Re: model.di is empty [message #800572 is a reply to message #800293] |
Fri, 17 February 2012 08:30 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Hello Francois,
It is possible to import a UML Model into Papyrus. It won't restore your diagrams, though. For most models, you can easily recreate a Diagram from importing a UML model and drag & droping elements from the ModelExplorer. However, I think there are undroppable elements in the sequence diagram... So this solution won't really work.
If the .di file is the only empty one, and if you're familiar with the xmi syntax, you can try to create a whole new Model, then replace the .notation and .uml files with your own. Don't forget to edit the Xmi ID in your new .di file, so that it can find your diagram(s).
Camille
Camille Letavernier
FUDForum. Page generated in 0.03029 seconds
