>> The Netherlands
>> The Netherlands
>> <?xml version="1.0" encoding="UTF-8"?>
>> nsPrefix="column">
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
The Netherlands
Re: Teneo/Hibernate Column Annotation Column [message #95797 is a reply to message #95781] |
Tue, 04 September 2007 03:30 |
Hi Martin,
Thanks for the info. Infact the hibernate schema updates happens only for
new objects that gets added and for new/changed relationships. Hibernate FAQ
itself says schema update tool comes with no warranties. Here is the link
which gives more info on Hibernate SchemaUpdate Tool.
http://www.hibernate.org/119.html#A9
Once again thanks for all the help. My life would have been a real hell
without without Teneo. Teneo really rocks!!
Phaneesh
news:fbhhe0$rr6$1@build.eclipse.org...
> Hi Phaneesh
> updates the schema. For example my experience is that new indexes are also
> only added in a create mode. So it seems to be a hibernate 'feature'.
> gr. Martin
> Phaneesh wrote:
>> Hi Martin,
>> set to the target column. But, the problem now is the schema is not
>> getting updated.
>> is not getting updated in the database. I am using oracle 10 database. If
>> I change the hibernate.hbm2ddl.auto to create and then run it on a new
>> schema the column length is set to the desired value. May be there is a
>> sync issue. Please tell me whether I have set any other option in teneo?
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> ecore file or xsd)?
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi Martin,
>>>> source=teneo.jpa
>>>> created
>>>> target
>>>> column.
>>>> * <p>
>>>> * </p>
>>>> * @see
>>>> * @generated
>>>> String getValue();
>>>> * <p>
>>>> * </p>
>>>> * @see
>>>> * @generated
>>>> String getValue();
>>>> </property>
>>>> Regards
>>>> Phaneesh
>>>>> Hi Phaneesh,
>>>>> annotation
>>>>> link
>>>>> noted above).
>>>>> gr. Martin
>>>>> Phaneesh wrote:
>>>>>> Hi,
>>>>>> is in
>>>>>> code
>>>>>> remains
>>>>>> getter
>>>>>> Key: length
>>>>>> Value: 500
>>>>>> * <p>
>>>>>> * </p>
>>>>>> * @see
>>>>>> length='500'"
>>>>>> * @generated
>>>>>> String getValue();
>>>>>> 2. JPA annotation
>>>>>> * <p>
>>>>>> * </p>
>>>>>> * @see
>>>>>> @Column(length=500)
>>>>>> String getValue();
>>>>>> me in
>>>>>> Regards
>>>>>> Phaneesh
>>>>> The Netherlands
>>> The Netherlands
>>> nsPrefix="column">
>>> </eAnnotations>
>>> <eAnnotations
>>> </eAnnotations>
>>> </eAnnotations>
>>> <eAnnotations
>>> </eAnnotations>
>>> </eAnnotations>
>>> <eAnnotations
>>> </eAnnotations>
>>> unique="false"
>>> scale="2")"/>
>>> </eAnnotations>
>>> <eAnnotations
>>> </eAnnotations>
>>> unique="false"
>>> <eAnnotations
>>> </eAnnotations>
>>> </eClassifiers>
>>> </ecore:EPackage>
> The Netherlands
Re: Teneo/Hibernate Column Annotation Column [message #609615 is a reply to message #95247] |
Hi Phaneesh,
gr. Martin
Phaneesh wrote:
> Key: length
> Value: 500
> * <p>
> * </p>
> * @see
> * @generated
> String getValue();
> 2. JPA annotation
> * <p>
> * </p>
> * @see
> @Column(length=500)
> String getValue();
> Regards
> Phaneesh
The Netherlands
Re: Teneo/Hibernate Column Annotation Column [message #609625 is a reply to message #95423] |
Hi Martin,
column.
* <p>
* </p>
* @see
* @generated
String getValue();
* <p>
* </p>
* @see
* @generated
String getValue();
</property>
Phaneesh
> Hi Phaneesh,
> noted above).
> gr. Martin
> Phaneesh wrote:
>> Hi,
>> Key: length
>> Value: 500
>> * <p>
>> * </p>
>> * @see
>> * @generated
>> String getValue();
>> 2. JPA annotation
>> * <p>
>> * </p>
>> * @see
>> @Column(length=500)
>> String getValue();
>> Regards
>> Phaneesh
> The Netherlands
Re: Teneo/Hibernate Column Annotation Column [message #609627 is a reply to message #95576] |
Hi Phaneesh,
ecore file or xsd)?
gr. Martin
Phaneesh wrote:
> Hi Martin,
> column.
> * <p>
> * </p>
> * @see
> * @generated
> String getValue();
> * <p>
> * </p>
> * @see
> * @generated
> String getValue();
> </property>
> Regards
> Phaneesh
>> Hi Phaneesh,
>> noted above).
