Home » Eclipse Projects » BIRT » How to use BIRT 3.7.1 on NetBeans?
How to use BIRT 3.7.1 on NetBeans? [message #798940] Wed, 15 February 2012 08:50 Go to next message
Sergey Syr is currently offline Sergey SyrFriend
Hi! Sorry to my articulation, My English is poor )) I'm from Russia, Moscow
Please, show me example code for use BIRT Run-time 3.7.1 on JAVA
I use NetBeans7.1 and GlassFish 3.1.1
I use this code, but it dont work.
public void executeReport() throws EngineException
	IReportEngine engine=null;
	EngineConfig config = null;
	try{
            String path = "C:\\BIRT\\birt-runtime-3_7_1\\ReportEngine";
		config = new EngineConfig( );
                config.setBIRTHome(path);
                config.setLogConfig("c:/temp/test", Level.FINEST);
		Platform.startup( config );
		IReportEngineFactory factory = (IReportEngineFactory) Platform
		.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
		engine = factory.createReportEngine( config );
		IReportRunnable design = null;
		//Open the report design
		String rpath = "C:\\BIRT\\birt-runtime-3_7_1\\ReportEngine\\new.rptdesign";
		design = engine.openReportDesign(rpath);
		IRunAndRenderTask task = engine.createRunAndRenderTask(design);
		//task.setParameterValue("Top Count", (new Integer(5)));
		//task.validateParameters();
		HTMLRenderOption options = new HTMLRenderOption();
		options.setOutputFileName("c:/temp/Parmdisp.html");
		options.setOutputFormat("html");
		//options.setHtmlRtLFlag(false);
		//options.setEmbeddable(false);
		//options.setImageDirectory("C:\\test\\images");
		//PDFRenderOption options = new PDFRenderOption();
		//options.setOutputFileName("c:/temp/test.pdf");
		//options.setOutputFormat("pdf");
		task.setRenderOption(options);
		task.run();
		task.close();
		engine.destroy();
	}catch( Exception ex){
		ex.printStackTrace();
	finally
	       Platform.shutdown( );
ON Platform.startup( config );
OR engine = factory.createReportEngine( config );
It droping to
[#|2012-02-14T14:53:53.409+0300|WARNING|glassfish3.1.1|javax.enterprise.system.container.web.com.sun.enterprise.web|_ThreadID=25;_ThreadName=Thread-2;|StandardWrapperValve[srvTest]: PWC1406: Servlet.service() for servlet srvTest threw exception
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/CoreException
	at org.eclipse.birt.core.framework.Platform.createPlatformLauncher(Platform.java:115)
	at org.eclipse.birt.core.framework.Platform.startup(Platform.java:74)
	at org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.java:59)
	at com.mecheltrans.test_1.testProcessor.executeReport(testProcessor.java:49)
	at com.mecheltrans.test_1.srvTest.processRequest(srvTest.java:65)
	at com.mecheltrans.test_1.srvTest.doGet(srvTest.java:105)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:734)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:847)
	at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1539)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:281)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
	at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:655)
	at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:595)
	at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:98)
	at com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:91)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:162)
	at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:330)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:231)
	at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:174)
	at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:828)
	at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:725)
	at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1019)
	at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:225)
	at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
	at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
	at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
	at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
	at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
	at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
	at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
	at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
	at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
	at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.runtime.CoreException
	at org.glassfish.web.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1519)
	at org.glassfish.web.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1369)
	... 33 more
What files and folders must be in "ReportEngine", besides that in standard archive birt-runtime-3_7_1.zip??
This code is correctly for 3.7.1 version birt-runtime?
Thank You!
[Updated on: Wed, 15 February 2012 08:55]
Report message to a moderator
Re: How to use BIRT 3.7.1 on NetBeans? [message #799276 is a reply to message #798940] Wed, 15 February 2012 17:27 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
In 3.7.1 you should not set:
Just add the jars from
C:\BIRT\birt-runtime-3_7_1\ReportEngine\lib
to your classpath and run the code you have.
Jason
> try{
> config = new EngineConfig( ); config.setBIRTHome(path);
> task.run();
> task.close();
> engine.destroy();
> finally
> It droping to
Re: How to use BIRT 3.7.1 on NetBeans? [message #799599 is a reply to message #799276] Thu, 16 February 2012 04:15 Go to previous messageGo to next message
Oh! Thank You!
So easy ))
I'ts work
Re: How to use BIRT 3.7.1 on NetBeans? [message #890469 is a reply to message #799599] Fri, 22 June 2012 11:22 Go to previous messageGo to next message
Anna T. is currently offline Anna T.Friend
Do we need aaaaaaaaaaaaaall the jars in C:\BIRT\birt-runtime-3_7_1\ReportEngine\lib to run a simple report?
Re: How to use BIRT 3.7.1 on NetBeans? [message #890585 is a reply to message #890469] Fri, 22 June 2012 15:52 Go to previous message
No you do not, but you will need quite a few. If you look at the data
tools jars you can remove any that you know you will not use. ie if you
are not using db2 remove those jars.
Jason
Previous Topic:Birt Report Problems in Browser
Next Topic:genreport -m render split pdf file
Current Time: Sat Nov 27 03:53:48 GMT 2021
Powered by FUDForum. Page generated in 0.02374 seconds
