Home » Eclipse Projects » P2 » Update (not install) Eclipse SDK with p2 director
Update (not install) Eclipse SDK with p2 director [message #798163] Tue, 14 February 2012 05:30 Go to next message
I'm updating my Eclipse quite often. So far I used p2 agent with couple of defined repositories and profiles. This worked fine but I decided to switch to using scripts. Here is what I put up for installing the SDK (a snippet):
./eclipse/equinox-p2-adminui-3.7.1-linux-gtk-x86/eclipse/eclipse -consolelog -application org.eclipse.equinox.p2.director -metadataRepository http://download.eclipse.org/eclipse/updates/3.8-I-builds -artifactRepository http://download.eclipse.org/eclipse/updates/3.8-I-builds -installIU org.eclipse.sdk.ide -destination ~/eclipse/ibuild38/ -bundlepool ~/eclipse/bp
This works like a charm when installing the IU, but when run for the second time (with intent to update the existing installation) it fails. Changing the destination helps but it's not what I need.
I'm missing a magic switch, right?
T
Re: Update (not install) Eclipse SDK with p2 director [message #799059 is a reply to message #798163] Wed, 15 February 2012 06:47 Go to previous messageGo to next message
Tomasz Zarna wrote on Tue, 14 February 2012 05:30
It would help if you posted the failure too! Smile
But I think you have two problems:
1. You likely need to specify the p2 profile: "-profile SDKProfile"
2. You need to instruct p2 to record the installed features: "-profileProperties org.eclipse.update.install.features=true"
Re: Update (not install) Eclipse SDK with p2 director [message #806100 is a reply to message #799059] Fri, 24 February 2012 09:51 Go to previous messageGo to next message
Thanks for the quick reply Brian.
I applied both suggestions, I think it worked once, but ever since I try to update the SDK I get this:
Installing org.eclipse.sdk.ide 3.8.0.I20120223-0928.
Installation failed.
Cannot complete the install because of a conflicting dependency.
 Software being installed: Eclipse SDK 3.8.0.I20120223-0928 (org.eclipse.sdk.ide 3.8.0.I20120223-0928)
 Software currently installed: Eclipse SDK 3.8.0.I20120214-0800 (org.eclipse.sdk.ide 3.8.0.I20120214-0800)
 Only one of the following can be installed at once:
  toolingorg.eclipse.sdk.ide.configuration 3.8.0.I20120223-0928
  toolingorg.eclipse.sdk.ide.configuration 3.8.0.I20120214-0800
 Cannot satisfy dependency:
  From: Eclipse SDK 3.8.0.I20120214-0800 (org.eclipse.sdk.ide 3.8.0.I20120214-0800)
  To: toolingorg.eclipse.sdk.ide.configuration [3.8.0.I20120214-0800]
  From: Eclipse SDK 3.8.0.I20120223-0928 (org.eclipse.sdk.ide 3.8.0.I20120223-0928)
  To: toolingorg.eclipse.sdk.ide.configuration [3.8.0.I20120223-0928]
Application failed, log file location: /home/tzarna/eclipse/equinox-p2-adminui-3.7.1-linux-gtk-x86/eclipse/configuration/1330094173919.log
And the log itself:
!SESSION 2012-02-24 15:36:12.933 -----------------------------------------------
eclipse.buildId=unknown
java.fullversion=JRE 1.6.0 IBM J9 2.4 Linux x86-32 jvmxi3260sr9-20110624_85526 (JIT enabled, AOT enabled)
J9VM - 20110624_085526
JIT  - r9_20101028_17488ifx17
GC   - 20101027_AA
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments:  -application org.eclipse.equinox.p2.director -metadataRepository http://download.eclipse.org/eclipse/updates/3.8-I-builds -artifactRepository http://download.eclipse.org/eclipse/updates/3.8-I-builds -installIU org.eclipse.sdk.ide -destination /home/tzarna/eclipse/ibuild38 -bundlepool /home/tzarna/eclipse/bp -profile SDKProfile -profileProperties org.eclipse.update.install.features=true
Command-line arguments:  -os linux -ws gtk -arch x86 -consoleLog -application org.eclipse.equinox.p2.director -metadataRepository http://download.eclipse.org/eclipse/updates/3.8-I-builds -artifactRepository http://download.eclipse.org/eclipse/updates/3.8-I-builds -installIU org.eclipse.sdk.ide -destination /home/tzarna/eclipse/ibuild38 -bundlepool /home/tzarna/eclipse/bp -profile SDKProfile -profileProperties org.eclipse.update.install.features=true
!ENTRY org.eclipse.equinox.p2.director 4 1 2012-02-24 15:36:57.464
!MESSAGE Cannot complete the install because of a conflicting dependency.
