Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Problems with inherited field
[Teneo] Problems with inherited field [message #92934] Fri, 10 August 2007 09:49 Go to next message
Originally posted by: doux.guil.gmail.com
Hi all,
I'm always experiencing problem with Teneo.
I have models that are conformed to a meta model.
The problem is that when I try to deserialize the model from an ecore
file, if I register the meta models packages from the meta models loaded
from an ecore file it works fine and I can deserialize my model.
But when I try to get my meta model from Teneo (assuming that the meta
model getting from Teneo vas previously persisted by taking the meta
model coming from the ecore file), I obtain an Exception :
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature
'val' not found. (file:///C:/eclipse-SDK-3.3-
win32/workspace/TestPlugin/deb_res_thunderbird.ecore, 8, 106)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors
(XMLLoadImpl.java:81)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load
(XMLLoadImpl.java:189)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad
(XMLResourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load
(ResourceImpl.java:1354)
(ResourceImpl.java:1155)
at test.TestStoreMetaModel.main(TestStoreMetaModel.java:131)
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeatu re
(XMLHandler.java:1856)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeatu re
(XMLHandler.java:1820)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.handleUnknownFeatu re
(XMIHandler.java:149)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue
(XMLHandler.java:2570)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs
(SAXXMIHandler.java:76)
So, I have seen that the "val" feature that isn't found is an inherited
attribute. And If I remove all the inherited element from my model It
works.
I have also seen that the mapping generated by Teneo for a meta model
are not the same if the meta model come directly from my ecore file or
if it is a meta model persisted with Teneo.
With the same properties for the initialization of the hbdatastore
(inheritance mapping setted to SINGLE_TABLE), the subclasses are not
mapped in the same way :
- when the meta model come from the ecore file only one table is
created for a class hierarchy as it is say on
http://www.elver.org/hibernate/inheritance.html
- when the "same" meta model come from Teneo the mapping create
also tables for the subclasses.
It is a problem for me because I have to do a models and meta models
repository, so I must be able to add/get/remove models corresponding to
meta models that are stored in Teneo (without the ecore files containing
the metamodels). But here the meta models coming from file or coming
from Teneo appears to not being equivalent and it doesn't work...
I'm trying to solve it from a long time but I con't find the solution...
If anyone can help me, I will be very happy.
Guillaume Doux
Re: [Teneo] Problems with inherited field [message #92961 is a reply to message #92934] Fri, 10 August 2007 10:13 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Guillaume,
If you encounter many problems then (imho) the best approach I can think of is take a small model
and analyze the differences between the xml-serialization and the db-serialization (write the
db-serialized model to an xml file and do a text compare) and then post these differences here in
the newsgroup. I would use several small models each one of them covering a limited set of more
complex part of your real-live models (for example one covering inheritance, one other for several
associations, one for enumerates, one for edatatypes, etc.).
Regarding your specific problem, it seems that the inheritance relations between your eclasses is
not persisted in the database. Because of this:
- the sub eclasses are stored in their own table (as Teneo does not see a supertype)
- the inherited features are not visible in the subeclass (as the subeclass does not have a relation
anymore to its supertype).
Can you check/post the hibernate mapping for the eSuperType and eGenericSuperType feature of the eClass?
gr. Martin
guillaume wrote:
> Hi all,
> at
> works.
> Guillaume Doux
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Problems with inherited field [message #93005 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous messageGo to next message
Hi again,
I attach the generated mapping for the meta-model coming from the ecore
file (mappingWithModelFromEcoreFile.xml) , the mapping for the meta-model
coming from Teneo (mappingWithModelFromTeneo.xml) , the serialized version
of my meta-model coming from Teneo (debFromTeneo.ecore) and my original
meta-model file (debFile.ecore).
