Re: Data Set Refresh Output Columns [message #792357 is a reply to message #792230] |
Mon, 06 February 2012 22:56 |
I do not think refreshing the bindings will remove a column because
technically a column in the binding can be created that gets its data
from an external source and not the data set. That said you can remove
a column by selecting the binding tab for the report item, click on the
column and click on the remove button.
Jason
On 2/6/2012 2:35 PM, Shane Allred wrote:
> I have a similar problem in the actual reports. It seems clicking
> "Refresh" on the data binding adds missing columns but leaves deleted
> and changed columns in the list, which causes an error when you run a
> report. I had to go into the XML and manually make the changes.
FUDForum. Page generated in 0.03947 seconds