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2012-02-24 15:36:57.466
!MESSAGE Software being installed: Eclipse SDK 3.8.0.I20120223-0928 (org.eclipse.sdk.ide 3.8.0.I20120223-0928)
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2012-02-24 15:36:57.468
!MESSAGE Software currently installed: Eclipse SDK 3.8.0.I20120214-0800 (org.eclipse.sdk.ide 3.8.0.I20120214-0800)
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2012-02-24 15:36:57.470
!MESSAGE Only one of the following can be installed at once:
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2012-02-24 15:36:57.471
!MESSAGE toolingorg.eclipse.sdk.ide.configuration 3.8.0.I20120223-0928
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2012-02-24 15:36:57.472
!MESSAGE toolingorg.eclipse.sdk.ide.configuration 3.8.0.I20120214-0800
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2012-02-24 15:36:57.474
!MESSAGE Cannot satisfy dependency:
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2012-02-24 15:36:57.475
!MESSAGE From: Eclipse SDK 3.8.0.I20120214-0800 (org.eclipse.sdk.ide 3.8.0.I20120214-0800)
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2012-02-24 15:36:57.476
!MESSAGE To: toolingorg.eclipse.sdk.ide.configuration [3.8.0.I20120214-0800]
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2012-02-24 15:36:57.477
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2012-02-24 15:36:57.479
!MESSAGE From: Eclipse SDK 3.8.0.I20120223-0928 (org.eclipse.sdk.ide 3.8.0.I20120223-0928)
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2012-02-24 15:36:57.481
!MESSAGE To: toolingorg.eclipse.sdk.ide.configuration [3.8.0.I20120223-0928]
The "toolingorg" part looks weird, doesn't it?
[Updated on: Fri, 24 February 2012 09:52] by Moderator
Re: Update (not install) Eclipse SDK with p2 director [message #807793 is a reply to message #806100] Sun, 26 February 2012 21:16 Go to previous messageGo to next message
The p2 director doesn't do updates -- p2 is trying to install the update alongside the existing version and complaining. You need to add a "-uninstallIU org.eclipse.sdk.ide".
Re: Update (not install) Eclipse SDK with p2 director [message #809356 is a reply to message #807793] Tue, 28 February 2012 14:43 Go to previous messageGo to next message
Brian's correct, currently an update is done by -installIU org.eclipse.sdk.ide -uninstallIU org.eclipse.sdk.ide.
But there's a catch. If there is nothing to update, the director trashes your install. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=368238
PW
Re: Update (not install) Eclipse SDK with p2 director [message #809800 is a reply to message #809356] Wed, 29 February 2012 04:24 Go to previous messageGo to next message
The p2agent (aka Admin UI) seems to be handling this case fine, it says something like Quote:
Your request has been modified. X is already installed, so an update will be performed.
and then does so. I was looking for the same thing when running the p2director.
Re: Update (not install) Eclipse SDK with p2 director [message #1714161 is a reply to message #798163] Tue, 10 November 2015 06:27 Go to previous messageGo to next message
Does any new p2director version support updating?
Re: Update (not install) Eclipse SDK with p2 director [message #1786926 is a reply to message #1714161] Tue, 15 May 2018 19:02 Go to previous message
I really wish that was just a different command line switch you could use.
Previous Topic:Eclipse RCP - Dependent plugins deployed as directory
Next Topic:p2.mirror task fails when using iu with specific version
Current Time: Sun Nov 02 12:56:24 EST 2025
Powered by FUDForum. Page generated in 0.24484 seconds
