Re: No autocompletion - even with simple code [message #93836 is a reply to message #93276] |
Tue, 17 February 2009 11:53 |
Originally posted by: michael.zend.com
Can you report a bug?
Thanks!
"Ingo Renner" <ingo@typo3.org> wrote in message
news:gmumec$f0o$1@build.eclipse.org...
> Hi all,
> I have a problem here with autocompletion not working even with that
> simple code...
> class X extends Y implements Z {
> public function __construct($host = 'localhost', $port = 8180, $path =
> parent::_construct($host, $port, $path);
> $h <-- no autocompletion here (for $host), only $HTTP_* global variables
> There's also no overwrite indicator for the constructor.
> Any idea what could cause this? In other projects this works fine however.
> Ingo
Re: No autocompletion - even with simple code [message #94001 is a reply to message #93850] |
Thu, 19 February 2009 12:52 |
Hi Ingo,
This is a message not just for you but also for all who is willing to help
PDT project.
I'll appreciate if you attach a unit test for code assit bug to the bug
report. Here are the instructions:
1. The unit test file must end with ".pdtt" extension
2. Unit test format is the following:
--TEST--
Test description
--FILE--
<?php
File contents. Put '|' character where you suppose to call the code assist.
--EXPECT--
Expected output
3. Expected output is a list of: type(A), method(A), field(A) or keyword(A)
entries, where A is an element name and 'type', 'method', 'field' or
'keyword' are element types:
a) 'type' refers to class, interface or namespace
b) 'method' refers to method or function
c) 'field' refers to variable or constant
d) 'keyword' refers to a PHP keyword or PHPDoc tag.
4. Example:
--TEST--
Test whether code assist of class instantiation works (bug #12345)
--FILE--
<?php
class MyClass1 {}
class MyClass2 {}
$a = new MyCl|
--EXPECT--
type(MyClass1)
type(MyClass2)
More examples can be found here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.pdt/tes ts/org.eclipse.php.test/workspace/codeassist/?root=Tools_Pro ject
Thanks for your help!
Michael
news:gnef7s$dsn$1@build.eclipse.org...
> Michael Spector wrote:
> Hi Michael,
> sure, will do. Is there anything I could attach that could help you find
> out what's going on / that could be of help to reproduce the issue? Any
> logs or so?
> best
> Ingo
Re: No autocompletion - even with simple code [message #94060 is a reply to message #94001] |
Thu, 19 February 2009 18:30 |
Roy Ganor Messages: 149 Registered: July 2009 |
Great stuff! I am sure we will be able to direct people to this method
when they meet code assist issue.
The next wiki page summarizes the pdtt method, including how to create and
submit a pdtt test -
http://wiki.eclipse.org/PDTT_-_PHP_5.3_Code_Assist_Tests
BTW - can we change the "type" element to "namespace" when the type is
really a namespace? I think that most users will not understand it.
Thanks!
- Roy
> Hi Ingo,
> PDT project.
> --TEST--
> Test description
> --FILE--
> <?php
> --EXPECT--
> Expected output
> 4. Example:
> --TEST--
> --FILE--
> <?php
> class MyClass1 {}
> class MyClass2 {}
> $a = new MyCl|
> --EXPECT--
> type(MyClass1)
> type(MyClass2)
> Best regards,
> Michael
>> Hi Michael,
>> logs or so?
>> best
>> Ingo
FUDForum. Page generated in 0.03894 seconds