The difference between the 2 ecore file is that in my original meta model,
the subclasses are represented like this :
<eClassifiers xsi:type="ecore:EClass" name="Version"
eSuperTypes="#/1/Field"/>
and in the serialized form coming from Teneo, I have this :
<eClassifiers xsi:type="ecore:EClass" name="Version">
<eGenericSuperTypes eClassifier="ecore:EClass
testdeb.ecore#/1/Field"/>
</eClassifiers>
Guillaume
Martin Taal <mtaal@elver.org> wrote in
news:f9hdp5$kh2$1@build.eclipse.org:
> Hi Guillaume,
> think of is take a small model and analyze the differences between the
> xml-serialization and the db-serialization (write the db-serialized
> differences here in the newsgroup. I would use several small models
> each one of them covering a limited set of more complex part of your
> several associations, one for enumerates, one for edatatypes, etc.).
> relations between your eclasses is not persisted in the database.
> Because of this: - the sub eclasses are stored in their own table (as
> Teneo does not see a supertype) - the inherited features are not
> gr. Martin
> guillaume wrote:
>> Hi all,
>> loaded from an ecore file it works fine and I can deserialize my
>> model.
>> meta model getting from Teneo vas previously persisted by taking the
>> meta model coming from the ecore file), I obtain an Exception :
>> Feature 'val' not found. (file:///C:/eclipse-SDK-3.3-
>> at
>> at
>> at
>> at
>> inherited attribute. And If I remove all the inherited element from
>> my model It works.
>> or if it is a meta model persisted with Teneo.
>> table is
>> create
>> to meta models that are stored in Teneo (without the ecore files
>> containing the metamodels). But here the meta models coming from file
>> or coming from Teneo appears to not being equivalent and it doesn't
>> work...
>> solution...
>> Thanks,
>> Guillaume Doux
Re: [Teneo] Problems with inherited field - File 1 of 4 - debFile.ecore (1/1) [message #93020 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous messageGo to next message
Re: [Teneo] Problems with inherited field - File 2 of 4 - debFromTeneo.ecore (1/1) [message #93034 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous messageGo to next message
Re: [Teneo] Problems with inherited field - File 3 of 4 - mappingWithModelFromEcoreFile.xml (1/1) [message #93070 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous messageGo to next message
Re: [Teneo] Problems with inherited field - File 4 of 4 - mappingWithModelFromTeneo.xml (1/1) [message #93085 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous messageGo to next message
Re: [Teneo] Problems with inherited field [message #93101 is a reply to message #93005] Fri, 10 August 2007 11:22 Go to previous messageGo to next message
and how does the hbm mapping of the ecore model itself look like? Especially the part around
EClassifier.
gr. Martin
guillaume wrote:
> Hi again,
> </eClassifiers>
> Guillaume
>> Hi Guillaume,
>> gr. Martin
>> guillaume wrote:
>>> Hi all,
>>> model.
>>> at
>>> at
>>> at
>>> at
>>> my model It works.
>>> table is
>>> create
>>> work...
>>> solution...
>>> Thanks,
>>> Guillaume Doux
The Netherlands
Re: [Teneo] Problems with inherited field - 1 attachment [message #93131 is a reply to message #93101] Fri, 10 August 2007 12:38 Go to previous messageGo to next message
It's the mapping corresponding to the EcorePackage,
the part arround the EClassifier is :
<subclass name="org.eclipse.emf.ecore.impl.EClassifierImpl" entity-
name="EClassifier" abstract="true" lazy="false" extends="ENamedElement"
discriminator-value="EClassifier">
<meta attribute="eclassName">EClassifier</meta>
<meta attribute="epackage">http://www.eclipse.org/emf/2002/Ecore
</meta>
<property name="instanceClassName" lazy="false" insert="true"
update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false"
name="`instanceclassname`"/>
</property>
<property name="instanceTypeName" lazy="false" insert="true"
name="`instancetypename`"/>
</property>
<many-to-one name="ePackage" entity-name="EPackage" lazy="false"
insert="false" update="false" not-null="false">
name="`eclassifier_epackage_e_id`"/>
</many-to-one>
<list name="eTypeParameters" lazy="true" cascade="all,delete-
orphan">
<key update="true">
<column name="`eclassifier_etypeparameters_e_id`" not-
null="false" unique="false"/>
</key>
<list-index column="`eclassifier_etypeparameters_idx`"/>
<one-to-many entity-name="ETypeParameter"/>
</list>
</subclass>
I attach the complete mapping file.
thanks,
Guillaume.
news:f9hhot$si0$1@build.eclipse.org:
> Especially the part around EClassifier.
