Home » Archived » M2M (model-to-model transformation) » [ATL] Transform to unknown target element
[ATL] Transform to unknown target element [message #797529] Mon, 13 February 2012 15:45 Go to next message
MinhTu TonThat is currently offline MinhTu TonThatFriend
Member
Hello everyone,
I have a question about ATL. Hope you can help me.
I'm facing a problem about how to transform to an element without knowing in advance its existence in the metamodel. Say I have a class A, I want to check whether there's a class named "A1" inherited from A and if yes, transform a given value to A1. Any help will be appreciated.
Re: [ATL] Transform to unknown target element [message #798175 is a reply to message #797529] Tue, 14 February 2012 10:51 Go to previous messageGo to next message
Member
Hello again,
Could anyone help me on this problem? To be more specific, I'll give an example like this. I want to transform MM1!A to MM2!B. In MM2 I have many classes inheriting from B (B1, B2, ...). In MM1!A I have an attribute typed String like "inheritingClass:String". Now within the transformation rule, basing on the inheritingClass attribute form MM1!A (its value could be 'B1', 'B2', ...), is there any way to determine the subclass form B to which I will transform A's values?
Best regards.
Re: [ATL] Transform to unknown target element [message #798328 is a reply to message #798175] Tue, 14 February 2012 14:47 Go to previous messageGo to next message
Zheng Cheng is currently offline Zheng ChengFriend
If my interpretation is correct, you can put conditions on the input and have multiple rules for the same src model, e.g.
rule A2B1{
    from
       in : MM1!A (in.inheritingClass = 'B1')
    to
       out : MM2!B1
rule A2B2{
    from
       in : MM1!A (in.inheritingClass = 'B2')
    to
       out : MM2!B2
[Updated on: Tue, 14 February 2012 14:48]
Report message to a moderator
Re: [ATL] Transform to unknown target element [message #798343 is a reply to message #798328] Tue, 14 February 2012 15:05 Go to previous messageGo to next message
Member
Hi Zheng,
Firstly, thank you for your answer. In fact, my problem is we don't know the value of inheritingClass attribute before writing the rule. I mean, is there a similar approach like this snippet of code:
for all subclasses of B
if there exists a subclass whose type name is equal to A.inheritingClass
then transform A's value to that subclass's value
Regards.
Re: [ATL] Transform to unknown target element [message #800652 is a reply to message #798343] Fri, 17 February 2012 10:11 Go to previous messageGo to next message
Member
Because my question is still not answered yet, I reparaphrase it to this question: Is it possible to reason about the existence of the elements of the meta-model in an ATL rule during the rule creation? Is it feasible to write a kind of code with the following philosophy:
If there exists an element named A in the target metamodel then transform a given value to it, else do nothing?
Regards.
Re: [ATL] Transform to unknown target element [message #800996 is a reply to message #800652] Fri, 17 February 2012 19:55 Go to previous messageGo to next message
Dennis Wagelaar is currently offline Dennis WagelaarFriend
> Regards.
First of all: this goes against the philosophy of MDE and model
transformation. Models are first-order, and transformations should not reflect
on the metamodels but just use them.
The way around this first-order limitation, is to use a second transformation:
a higher-order transformation. This second transformation will generate your
first-order transformation, made to measure for your specific metamodel.
See also:
http://www.eclipse.org/m2m/atl/atlTransformations/#KM32ATLCopier
http://jordicabot.com/papers/ICMT10a.pdf
If the expected variation of output metamodels is bounded and small enough,
you can manually create one model transformation for each output metamodel as
well.
Dennis
Re: [ATL] Transform to unknown target element [message #801313 is a reply to message #800996] Sat, 18 February 2012 07:02 Go to previous message
Member
Thank for your reply, Dennis. I think using the HOT to create appropriate transformation rules according to each meta-model fits me well Very Happy
Previous Topic:[ATL]Guard condition at target element in matched rule
Next Topic:[ATL] Compiling ATL files to ASM in build system
Current Time: Sun Nov 29 14:41:54 GMT 2020
Powered by FUDForum. Page generated in 0.02120 seconds
