Error w/Spring 3.1.0.RELEASE in repository/usr w/Virgo Tomcat 3.5.0.M02 [message #799413] |
Wed, 15 February 2012 21:26 |
Hi all,
Just downloaded Virgo Tomcat 3.5.0.M02, copied spring library jars into repository/usr, started virgo, and got the following error (after working around the issue I described at http://www.eclipse.org/forums/index.php/mv/msg/277347/799402/#msg_799402 ). I thought the version of Spring in the user region wouldn't conflict with that in the kernel region -- at least that's what it says at
http://wiki.eclipse.org/Virgo/FAQ#How_can_I_change_the_version_of_Spring_framework_in_the_user_region.3F
I did report bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=357273
which says it's fixed in the 3.5.0 line. Anyone know what's up?
Command line output:
C:\virgo\virgo-tomcat-server-3.5.0.M02\bin>startup -clean
WARNING: jmxPermissions.vbs did not update the permissions of C:\virgo\VIRGO-~1.M02\config\org.eclipse.virgo.kernel.jmxremote.access.properties. Check the file has the correct permissions.
[2012-02-15 15:18:25.064] startup-tracker <KE0001I> Kernel starting.
[2012-02-15 15:18:28.013] startup-tracker <KE0002I> Kernel started.
[2012-02-15 15:18:28.285] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '3.0.0'.
[2012-02-15 15:18:30.103] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2012-02-15 15:18:30.639] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2012-02-15 15:18:30.784] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2012-02-15 15:18:30.913] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '3.5.0.M02'.
[2012-02-15 15:18:30.972] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '3.5.0.M02'.
[2012-02-15 15:18:31.440] system-artifacts <DE0000I> Installing bundle 'org.eclipse.equinox.ds' version '1.3.0.v20110124-0830'.
[2012-02-15 15:18:31.800] system-artifacts <DE0000I> Installing bundle 'org.eclipse.equinox.util' version '1.0.200.v20100503'.
[2012-02-15 15:18:31.814] system-artifacts <DE0000I> Installing configuration 'osgi.console' version '0.0.0'.
[2012-02-15 15:18:32.987] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2012-02-15 15:18:32.988] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2012-02-15 15:18:32.990] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2012-02-15 15:18:32.991] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '3.5.0.M02'.
[2012-02-15 15:18:32.993] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '3.5.0.M02'.
[2012-02-15 15:18:32.994] system-artifacts <DE0001I> Installed bundle 'org.eclipse.equinox.ds' version '1.3.0.v20110124-0830'.
[2012-02-15 15:18:32.997] system-artifacts <DE0001I> Installed bundle 'org.eclipse.equinox.util' version '1.0.200.v20100503'.
[2012-02-15 15:18:32.998] system-artifacts <DE0001I> Installed configuration 'osgi.console' version '0.0.0'.
[2012-02-15 15:18:32.999] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '3.0.0'.
[2012-02-15 15:18:33.039] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '3.0.0'.
[2012-02-15 15:18:33.046] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2012-02-15 15:18:33.050] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2012-02-15 15:18:33.051] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2012-02-15 15:18:33.612] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2012-02-15 15:18:33.613] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2012-02-15 15:18:33.616] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2012-02-15 15:18:33.617] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '3.5.0.M02'.
[2012-02-15 15:18:33.620] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '3.5.0.M02'.
[2012-02-15 15:18:33.623] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '3.5.0.M02'.
[2012-02-15 15:18:33.644] system-artifacts <DE0004I> Starting bundle 'org.eclipse.equinox.ds' version '1.3.0.v20110124-0830'.
[2012-02-15 15:18:33.769] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.equinox.ds' version '1.3.0.v20110124-0830'.
[2012-02-15 15:18:33.770] system-artifacts <DE0004I> Starting bundle 'org.eclipse.equinox.util' version '1.0.200.v20100503'.
[2012-02-15 15:18:33.788] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '3.5.0.M02'.
[2012-02-15 15:18:33.791] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.equinox.util' version '1.0.200.v20100503'.
[2012-02-15 15:18:33.791] system-artifacts <DE0004I> Starting configuration 'osgi.console' version '0.0.0'.