> gr. Martin
> guillaume wrote:
>> Hi again,
>> ecore file (mappingWithModelFromEcoreFile.xml) , the mapping for the
>> meta-model coming from Teneo (mappingWithModelFromTeneo.xml) , the
>> serialized version of my meta-model coming from Teneo
>> (debFromTeneo.ecore) and my original meta-model file (debFile.ecore).
>> model, the subclasses are represented like this :
>> </eClassifiers>
>> Thanks,
>> Guillaume
>>> Hi Guillaume,
>>> post these differences here in the newsgroup. I would use several
>>> small models each one of them covering a limited set of more complex
>>> one other for several associations, one for enumerates, one for
>>> edatatypes, etc.).
>>> (as Teneo does not see a supertype) - the inherited features are not
>>> gr. Martin
>>> guillaume wrote:
>>>> Hi all,
>>>> ecore file, if I register the meta models packages from the meta
>>>> models loaded from an ecore file it works fine and I can
>>>> the meta model coming from the ecore file), I obtain an Exception :
>>>> at
>>>> at
>>>> at
>>>> at
>>>> my model It works.
>>>> model are not the same if the meta model come directly from my
>>>> ecore file or if it is a meta model persisted with Teneo.
>>>> not mapped in the same way :
>>>> table is
>>>> create
>>>> models repository, so I must be able to add/get/remove models
>>>> corresponding to meta models that are stored in Teneo (without the
>>>> ecore files containing the metamodels). But here the meta models
>>>> coming from file or coming from Teneo appears to not being
>>>> solution...
>>>> Thanks,
>>>> Guillaume Doux
Re: [Teneo] Problems with inherited field - 1 attachment [message #93196 is a reply to message #93131] Fri, 10 August 2007 21:02 Go to previous messageGo to next message
--------------090608060508000500000906
I retested this and afaics it went fine (see the attached file, this one was read from the db). Your
debFromTeneo.ecore has a view strange sections:
<eClassifiers xsi:type="ecore:EClass" name="Dependancy">
<eGenericSuperTypes eClassifier="ecore:EClass testdeb.ecore#/1/Field"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="package_descriptions">
</eClassifiers>
What I don't understand is where this: ecore:EClass testdeb.ecore#
comes from. In the ecore file, I created, the uri is: /1/Field.
My feeling is that this has something to do with the way you create the resource which reads the
debFromTeneo.ecore (btw, this may not be the problem but hides why it does not work for you).
Also my experience with reading epackages from the db or the filesystem is that it needs to be done
through a resourceset this ensures that the packages are placed in the EPackage registry and that
this registry is used during reading.
Btw, here is the simplified code I use to read the ecore, persist it and read it back. There are a
number of calls to convenience methods (store.beginTransaction etc.) but for the rest it is pretty
simple. This code does not use a resourceset (not required for the tests) but in production code you
should do this. You can try to replicate this simple approach and then check if the output is
incorrect or correct.
final Resource fileRes = new XMIResourceImpl();
fileRes.load(this.getClass().getResourceAsStream("debFile.ecore "), Collections.EMPTY_MAP);
store.beginTransaction();
for (Object o : fileRes.getContents()) {
store.store(o);
store.commitTransaction();
final Resource res = new XMIResourceImpl();
for (Object o : store.getObjects(EPackage.class)) {
res.getContents().add((EObject) o);
final OutputStream os = new FileOutputStream("/home/mtaal/mytmp/test.ecore");
res.save(os, Collections.EMPTY_MAP);
gr. Martin
guillaume wrote:
> </meta>
> </property>
> </property>
> </many-to-one>
> orphan">
> <key update="true">
> </key>
> </list>
> </subclass>
> thanks,
> Guillaume.
