Home » Archived » Visual Editor (VE) » The TabbedPane test does not work and hangs Eclipse
The TabbedPane test does not work and hangs Eclipse [message #93687] Sun, 12 June 2005 16:39 Go to next message
Originally posted by: james_rome.yahoo.com
Using the 1.1M2 build, I tried the tabbedPane Functionality test.
1) When I dropped a JFrame on the tabbed pane, the whole editor pane
went white. No tab appeared.
2) I wanted to see whare the JFrame was, so I highlighted it in the bean
window and clicked on the border property editor. The editor came up
blank. Frame only. There was no way to close it, or to get back to Eclipse.
Jim Rome
Re: The TabbedPane test does not work and hangs Eclipse [message #93879 is a reply to message #93687] Mon, 13 June 2005 16:39 Go to previous messageGo to next message
Are you using Eclipse 3.1RC2? What java version are you using? Are you
on Windows, or some other platform? Are there any messages in the .log file?
Rich Kulp
Re: The TabbedPane test does not work and hangs Eclipse [message #93953 is a reply to message #93879] Tue, 14 June 2005 09:49 Go to previous messageGo to next message
> file?
I am using RC1 because the VE download page seems to only have a version
that works with RC1.
However, today it works. Part of the problem may be that I had Xerces
XML: jar files in jre/lib/ext, and they stopped the help server from
running, for example.
But when I opened the tabbed pane demo project code in the VE, the beans
view and property sheet did not appear. They did appear after I switched
to and back again
Re: The TabbedPane test does not work and hangs Eclipse [message #93968 is a reply to message #93953] Tue, 14 June 2005 12:13 Go to previous message
The M2 works with RC2. The problem was that when M2 went out RC2 was not
available yet. Our tests show it is compatible with RC2. We will be
updating the download page to say this.
>>file?
> to and back again
Rich Kulp
Re: The TabbedPane test does not work and hangs Eclipse [message #607948 is a reply to message #93687] Mon, 13 June 2005 16:39 Go to previous message
Rich Kulp
Re: The TabbedPane test does not work and hangs Eclipse [message #607953 is a reply to message #93879] Tue, 14 June 2005 09:49 Go to previous message
> file?
to and back again
Re: The TabbedPane test does not work and hangs Eclipse [message #607954 is a reply to message #93953] Tue, 14 June 2005 12:13 Go to previous message
>>file?
> to and back again
Rich Kulp
Previous Topic:Disable add components
Next Topic:VE design of RCP Wizard pages (ve 3.1M2)
Current Time: Fri Jul 18 01:24:16 EDT 2025
Powered by FUDForum. Page generated in 0.29767 seconds
