Re: birt view localization problem [message #793192 is a reply to message #792702] |
Tue, 07 February 2012 21:34 |
How are you setting the locale? In the preview preferences?
What version of BIRT is the product based on?
Jason
On 2/7/2012 4:57 AM, Ricky Mising name wrote:
> Dear friends,
> I met a strange problem.
> We have a RCP product based on Birt Designer and we have NLS support. I
> set the locale to Simple Chinese. I use the "preview as HTML" option to
> preview a birt report. The url issued to birt viewer is as below;
> //127.0.0.1:62177/viewer/preview?__report=C%3A%5CUsers%5Cuser%5CDesktop%5Crky%5Cbackup.rptdesign&__format=html&__svg=false&__locale=%E4%B8%AD%E6%96%87+%28%E4%B8%AD%E5%9B%BD%29&__timezone=America%2FChicago&__masterpage=true&__rtl=false&__cubememsize=10&__resourceFolder=C%3A%5CUsers%5Cuser%5CDesktop%5Crky&__dpi=96&-1652979745
> But I could see nothing just with a white panel. So, I tried to see the
> source and the HTML content is shown in notepad, everything is ok.
> I copied the url to IE8(WIN 7, Virtual Machine) and found the same
> problem. But I tried to see the source content and found the messy
> code(the original Chinese Character) which destroied the HTML structure.
> I think this is the reason why the page is blank. But if I copy the url
> to firefox, the page can be displayed correctly.
> The IE8 can display other Chinese page well.
> the source content from IE8
> <title>BIRT 鎶ュ憡鏌ョ湅鍣?/title>
> I feel confused about this problem. If I installed the product in a
> physical machine(WIN7 IE8), everything works ok. Could you please give
> some clue on this? Is there any configuration I can set in IE8? Is this
> an encoding problem?
Re: birt view localization problem [message #793387 is a reply to message #793337] |
Wed, 08 February 2012 04:24 |
When you have the designer open, select Window->preference->Report
Design->Preview. Check the locale setting.
Jason
On 2/7/2012 9:40 PM, Ricky Mising name wrote:
> I changed the locale on the OS. The birt designer version is 2.6.1.
FUDForum. Page generated in 0.02211 seconds