[2012-02-15 15:18:33.833] system-artifacts <DE0005I> Started configuration 'osgi.console' version '0.0.0'.
[2012-02-15 15:18:33.834] system-artifacts <DE0005I> Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '3.0.0'.
[2012-02-15 15:18:33.963] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2012-02-15 15:18:33.973] system-artifacts <DE0000I> Installing configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2012-02-15 15:18:34.382] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.core' version '2.1.0.BUILD-20120114220114'.
[2012-02-15 15:18:34.718] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.tomcat' version '2.1.0.BUILD-20120114220114'.
[2012-02-15 15:18:34.838] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.core' version '3.5.0.M02'.
[2012-02-15 15:18:34.870] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.dm' version '3.5.0.M02'.
[2012-02-15 15:18:34.959] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.tomcat.support' version '3.5.0.M02'.
[2012-02-15 15:18:35.282] system-artifacts <DE0001I> Installed configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2012-02-15 15:18:35.284] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.core' version '2.1.0.BUILD-20120114220114'.
[2012-02-15 15:18:35.285] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.tomcat' version '2.1.0.BUILD-20120114220114'.
[2012-02-15 15:18:35.287] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.core' version '3.5.0.M02'.
[2012-02-15 15:18:35.288] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.dm' version '3.5.0.M02'.
[2012-02-15 15:18:35.290] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.tomcat.support' version '3.5.0.M02'.
[2012-02-15 15:18:35.291] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2012-02-15 15:18:35.318] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2012-02-15 15:18:35.319] system-artifacts <DE0004I> Starting configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2012-02-15 15:18:35.365] system-artifacts <DE0005I> Started configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2012-02-15 15:18:35.367] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.core' version '2.1.0.BUILD-20120114220114'.
[2012-02-15 15:18:35.396] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.web.core' version '2.1.0.BUILD-20120114220114'.
[2012-02-15 15:18:35.399] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.tomcat' version '2.1.0.BUILD-20120114220114'.
[2012-02-15 15:18:35.908] system-artifacts <TC0000I> Starting Tomcat.
[2012-02-15 15:18:35.937] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme http on port 8080.
[2012-02-15 15:18:35.947] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme https on port 8443.
[2012-02-15 15:18:35.952] system-artifacts <TC0010I> Creating AJP/1.3 connector with scheme http on port 8009.
[2012-02-15 15:18:35.957] system-artifacts <TC0001I> Started Tomcat.
[2012-02-15 15:18:35.976] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.core' version '3.5.0.M02'.
[2012-02-15 15:18:35.984] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.dm' version '3.5.0.M02'.
[2012-02-15 15:18:35.987] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.web.dm' version '3.5.0.M02'.
[2012-02-15 15:18:35.988] system-artifacts <DE0005I> Started bundle 'org.eclipse.virgo.web.tomcat.support' version '3.5.0.M02'.
[2012-02-15 15:18:36.107] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.web.tomcat' version '2.1.0.BUILD-20120114220114'.
[2012-02-15 15:18:36.124] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.web.core' version '3.5.0.M02'.
[2012-02-15 15:18:36.126] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2012-02-15 15:18:36.136] sync Event Dispatcher Thread <UR0001I> User region ready.
[2012-02-15 15:18:37.141] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.admin_3.5.0.M02.plan'.
[2012-02-15 15:18:37.289] fs-watcher <DE0000I> Installing plan 'org.eclipse.virgo.apps.admin.plan' version '3.0.0'.
[2012-02-15 15:18:37.516] fs-watcher <DE0000I> Installing bundle 'org.eclipse.virgo.apps.admin.core' version '3.5.0.M02'.
[2012-02-15 15:18:45.511] fs-watcher <DE0000I> Installing bundle 'org.eclipse.virgo.apps.admin.web' version '3.5.0.M02'.
