Re: Erroneous Handlers - BIRT 3.7.1 [message #800192 is a reply to message #799822] |
Thu, 16 February 2012 20:01 |
Did you remove all the jars that were in the 2.6.1 reportengine/lib
directory from your classpath. BTW if this is a on a windows machine
this might be creating a classpath string that is to long. To test this
create a directory off of the c drive like c:/birtlib and move all the
jars from C:/birt-runtime-3_7_1/ReportEngine/lib to this new directory.
Then change your BIRTENGINE variable.
Jason
On 2/16/2012 6:03 AM, Sravan Kumar wrote:
> I have removed old jar files from my lib directory (js.jar,
> commons-cli-1.0.jar and engineapi.jar) and copied
> org.eclipse.birt.runtime_3.7.1.v20110913-1734.jar
Re: Erroneous Handlers - BIRT 3.7.1 [message #801008 is a reply to message #800787] |
Fri, 17 February 2012 20:10 |
Is this a web app that you are calling the report engine from or a
command line app?
Jason
On 2/17/2012 8:49 AM, Sravan Kumar wrote:
> Hi Jason,
> Thanks for your response. I have removed all the 2.6.1 jars and then I
> have added 3.7.1 jars in my application lib directory, I was getting the
> error "The input line is too long." like you have mentioned, on Windows XP.
> But when I was referring the jars from
> C:/birt-runtime-3_7_1/ReportEngine/lib directory I was not getting this
> error but I was getting the error I have specified in my first post.
> So please clarify me how it is going to help me if I copy the jars to
> some external directory like c:/birtlib, is it just reducing the length
> of the path or even the BIRT engine interpretation of the jars as it was
> outside the BIRT_HOME (though I did not set it now) because my
> application has lot many other jars in its classpath.
> Sravan
FUDForum. Page generated in 0.03261 seconds
