Home » Archived » Test and Performance Tools Platform (TPTP) » Problems with Code Coverage
Problems with Code Coverage [message #94404] Thu, 29 March 2007 00:00 Go to next message
Originally posted by: naabou.wnt.sas.com
I am trying to use this feature on 4.2.2 and it works the first time only:
after that I get the following error:
Error occurred during initialization of VM
Could not find agent library on the library path or in the local directory:
piLLCAgent
I saw that other developers had the same problem before and were told that
they should use "Profile" instead of "Run" - but this is what I am doing.
The problem I believe is that after the first call, TPTT switches to the
installed Agent Controller running on port 10002 instead of using the
integrated agent. I was able to verify that by going back to
Window->Preferences->Profiling and Logging->Hosts. Even after I explicily
set it to use the "Local Direct Connection" option, it reverts back to
"localhost:10002".
Any suggestions?
Nascif
Re: Problems with Code Coverage [message #94420 is a reply to message #94404] Thu, 29 March 2007 02:48 Go to previous messageGo to next message
On top of that, I can't get line coverage to work as in the viewlet - I
don't get the "method and line coverage" option, just "method coverage"
which just support a summary with percentage numbers. I can't get the
per-line indicators on the editor window.
Is that supposed to be a 4.3.1 feature only, or should it work with 4.2.2 as
well?
"Nascif Abousalh-Neto" <naabou@wnt.sas.com> wrote in message
news:euevjo$iqm$1@build.eclipse.org...
> directory: piLLCAgent
> "localhost:10002".
> Any suggestions?
> Nascif
Re: Problems with Code Coverage [message #94556 is a reply to message #94420] Fri, 30 March 2007 08:31 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
In a vanilla 4.3.1 driver + code coverage tech preview item, I'm not able to
see the code coverage analysis type under the profile launch configuration.
I've opened the following defect
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180150 to address the problem.
I was able to repeatedly run line code coverage using the "Engage Line
Coverage" toolbar button included with the package explorer view.
news:euf9ep$33c$1@build.eclipse.org...
> as well?
>> that they should use "Profile" instead of "Run" - but this is what I am
>> doing. The problem I believe is that after the first call, TPTT switches
>> to the installed Agent Controller running on port 10002 instead of using
>> the integrated agent. I was able to verify that by going back to
>> explicily set it to use the "Local Direct Connection" option, it reverts
>> back to "localhost:10002".
>> Any suggestions?
>> Thanks,
>> Nascif
Re: Problems with Code Coverage [message #94687 is a reply to message #94556] Mon, 02 April 2007 12:59 Go to previous messageGo to next message
I can do that too, but I jst get the summary information.
Do you get the markers on the source code editor as well?
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:euihtk$t9u$1@build.eclipse.org...
> to see the code coverage analysis type under the profile launch
> configuration. I've opened the following defect
> problem.
>> as well?
>>>only: after that I get the following error:
>>> Any suggestions?
>>> Thanks,
>>> Nascif
Re: Problems with Code Coverage [message #94777 is a reply to message #94687] Tue, 03 April 2007 19:39 Go to previous message
Yes, I did get the markers.
news:euqun6$6ha$1@build.eclipse.org...
>> problem.
>>> 4.2.2 as well?
>>>> switches to the installed Agent Controller running on port 10002
>>>> instead of using the integrated agent. I was able to verify that by
>>>> going back to Window->Preferences->Profiling and Logging->Hosts. Even
>>>> after I explicily set it to use the "Local Direct Connection" option,
>>>> it reverts back to "localhost:10002".
>>>> Any suggestions?
>>>> Thanks,
>>>> Nascif
Previous Topic:Build Verification tests
Next Topic:Posting on behalf of Rakesh Sagar
Current Time: Thu Oct 01 20:32:29 GMT 2020
Powered by FUDForum. Page generated in 0.02382 seconds