[2012-02-15 15:18:47.609] fs-watcher <ME0003I> Dump 'serviceability\dump\2012-02-15-15-18-610' generated
[2012-02-15 15:18:47.714] fs-watcher <DE0002E> Installation of plan 'org.eclipse.virgo.apps.admin.plan' version '3.0.0' failed. org.eclipse.virgo.kernel.osgi.framework.UnableToS
atisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'org.eclipse.virgo.apps.admin.web' at version '3.5.0.M02': Cannot resolve: org.eclipse.virgo.apps.admin.web
Resolver report:
Uses violation: <Import-Package: org.eclipse.virgo.web.dm; version="[3.5.0,4.0.0)"> in bundle <org.eclipse.virgo.apps.admin.web_3.5.0.M02[1329340717289]>
Found conflicts:
package 'org.springframework.asm_3.1.0.RELEASE' in bundle 'org.springframework.asm_3.1.0.RELEASE[90]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.eclipse.vi
rgo.web.dm_3.5.0.M02[103]'
conflicts with 'org.springframework.asm_3.0.5.RELEASE' in bundle 'org.springframework.asm_3.0.5.RELEASE[1329340717404]' used by 'org.springframework.web.servlet.support_3.0.5.RELE
ASE' in bundle 'org.springframework.web.servlet_3.0.5.RELEASE[1329340717290]'
package 'org.springframework.context.support_3.1.0.RELEASE' in bundle 'org.springframework.context_3.1.0.RELEASE[92]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle
'org.eclipse.virgo.web.dm_3.5.0.M02[103]'
conflicts with 'org.springframework.context.support_3.0.5.RELEASE' in bundle 'org.springframework.context_3.0.5.RELEASE[1329340717344]' used by 'org.springframework.web.servlet.su
pport_3.0.5.RELEASE' in bundle 'org.springframework.web.servlet_3.0.5.RELEASE[1329340717290]'
package 'org.springframework.core_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[93]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.eclipse.
conflicts with 'org.springframework.core_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[1329340717395]' used by 'org.springframework.web.servlet.support_3.0.5.RE
package 'org.springframework.ui.context_3.1.0.RELEASE' in bundle 'org.springframework.context_3.1.0.RELEASE[92]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org
conflicts with 'org.springframework.ui.context_3.0.5.RELEASE' in bundle 'org.springframework.context_3.0.5.RELEASE[1329340717344]' used by 'org.springframework.web.servlet.support
package 'org.springframework.beans.support_3.1.0.RELEASE' in bundle 'org.springframework.beans_3.1.0.RELEASE[91]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'or
conflicts with 'org.springframework.beans.support_3.0.5.RELEASE' in bundle 'org.springframework.beans_3.0.5.RELEASE[1329340717347]' used by 'org.springframework.web.servlet.suppor
package 'org.springframework.core.io_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[93]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.eclip
conflicts with 'org.springframework.core.io_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[1329340717395]' used by 'org.springframework.web.servlet.support_3.0.5
package 'org.springframework.beans.factory.xml_3.1.0.RELEASE' in bundle 'org.springframework.beans_3.1.0.RELEASE[91]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle
conflicts with 'org.springframework.beans.factory.xml_3.0.5.RELEASE' in bundle 'org.springframework.beans_3.0.5.RELEASE[1329340717347]' used by 'org.springframework.web.servlet.su
package 'org.springframework.core.io.support_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[93]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'o
conflicts with 'org.springframework.core.io.support_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[1329340717395]' used by 'org.springframework.web.servlet.suppo
package 'org.springframework.context.event_3.1.0.RELEASE' in bundle 'org.springframework.context_3.1.0.RELEASE[92]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle '
conflicts with 'org.springframework.context.event_3.0.5.RELEASE' in bundle 'org.springframework.context_3.0.5.RELEASE[1329340717344]' used by 'org.springframework.web.servlet_3.0.
package 'org.springframework.asm.commons_3.1.0.RELEASE' in bundle 'org.springframework.asm_3.1.0.RELEASE[90]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.ec
conflicts with 'org.springframework.asm.commons_3.0.5.RELEASE' in bundle 'org.springframework.asm_3.0.5.RELEASE[1329340717404]' used by 'org.springframework.web.servlet.support_3.