>> Hi,
>> gr. Martin
>> guillaume wrote:
>>> Hi again,
>>> </eClassifiers>
>>> Thanks,
>>> Guillaume
>>>> Hi Guillaume,
>>>> edatatypes, etc.).
>>>> gr. Martin
>>>> guillaume wrote:
>>>>> Hi all,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> my model It works.
>>>>> table is
>>>>> create
>>>>> solution...
>>>>> Thanks,
>>>>> Guillaume Doux
> <!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD 3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
> <!-- Generated by Teneo on Fri Aug 10 14:17:28 CEST 2007 -->
> <hibernate-mapping auto-import="false">
> <typedef name="ecore.EDiagnosticChain" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
> <param name="epackage">http://www.eclipse.org/emf/2002/Ecore</param>
> <param name="edatatype">EDiagnosticChain</param>
> </typedef>
> <typedef name="ecore.EEList" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
> <param name="edatatype">EEList</param>
> </typedef>
> <typedef name="ecore.EEnumerator" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
> <param name="edatatype">EEnumerator</param>
> </typedef>
> <typedef name="ecore.EFeatureMap" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
> <param name="edatatype">EFeatureMap</param>
> </typedef>
> <typedef name="ecore.EFeatureMapEntry" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
> <param name="edatatype">EFeatureMapEntry</param>
> </typedef>
> <typedef name="ecore.EMap" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
> <param name="edatatype">EMap</param>
> </typedef>
> <typedef name="ecore.EResource" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
> <param name="edatatype">EResource</param>
> </typedef>
> <typedef name="ecore.EResourceSet" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
> <param name="edatatype">EResourceSet</param>
> </typedef>
> <typedef name="ecore.ETreeIterator" class=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
> <param name="edatatype">ETreeIterator</param>
> </typedef>
> <class name="org.eclipse.emf.ecore.impl.BasicEObjectImpl" entity-name="ecore_EObject" abstract="false" lazy="false" discriminator-value="ecore_EObject" table="`ecore_eobject`">
> <meta attribute="eclassName">EObject</meta>
> <meta attribute="epackage">http://www.eclipse.org/emf/2002/Ecore</meta>
> <id type="long" name="e_id" column="e_id" access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
> <meta attribute="syntheticId">true</meta>
> <generator class="native"/>
> </id>
> <discriminator column="`dtype`" type="string"/>
> <version name="e_version" column="e_version" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
> <meta attribute="syntheticVersion">true</meta>
> </version>
> </class>
> <subclass name="org.eclipse.emf.ecore.impl.EModelElementImpl" entity-name="EModelElement" abstract="true" lazy="false" extends="ecore_EObject" discriminator-value="EModelElement">
> <meta attribute="eclassName">EModelElement</meta>
> <list name="eAnnotations" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eannotation_emodelelement_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`emodelelement_eannotations_idx`"/>
> <one-to-many entity-name="EAnnotation"/>
> </list>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.ENamedElementImpl" entity-name="ENamedElement" abstract="true" lazy="false" extends="EModelElement" discriminator-value="ENamedElement">
> <meta attribute="eclassName">ENamedElement</meta>
> <property name="name" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`name`"/>
> </property>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.ETypedElementImpl" entity-name="ETypedElement" abstract="true" lazy="false" extends="ENamedElement" discriminator-value="ETypedElement">
> <meta attribute="eclassName">ETypedElement</meta>
> <property name="ordered" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`ordered`"/>
> </property>
> <property name="unique" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`unique`"/>
> </property>
> <property name="lowerBound" lazy="false" insert="true" update="true" not-null="false" unique="false" type="int">
> <column not-null="false" unique="false" name="`lowerbound`"/>
> </property>
> <property name="upperBound" lazy="false" insert="true" update="true" not-null="false" unique="false" type="int">
> <column not-null="false" unique="false" name="`upperbound`"/>
> </property>
> <many-to-one name="eType" entity-name="EClassifier" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`eclassifier_etype_e_id`"/>
> </many-to-one>
> <many-to-one name="eGenericType" entity-name="EGenericType" cascade="all" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`egenerictype_egenerictype_e_id`"/>
> </many-to-one>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EStructuralFeatureImpl" entity-name="EStructuralFeature" abstract="true" lazy="false" extends="ETypedElement" discriminator-value="EStructuralFeature">
