The TabbedPane test does not work and hangs Eclipse [message #93687] |
Sun, 12 June 2005 16:39  |
Originally posted by: james_rome.yahoo.com
Using the 1.1M2 build, I tried the tabbedPane Functionality test.
1) When I dropped a JFrame on the tabbed pane, the whole editor pane
went white. No tab appeared.
2) I wanted to see whare the JFrame was, so I highlighted it in the bean
window and clicked on the border property editor. The editor came up
blank. Frame only. There was no way to close it, or to get back to Eclipse.
Jim Rome
Re: The TabbedPane test does not work and hangs Eclipse [message #93968 is a reply to message #93953] |
Tue, 14 June 2005 12:13  |
The M2 works with RC2. The problem was that when M2 went out RC2 was not
available yet. Our tests show it is compatible with RC2. We will be
updating the download page to say this.
JamesRome wrote:
> Rich Kulp wrote:
>>Are you using Eclipse 3.1RC2? What java version are you using? Are you
>>on Windows, or some other platform? Are there any messages in the .log
>>file?
> I am using RC1 because the VE download page seems to only have a version
> that works with RC1.
> However, today it works. Part of the problem may be that I had Xerces
> XML: jar files in jre/lib/ext, and they stopped the help server from
> running, for example.
> But when I opened the tabbed pane demo project code in the VE, the beans
> view and property sheet did not appear. They did appear after I switched
> to and back again
Rich Kulp
Re: The TabbedPane test does not work and hangs Eclipse [message #607953 is a reply to message #93879] |
Tue, 14 June 2005 09:49  |
> file?
to and back again
Re: The TabbedPane test does not work and hangs Eclipse [message #607954 is a reply to message #93953] |
>>file?
> to and back again
Rich Kulp
FUDForum. Page generated in 0.06077 seconds
