Home » Eclipse Projects » GEF » ZEST: Transparent nodes?
ZEST: Transparent nodes? [message #793587] Wed, 08 February 2012 10:12 Go to next message
Stephan Druskat is currently offline Stephan DruskatFriend
Dear All,
before I turn to using ZEST for my RCP application, I'd like to know whether it's possible to have transparent nodes in a graph, so that only the node text is visible.
Many thanks!
Re: ZEST: Transparent nodes? [message #793610 is a reply to message #793587] Wed, 08 February 2012 10:46 Go to previous message
Zoltan Ujhelyi is currently offline Zoltan UjhelyiFriend
You could define custom figures. If you are using the JFace API, then your Label provider should extend the IFigureProvider. Or you could create nodes with custom figures using the CGraphNode class.
Previous Topic:Disable connection feedback
Next Topic:Palette problem in a MultiPageEditor
Current Time: Mon Nov 29 03:54:20 GMT 2021
Powered by FUDForum. Page generated in 0.01300 seconds
