Home » Modeling » TMF (Xtext) » How to iterate through a HashMap in Xtend?
How to iterate through a HashMap in Xtend? [message #792949] Tue, 07 February 2012 15:45 Go to next message
Soenke Brightside is currently offline Soenke BrightsideFriend
Member
As the title says: How can i iterate through a Hashmap in Xtend?
Sönke
Re: How to iterate through a HashMap in Xtend? [message #792995 is a reply to message #792949] Tue, 07 February 2012 16:42 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Am 07.02.12 16:45, schrieb Soenke Escher:
> Sönke
Sönke,
for(e: map.entrySet) {
should do the trick.
Alternatively you could use
map.forEach [key, value | ..]
Sebastian
Re: How to iterate through a HashMap in Xtend? [message #793585 is a reply to message #792995] Wed, 08 February 2012 10:09 Go to previous messageGo to next message
Member
Thank you Sebastian,
i already tryed this but the problem is the e/key/value has the type Object and i cannot cast them to Map.Entry.
"Couldn't resolve reference to JvmType 'Map.Entry'."
Sönke
[Updated on: Wed, 08 February 2012 10:11]
Report message to a moderator
Re: How to iterate through a HashMap in Xtend? [message #793595 is a reply to message #793585] Wed, 08 February 2012 10:24 Go to previous messageGo to next message
Sönke,
how's your map defined / instantiated?
Sebastian
Am 08.02.12 11:09, schrieb Soenke Escher:
> Sönke
Re: How to iterate through a HashMap in Xtend? [message #793596 is a reply to message #793595] Wed, 08 February 2012 10:28 Go to previous messageGo to next message
Member
var hmap = new HashMap<SystemComponent, List<SystemComponent>>();
Sönke
Re: How to iterate through a HashMap in Xtend? [message #793609 is a reply to message #793596] Wed, 08 February 2012 10:43 Go to previous messageGo to next message
Sönke,
this works for me:
import java.util.HashMap
import java.util.List
class X {
def forLoopMap() {
var hmap = new HashMap<String, List<String>>();
for(e: hmap.entrySet) {
val String key = e.key
val String firstValue = e.value.head
// to avoid unused variable warnings
if (key == firstValue)
return
def forEachMap() {
hmap.forEach [ k, v |
val String key = k
val String firstValue = v.head
return
Which version of Xtend do you use?
Sebastian
Am 08.02.12 11:28, schrieb Soenke Escher:
> Sönke
Re: How to iterate through a HashMap in Xtend? [message #793617 is a reply to message #793609] Wed, 08 February 2012 10:55 Go to previous messageGo to next message
Member
I use Xtend2 2.2.1. Your code runs fine.
Here a code-snippet of mine:
def dispatch compile(ProjectRepository pr, IFileSystemAccess fsa) {
for(e:pr.hashMap.entrySet){
// e is type of object. cant do anything with it.
def HashMap getHashMap(ProjectRepository pr){
//do something
return hmap;
Re: How to iterate through a HashMap in Xtend? [message #793620 is a reply to message #793617] Wed, 08 February 2012 10:58 Go to previous message
Member
Got it. I had to change
to
def HashMap<SystemComponent, List<SystemComponent>> getHashMap(ProjectRepository pr){
Previous Topic:How to limit content assist suggestion to same file
Next Topic:Writing unit tests for code written in my DSL
Current Time: Sat Feb 27 22:37:57 GMT 2021
Powered by FUDForum. Page generated in 0.02206 seconds
