Changing Server Version ?????? [message #93693] |
Thu, 21 April 2005 06:50 |
Originally posted by: luc_jn.yahoo.com
Hello, is it possible if I want to change the version of the Server, for
example instead of using jboss3.2.x one can use jboss-4.0.1sp1.zip ??? or
from bea8.1spx to Diablo the new version of bea.
If so how ? that could be great.
Thanks.
Re: Changing Server Version ?????? [message #94417 is a reply to message #93693] |
Sat, 23 April 2005 10:00 |
Originally posted by: gercan.REMOVEME.acm.org
This is very much depends on the server you wish to use. For instance
the server definitions for the jboss 3.2.3 will not work with jboss
3.2.6 and later due to changes in the classpath, on the other and jonas
4.1.4 server definition works with Jonas 4.2.3. I am not sure about the
weblogic, I did not try the new wls.
> or from bea8.1spx to Diablo the new version of bea.
> Thanks.
FUDForum. Page generated in 0.03005 seconds
