A time-out occurred while attempting to launch the process [message #95228] |
Tue, 10 April 2007 17:13 |
Originally posted by: ronkinney.gmail.com
I am trying to use any of the analysis provided under the Java Profiling
with Instrumentation on a rather large application. However, whenever I
click on the profile, the progress bar gets stuck on 78% for about 55
seconds before I get the following warning message. Even though this is
a warning, the profiling stops.
One of the selected launch delegates has failed. The operation will
continue
Reason:
Details>>
org.eclipse.core.runtime.CoreException
org.eclipse.core.runtime.CoreException: A A time-out occurred while
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherhUt ility.createCoreException(LauncherUtility.java:133)
Window->Preferences->Profiling and Logging->Hosts->Test Connection on
both localhost:10002 and localhost:10006 are successful.
Run->Profile...->Monitor->Java Profiling with Instrumentation->Test
Availability is successful too.
For the record, whenever I profile a small "Hello World" application,
everything seems to work. Its only on this larger server application
that the timeouts occur. Is there some kind of timeout value I can
increase or a log I can look at for more information on the timeout?
Re: A time-out occurred while attempting to launch the process [message #95481 is a reply to message #95466] |
Wed, 11 April 2007 21:56 |
Thanks Asaf. I'm in the process of trying that now. I am partially
confused on the downloads on the Development - 4.4.0 page for both the
stable build and development build, though :
http://www.eclipse.org/tptp/home/downloads/?buildId=TPTP-4.4 .0-200703270100D
http://www.eclipse.org/tptp/home/downloads/?buildId=TPTP-4.4 .0-200704092245
The "New Java Profiler" previously had a jvmti-client-TPTP download for
4.3.1. Where can I find the jvmti-client-TPTP download for 4.4? I
don't see a link on the download page.
The "New Technology Agent Controller" only has downloads for
Linux-EM64T and Linux-IPF. Each of those archives didn't contain
anything in the bin directory either -- just a readme.txt that didn't
help. Where's Linux IA-32?
Lastly, the Eclipse Web Tools Platform (WTP) 2.0 download link is broken.
Asaf Yaffe wrote:
> Ron,
> Please try using the latest 4.4 version (TPTP client and Agent
> Controller). Note that this version works only with Eclipse 3.3 (latest
> version is 3.3M6) and EMF 2.3. Most of the problems you describe were
> addressed. There are still issues with profiling large Java
> applications. These can be avoided by carefully defining profiling
> filters that will include only the classes/packages you care about.
> HTH,
> Asaf
FUDForum. Page generated in 0.02072 seconds
