Re: RAP 1.5 M5 - invalid software site [message #791972 is a reply to message #791923] |
Mon, 06 February 2012 13:30 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Sudesh,
due to breaking changes in the Eclipse platform, the 1.5 tooling is no
longer working with Indigo. See the following bug for more details:
366614: [Tooling] Breaking changes in the latest org.eclipse.pde.core bundle
https://bugs.eclipse.org/bugs/show_bug.cgi?id=366614
If you want to use 1.5 runtime with Indigo, you could still do it by
installing the 1.4 tooling. In this case, you need to manually adjust
the auto-generated launch configuration (add new jetty bundles, apache
gogo bundles, osgi console bundle and rwt.osgi bundle). For 1.5 tooling
you need at least Eclipse 3.8M4 or 4.2M4.
HTH,
Ivan
On 2/6/2012 2:21 PM, Sudesh Bulathsinhala wrote:
> Hello,
> i'm trying to install the latest RAP 1.5M5 using the following URL.
> the version of eclipse is indigo(jee), which i downloaded recently and
> there's no previous version of RAP installed. so it's pretty much
> clean environment.
> http://download.eclipse.org/rt/rap/1.5/tooling
> however, when i try to install the RAP 1.5 using the above URL, i'm
> only given with the old version selections below :
> Rich Ajax Platform (RAP) Tooling 1.5.0.20111107-1628
> Rich Ajax Platform (RAP) Tooling 1.5.0.20110927-1701
> Rich Ajax Platform (RAP) Tooling 1.5.0.20110816-0954
> also i tried with nightly builds URL below :
> http://download.eclipse.org/rt/rap/nightly/tooling/
> while installing nightly build using above URL, i get the following
> error message :
> Cannot complete the install because one or more required items could
> not be found.
> Software being installed: Rich Ajax Platform (RAP) Tooling
> 1.5.0.20120206-0255 (org.eclipse.rap.tooling.feature.group
> 1.5.0.20120206-0255)
> Missing requirement: RWT Launcher Plug-in 1.5.0.20120206-0255
> (org.eclipse.rap.ui.launch.rwt 1.5.0.20120206-0255) requires 'bundle
> org.eclipse.jetty.continuation [8.1.0,9.0.0)' but it could not be found
> Cannot satisfy dependency:
> From: Rich Ajax Platform (RAP) Tooling 1.5.0.20120206-0255
> (org.eclipse.rap.tooling.feature.group 1.5.0.20120206-0255)
> To: org.eclipse.rap.ui.launch.rwt [1.5.0.20120206-0255]
> none of the above two methods were successful.
> 1. latest stable build - http://download.eclipse.org/rt/rap/1.5/tooling
> 2. nightly build -
> kindly advise, if i'm not following the correct approach OR had i
> missed something.
> Regards,
> Sudesh
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03712 seconds
