Home » Newcomers » Newcomers » Eclipse not picking up Maven Managed Dependencies
Eclipse not picking up Maven Managed Dependencies [message #793812] Wed, 08 February 2012 15:52 Go to next message
adam medi is currently offline adam mediFriend
I'm pretty new to maven and i'm trying to compile, run and debug a esper project in Maven.
I've successfully managed to compile the project on the command line using maven.
However when I add the project to eclipse eclispe doesn't seem to recognise any of the objects which are included as a dependency from the pom file and therefore I get compile errors.
I'm running the latest version of eclipse with the latest version of m2e eclipse.
I'm running on windows 7 (64 bit).
Any help would be greatly appreciated.
Re: Eclipse not picking up Maven Managed Dependencies [message #794113 is a reply to message #793812] Wed, 08 February 2012 23:22 Go to previous message
David M. Karr is currently offline David M. KarrFriend
You didn't say whether you added the Maven nature to the project.
Previous Topic:Hi to everybody!
Next Topic:The output folder cannot be set to the root of a volume.
Current Time: Fri Jul 23 16:06:06 GMT 2021
Powered by FUDForum. Page generated in 0.03213 seconds