package 'org.springframework.core.convert.converter_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[93]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bu
ndle 'org.eclipse.virgo.web.dm_3.5.0.M02[103]'
conflicts with 'org.springframework.core.convert.converter_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[1329340717395]' used by 'org.springframework.web.servle
t.support_3.0.5.RELEASE' in bundle 'org.springframework.web.servlet_3.0.5.RELEASE[1329340717290]'
Uses violation: <Import-Package: org.springframework.context.config; version="[2.5.6,4.0.0)"> in bundle <org.eclipse.virgo.apps.admin.web_3.5.0.M02[1329340717289]>
Found conflicts:
package 'org.springframework.asm_3.0.5.RELEASE' in bundle 'org.springframework.asm_3.0.5.RELEASE[49]' used by 'org.springframework.context.config_3.0.5.RELEASE' in bundle '
org.springframework.context_3.0.5.RELEASE[51]'
conflicts with 'org.springframework.asm_3.1.0.RELEASE' in bundle 'org.springframework.asm_3.1.0.RELEASE[90]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.eclipse.vi
package 'org.springframework.beans.support_3.0.5.RELEASE' in bundle 'org.springframework.beans_3.0.5.RELEASE[50]' used by 'org.springframework.context.config_3.0.5.RELEASE'
in bundle 'org.springframework.context_3.0.5.RELEASE[51]'
conflicts with 'org.springframework.beans.support_3.1.0.RELEASE' in bundle 'org.springframework.beans_3.1.0.RELEASE[91]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'or
package 'org.springframework.util_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[52]' used by 'org.springframework.context.config_3.0.5.RELEASE' in bundle
conflicts with 'org.springframework.util_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[1329340717395]' used by 'org.springframework.web.servlet.support_3.0.5.RE
conflicts with 'org.springframework.util_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[93]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.eclipse.
package 'org.springframework.core.io_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[52]' used by 'org.springframework.context.config_3.0.5.RELEASE' in bun
conflicts with 'org.springframework.core.io_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[93]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.eclip
package 'org.springframework.beans.factory.xml_3.0.5.RELEASE' in bundle 'org.springframework.beans_3.0.5.RELEASE[50]' used by 'org.springframework.context.config_3.0.5.RELE
ASE' in bundle 'org.springframework.context_3.0.5.RELEASE[51]'
conflicts with 'org.springframework.beans.factory.xml_3.1.0.RELEASE' in bundle 'org.springframework.beans_3.1.0.RELEASE[91]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle
package 'org.springframework.core.io.support_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[52]' used by 'org.springframework.context.config_3.0.5.RELEASE
conflicts with 'org.springframework.core.io.support_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[93]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'o
package 'org.springframework.core_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[52]' used by 'org.springframework.context.config_3.0.5.RELEASE' in bundle
conflicts with 'org.springframework.core_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[93]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.eclipse.
package 'org.springframework.asm.commons_3.0.5.RELEASE' in bundle 'org.springframework.asm_3.0.5.RELEASE[49]' used by 'org.springframework.context.config_3.0.5.RELEASE' in
conflicts with 'org.springframework.asm.commons_3.1.0.RELEASE' in bundle 'org.springframework.asm_3.1.0.RELEASE[90]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.ec
package 'org.springframework.core.convert_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[52]' used by 'org.springframework.context.config_3.0.5.RELEASE' i
conflicts with 'org.springframework.core.convert_3.1.0.RELEASE' in bundle 'org.springframework.core_3.1.0.RELEASE[93]' used by 'org.eclipse.virgo.web.dm_3.5.0.M02' in bundle 'org.
package 'org.springframework.asm_3.0.5.RELEASE' in bundle 'org.springframework.asm_3.0.5.RELEASE[1329340717404]' used by 'org.springframework.context.config_3.0.5.RELEASE'
package 'org.springframework.beans.support_3.0.5.RELEASE' in bundle 'org.springframework.beans_3.0.5.RELEASE[1329340717347]' used by 'org.springframework.context.config_3.0
package 'org.springframework.beans.factory.xml_3.0.5.RELEASE' in bundle 'org.springframework.beans_3.0.5.RELEASE[1329340717347]' used by 'org.springframework.context.config
package 'org.springframework.core.io.support_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[1329340717395]' used by 'org.springframework.context.config_3.