>> gr. Martin
>> Phaneesh wrote:
>>> Hi,
>>> Key: length
>>> Value: 500
>>> * <p>
>>> * </p>
>>> * @see
>>> * @generated
>>> String getValue();
>>> 2. JPA annotation
>>> * <p>
>>> * </p>
>>> * @see
>>> @Column(length=500)
>>> String getValue();
>>> Regards
>>> Phaneesh
>> The Netherlands
The Netherlands
name="column.ecore"
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: Teneo/Hibernate Column Annotation Column [message #609634 is a reply to message #95617] |
Hi Martin,
updated.
Phaneesh
> Hi Phaneesh,
> ecore file or xsd)?
> gr. Martin
> Phaneesh wrote:
>> Hi Martin,
>> source=teneo.jpa
>> created
>> target
>> column.
>> * <p>
>> * </p>
>> * @see
>> * @generated
>> String getValue();
>> * <p>
>> * </p>
>> * @see
>> * @generated
>> String getValue();
>> </property>
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> noted above).
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> in
>>>> remains
>>>> Key: length
>>>> Value: 500
>>>> * <p>
>>>> * </p>
>>>> * @see
>>>> * @generated
>>>> String getValue();
>>>> 2. JPA annotation
>>>> * <p>
>>>> * </p>
>>>> * @see
>>>> @Column(length=500)
>>>> String getValue();
>>>> in
>>>> Regards
>>>> Phaneesh
>>> The Netherlands
> The Netherlands
> nsPrefix="column">
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
Re: Teneo/Hibernate Column Annotation Column [message #609636 is a reply to message #95747] |
Hi Phaneesh
gr. Martin
Phaneesh wrote:
> Hi Martin,
> updated.
> Regards
> Phaneesh
>> Hi Phaneesh,
>> ecore file or xsd)?
>> gr. Martin
>> Phaneesh wrote:
>>> Hi Martin,
>>> source=teneo.jpa
>>> created
>>> target
>>> column.
>>> * <p>
>>> * </p>
>>> * @see
>>> * @generated
>>> String getValue();
>>> * <p>
>>> * </p>
>>> * @see
>>> * @generated
>>> String getValue();
>>> </property>
>>> Regards
>>> Phaneesh
>>>> Hi Phaneesh,
>>>> noted above).
>>>> gr. Martin
>>>> Phaneesh wrote:
>>>>> Hi,
>>>>> in
>>>>> remains
>>>>> Key: length
>>>>> Value: 500
>>>>> * <p>
>>>>> * </p>
>>>>> * @see
>>>>> * @generated
>>>>> String getValue();
>>>>> 2. JPA annotation
>>>>> * <p>
>>>>> * </p>
>>>>> * @see
>>>>> @Column(length=500)
>>>>> String getValue();
>>>>> in
>>>>> Regards
>>>>> Phaneesh
>>>> The Netherlands
>> The Netherlands
>> nsPrefix="column">
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> </eAnnotations>
>> <eAnnotations
>> </eAnnotations>
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
The Netherlands
Re: Teneo/Hibernate Column Annotation Column [message #609637 is a reply to message #95781] |
Hi Martin,
Phaneesh
> Hi Phaneesh
> gr. Martin
> Phaneesh wrote:
>> Hi Martin,
>> getting updated.
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> ecore file or xsd)?
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi Martin,
>>>> source=teneo.jpa
>>>> created
>>>> target
>>>> column.
>>>> * <p>
>>>> * </p>
>>>> * @see
>>>> * @generated
>>>> String getValue();
>>>> * <p>
>>>> * </p>
>>>> * @see
>>>> * @generated
>>>> String getValue();
>>>> </property>
>>>> Regards
>>>> Phaneesh
>>>>> Hi Phaneesh,
>>>>> annotation
>>>>> link
>>>>> noted above).
>>>>> gr. Martin
>>>>> Phaneesh wrote:
>>>>>> Hi,
>>>>>> is in
>>>>>> code
>>>>>> remains
>>>>>> getter
>>>>>> Key: length
>>>>>> Value: 500
>>>>>> * <p>
>>>>>> * </p>
>>>>>> * @see
>>>>>> length='500'"
>>>>>> * @generated
>>>>>> String getValue();
>>>>>> 2. JPA annotation
>>>>>> * <p>
>>>>>> * </p>
>>>>>> * @see
>>>>>> @Column(length=500)
>>>>>> String getValue();
>>>>>> me in
>>>>>> Regards
>>>>>> Phaneesh
>>>>> The Netherlands
>>> The Netherlands
>>> nsPrefix="column">
>>> </eAnnotations>
>>> <eAnnotations
>>> </eAnnotations>
>>> </eAnnotations>
>>> <eAnnotations
>>> </eAnnotations>
>>> </eAnnotations>
>>> <eAnnotations
>>> </eAnnotations>
>>> unique="false"
>>> scale="2")"/>
>>> </eAnnotations>
>>> <eAnnotations
>>> </eAnnotations>
>>> unique="false"
>>> <eAnnotations
>>> </eAnnotations>
>>> </eClassifiers>
>>> </ecore:EPackage>
> The Netherlands
Current Time: Thu Apr 18 11:53:21 GMT 2024
Powered by FUDForum. Page generated in 0.02646 seconds
