Re: Hexadecimal values on bar chart [message #793900 is a reply to message #793685] |
Wed, 08 February 2012 18:23 |
I am not 100% certain what you need. Do both strings contain 512 chars?
Jason
On 2/8/2012 7:41 AM, cankovicv wrote:
> I have two fields:
> First:0000AAAABBBBBBBBBBBBBBAAAA987653
> Second:00CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCBCCBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBCBBBBBBBBBBBBBBBBBBBBB2BBBBBBBBBBB2BBBBBBBBBBBBBBBBBBBBAAAAAAAAAAAAAAAAAAAAAAAAAA9999999999999999999999999999
> Each character in field represents hexadecimal value.
> So on y-axis we have limited values from 0 to 15 (from 0 to F).
> On x-axis is value from 0 to 512 because each of this two fields can have maximum 512 characters.
> So on example balded A in first field will have coordinates (5,10). 5 is x value because it is 5-th character in field and 10 because A is hexadecimal 10.
> Similar balded C in second field will have coordinates(3,12).
> Picture how it looks in some system is below.
> Can someone knows how to solve and present this? Thanks
Re: Hexadecimal values on bar chart [message #793968 is a reply to message #793926] |
Wed, 08 February 2012 19:35 |
Take a look at the attached example. Look at the scripts on the
scripted dataset.
Jason
On 2/8/2012 1:51 PM, cankovicv wrote:
> Thanks Jason for response, yes both fields contains 513 characters (not
> 512 my mistake because from 0 to 512 are 513 spots that is hexadecimal
> values).
> Do you know maybe how to get each character value separately from that
> huge string value and how to do the mapping of coordinates for the
> values of y axis (0 -15 hexadecimal) and x-axis (0-512)? I would
> appreciate some example if you have.
> Thanks!!!
Attachment: hexchart.zip
(Size: 4.23KB, Downloaded 224 times)
Re: Hexadecimal values on bar chart [message #798446 is a reply to message #798196] |
Tue, 14 February 2012 17:56 |
I have modified the example to illustrate how you could nest the data
set in another data set to get the initial string that you will be using
for the chart data set. Look at the script and look at the binding tab
for the chart. Specifically look at the parameters for the binding of
the chart which references the outer tables data value. For the two
field, do you want a second chart or a second series on the same chart?
Jason
On 2/14/2012 6:22 AM, cankovicv wrote:
> Jason thanks for your useful material.
> I just have two questions:
> 1. you bound xstring with some value...xstring =
> "00CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC... but how to bind it in
> script with some field? because this values will be different for each
> record in DB.
> can I use something like xstring=field_name or what is the correct
> expression? same problem and for ystring...?
> 2. what is necessary to add to this be aplicable for two fields? I saw
> that you commented ystring
> So I would add in open method this:
> iiy=0;
> ystring="000AB..."
> leny=ystring.length;
> and in fetch method:
> if( iiy >= leny ) return false;
> row["xval"] = iiy; // parseInt(xstring.substr(iiy,1),16);
> row["yval"] = parseInt(xstring.substr(iiy,1),16);
> iiy++
> return true;
> is this enough?
> Thanks
(Size: 4.66KB, Downloaded 196 times)
Re: Hexadecimal values on bar chart [message #803645 is a reply to message #802761] |
Tue, 21 February 2012 16:10 |
Modify the scripted datasets and refresh the bindings on the chart and
table. Do refresh select the binding tab in the properties editor and
click on the refresh button. You will need to add another input
parameter to the nested dataset as well. Look at the attached modified
example.
Jason
On 2/20/2012 7:12 AM, cankovicv wrote:
> Hi Jason, I would like second series on the same chart.
> What do I have to change?
> Thanks
(Size: 5.04KB, Downloaded 248 times)
Re: Hexadecimal values on bar chart [message #805361 is a reply to message #804517] |
Thu, 23 February 2012 17:11 |
This is an issue with the area chart type. You can bump the chart to
the left with some script but it will not extend to the furthest point
to the right. For example put a script like this in:
function beforeDrawSeries( series, seriesRenderer, context )
if( series.getSeriesIdentifier() == "Series 1" ||
series.getSeriesIdentifier() == "Series 2"){
var dpharray =
seriesRenderer.getSeriesRenderingHints().getDataPoints();
for( j=0;j<dpharray.length;j++){
var xval = dpharray[j].getLocation().getX();
dpharray[j].getLocation().setX(xval-100);
Jason
On 2/22/2012 1:18 PM, cankovicv wrote:
> You are GENIUS!!! I can't thank you enough!!!!
> This is exactly what I wanted (similar to the first graphic) and it looks very nice:)
> Just one more little question- can I somehowe move this graph to the left to assemble it to the y and x axis?
> Thank you Jason once again!!!
FUDForum. Page generated in 0.03042 seconds