package 'org.springframework.core_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[1329340717395]' used by 'org.springframework.context.config_3.0.5.RELEASE
package 'org.springframework.asm.commons_3.0.5.RELEASE' in bundle 'org.springframework.asm_3.0.5.RELEASE[1329340717404]' used by 'org.springframework.context.config_3.0.5.R
package 'org.springframework.core.convert_3.0.5.RELEASE' in bundle 'org.springframework.core_3.0.5.RELEASE[1329340717395]' used by 'org.springframework.context.config_3.0.5
Uses violation: <Import-Package: org.springframework.web.multipart.commons; version="[2.5.6,4.0.0)"> in bundle <org.eclipse.virgo.apps.admin.web_3.5.0.M02[1329340717289]>
Found conflicts:
package 'org.springframework.web.multipart_3.1.0.RELEASE' in bundle 'org.springframework.web_3.1.0.RELEASE[99]' used by 'org.springframework.web.multipart.commons_3.1.0.REL
conflicts with 'org.springframework.web.multipart_3.0.5.RELEASE' in bundle 'org.springframework.web_3.0.5.RELEASE[1329340717420]' used by 'org.springframework.web.servlet_3.0.5.RE
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:46)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:286)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:165)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:137)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:204)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeployerFileSystemListener.java:163)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeployerFileSystemListener.java:175)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeployerFileSystemListener.java:76)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:245)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:166)
at org.eclipse.virgo.kernel.deployer.hot.WatchTask.run(WatchTask.java:48)
at java.lang.Thread.run(Thread.java:662)
[2012-02-15 15:18:48.678] fs-watcher <DE0003E> Install failed for bundle 'org.eclipse.virgo.apps.admin.core' version '3.5.0.M02'.
[2012-02-15 15:18:48.680] fs-watcher <DE0003E> Install failed for bundle 'org.eclipse.virgo.apps.admin.web' version '3.5.0.M02'.
[2012-02-15 15:18:48.738] fs-watcher <DE0003E> Install failed for plan 'org.eclipse.virgo.apps.admin.plan' version '3.0.0'.
[2012-02-15 15:18:48.774] fs-watcher <HD0002E> Hot deploy failed for file 'org.eclipse.virgo.apps.admin_3.5.0.M02.plan'. org.eclipse.virgo.kernel.deployer.core.DeploymentExcepti
on: Dependency satisfaction failed
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:289)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'org.eclipse.virgo.apps.admin.web' at version '3.5.0.M02':
Resolver report:
Found conflicts:
Re: Error w/Spring 3.1.0.RELEASE in repository/usr w/Virgo Tomcat 3.5.0.M02 [message #799810 is a reply to message #799744] |
Thu, 16 February 2012 10:48 |
You are correct, you should be able to use whatever version of Spring you like in the user region, however there are two problems here. Firstly, there have been some changes in Spring 3.1.0 that required us to make a small change in Virgo for it to work. This isn't a conflict with the other version of Spring just some changes in the manifests and that fix isn't in 3.5.0.M02 but has been done and should be in a milestone soon.
Second, there have been some pretty big changes to the repositories stuff in Vrigo so I wouldn't be surprised if this has cause problems with dependencies leaking between the regions. On the second point, I've asked another committer to have a look at this thread, they might ask you to raise a bug.
Thanks, Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: Error w/Spring 3.1.0.RELEASE in repository/usr w/Virgo Tomcat 3.5.0.M02 [message #799940 is a reply to message #799744] |
Thu, 16 February 2012 13:41 |
@Chris, thanks for the info.
@Borislav, as Chris noted, I'm not trying to replace the Spring version in repository/ext, only in repository/usr, which Chris confirmed I'm supposed to be able to do. By placing some of the Spring 3.1.0 jars in repository/usr and doing nothing else except starting virgo, I get the error listed.
It is worth noting that if I copy **all** of the Spring 3.1.0 jars to repository/usr, then virgo starts normally.
What's the timeline for 3.5.0.RELEASE?
Matthew
Re: Error w/Spring 3.1.0.RELEASE in repository/usr w/Virgo Tomcat 3.5.0.M02 [message #799947 is a reply to message #799940] |
Thu, 16 February 2012 13:50 |
I think that's it then, just needed to copy all the jars. Spring won't work if it's half one version and half another version.
@Borislav, if they remove the old version of spring from repository/ext won't the kernel still be running on the old copy of spring in the plugins folder, this is what I thought but wasn't sure.
Chris.
FUDForum. Page generated in 0.03354 seconds
