Re: .odp and .odt formats gives exception [message #801014 is a reply to message #800555] |
Fri, 17 February 2012 20:22 |
Can you post your code?
Jason
On 2/17/2012 3:06 AM, Deepali Patil wrote:
> Hello,
> When I am trying to generate report in ODT and ODP format it gives me
> list of exception as below. Generated reports has no problem but
> exception are displayed on console while generating these reports. I
> have copied the below jars but still the problem persists.
> org.eclipse.birt.report.engine.emitter.odp.config_3.7.0.v20110602.jar
> org.eclipse.birt.report.engine.emitter.odp_3.7.0.v20110602.jar
> org.eclipse.birt.report.engine.emitter.ods.config_3.7.0.v20110602.jar
> org.eclipse.birt.report.engine.emitter.ods_3.7.0.v20110602.jar
> org.eclipse.birt.report.engine.emitter.odt.config_3.7.0.v20110602.jar
> org.eclipse.birt.report.engine.emitter.odt_3.7.0.v20110602.jar
> Please suggest how to resolve the below exceptions.
> Feb 17, 2012 12:34:43 PM
> org.eclipse.birt.report.engine.odf.AbstractOdfEmitter save
> SEVERE: Stream closed
> java.io.IOException: Stream closed
> at java.util.zip.ZipOutputStream.ensureOpen(Unknown Source)
> at java.util.zip.ZipOutputStream.closeEntry(Unknown Source)
> at
> org.eclipse.birt.report.engine.odf.pkg.Package.writeManifest(Package.java:188)
> at org.eclipse.birt.report.engine.odf.pkg.Package.close(Package.java:120)
> at
> org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.save(AbstractOdfEmitter.java:166)
> at
> org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.end(AbstractOdfEmitter.java:143)
> at
> org.eclipse.birt.report.engine.emitter.odt.OdtEmitter.end(OdtEmitter.java:602)
> at
> org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.end(CompositeContentEmitter.java:65)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:182)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
> at
> com.sneengineers.wims.reportGeneration.ReportCreation.main(ReportCreation.java:57)
> Deepali.
Re: .odp and .odt formats gives exception [message #804382 is a reply to message #804011] |
Wed, 22 February 2012 15:08 |
Is it possible in your app that two threads are writing to the same
output file?
Jason
On 2/21/2012 11:48 PM, Deepali Patil wrote:
> Thanks for the reply,
> I added task.close() in my code but exception still occurs for odp and
> odf format.
> Please suggest something which resolve this exception.
> Feb 22, 2012 10:10:44 AM
> org.eclipse.birt.report.engine.emitter.odp.OdpEmitter save
> at
> at
> org.eclipse.birt.report.engine.emitter.odp.OdpEmitter.save(OdpEmitter.java:87)
> at
> org.eclipse.birt.report.engine.emitter.odp.OdpEmitter.end(OdpEmitter.java:63)
> at
> org.eclipse.birt.report.engine.nLayout.LayoutEngine.end(LayoutEngine.java:345)
> at
> at
> at
> at
> com.sne.reportRunner.reportCreator.ReportGeneratorImpl.generateReport(ReportGeneratorImpl.java:95)
> at
> com.sne.reportRunner.reportCreator.ReportGeneratorImplTest.testThatReportInExcelFormatFileIsGenerated(ReportGeneratorImplTest.java:83)
> at
> org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
> at
> org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
> at
> org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
> at
> org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
> at
> org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
> at
> org.springframework.test.context.junit4.statements.RunBeforeTestMethodCallbacks.evaluate(RunBeforeTestMethodCallbacks.java:74)
> at
> org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
> at
> org.springframework.test.context.junit4.statements.RunAfterTestMethodCallbacks.evaluate(RunAfterTestMethodCallbacks.java:82)
> at
> org.springframework.test.context.junit4.statements.SpringRepeat.evaluate(SpringRepeat.java:72)
> at
> org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:231)
> at
> org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
> at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
> at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
> at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
> at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
> at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
> at
> org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:61)
> at
> org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70)
> at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
> at
> org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:174)
> at
> org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:46)
> at
> org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
> at
> org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
> Deepali.
Re: .odp and .odt formats gives exception [message #804511 is a reply to message #804485] |
Wed, 22 February 2012 18:07 |
Can you reproduce the issue with a command line app that I can run?
Jason
On 2/22/2012 12:27 PM, Deepali Patil wrote:
> Thanks for reply,
> I am generating output report with generating random file name,
> therefore no possibility of writing to the same output report file.
> final String outputFile = outputFileNameGenerator.getOutputFileNameFor(
> Integer.toString(reportId) + "." + outputFormat);
> I am not getting where I am going wrong.
> Please help me to sort out this exception.
> Thanks, Deepali.
Re: .odp and .odt formats gives exception [message #808385 is a reply to message #804930] |
Mon, 27 February 2012 18:25 |
I just opened a bug for this. It appears to be an issue in 3.7.1 and 3.7.2.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=372671
Jason
On 2/23/2012 1:38 AM, Deepali Patil wrote:
> I have attached an application which creates a report which you can run through command line.
> This application is created using maven.
> Changes that you need to do to run the application.
> 1) In pom.xml set<birt.runtime.location> to the lib of ReportEngine.
> Run the application on command prompt using maven. On command prompt go to the folder where you have copied attached files. Run the below command
> report-runner>mvn clean eclipse:clean eclipse:eclipse install
> It will build successful but with exception.
> Please go through my code.
> Deepali.
FUDForum. Page generated in 0.04216 seconds