> <meta attribute="eclassName">EStructuralFeature</meta>
> <property name="changeable" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`changeable`"/>
> </property>
> <property name="volatile" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`volatile`"/>
> </property>
> <property name="transient" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`transient`"/>
> </property>
> <property name="defaultValueLiteral" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`defaultvalueliteral`"/>
> </property>
> <property name="unsettable" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`unsettable`"/>
> </property>
> <property name="derived" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`derived`"/>
> </property>
> <many-to-one name="eContainingClass" entity-name="EClass" lazy="false" insert="false" update="false" not-null="false">
> <column not-null="false" unique="false" name="`estructuralfeature_econtainingclass_e_id`"/>
> </many-to-one>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EAttributeImpl" entity-name="EAttribute" abstract="false" lazy="false" extends="EStructuralFeature" discriminator-value="EAttribute">
> <meta attribute="eclassName">EAttribute</meta>
> <property name="iD" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`id`"/>
> </property>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EAnnotationImpl" entity-name="EAnnotation" abstract="false" lazy="false" extends="EModelElement" discriminator-value="EAnnotation">
> <meta attribute="eclassName">EAnnotation</meta>
> <property name="source" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`source`"/>
> </property>
> <map name="details" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eannotation_details_e_id`" not-null="false" unique="false"/>
> </key>
> <map-key type="java.lang.String"/>
> <element type="java.lang.String"/>
> </map>
> <many-to-one name="eModelElement" entity-name="EModelElement" lazy="false" insert="false" update="false" not-null="false">
> <column not-null="false" unique="false" name="`eannotation_emodelelement_e_id`"/>
> </many-to-one>
> <list name="contents" table="`eannotation_contents`" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eannotation_e_id`" not-null="true" unique="false"/>
> </key>
> <list-index column="`eannotation_contents_idx`"/>
> <many-to-any id-type="long">
> <column not-null="true" unique="false" name="`contents_type`"/>
> <column not-null="true" unique="false" name="`contents_id`"/>
> </many-to-any>
> </list>
> <list name="references" table="`eannotation_references`" lazy="true">
> <key update="true">
> </key>
> <list-index column="`eannotation_references_idx`"/>
> <column not-null="true" unique="false" name="`references_type`"/>
> <column not-null="true" unique="false" name="`references_id`"/>
> </many-to-any>
> </list>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EClassifierImpl" entity-name="EClassifier" abstract="true" lazy="false" extends="ENamedElement" discriminator-value="EClassifier">
> <property name="instanceClassName" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`instanceclassname`"/>
> </property>
> <property name="instanceTypeName" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`instancetypename`"/>
> </property>
> <many-to-one name="ePackage" entity-name="EPackage" lazy="false" insert="false" update="false" not-null="false">
> <column not-null="false" unique="false" name="`eclassifier_epackage_e_id`"/>
> </many-to-one>
> <list name="eTypeParameters" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eclassifier_etypeparameters_e_id`" not-null="false" unique="false"/>
> </key>
> </list>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EClassImpl" entity-name="EClass" abstract="false" lazy="false" extends="EClassifier" discriminator-value="EClass">
> <meta attribute="eclassName">EClass</meta>
> <property name="abstract" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`abstract`"/>
> </property>
> <property name="interface" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`interface`"/>
> </property>
> <list name="eSuperTypes" lazy="true">
> <key update="true">
> <column name="`eclass_esupertypes_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`eclass_esupertypes_idx`"/>
> <one-to-many entity-name="EClass"/>
> </list>
> <list name="eOperations" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eoperation_econtainingclass_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`eclass_eoperations_idx`"/>
> <one-to-many entity-name="EOperation"/>
> </list>
> <list name="eStructuralFeatures" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`estructuralfeature_econtainingclass_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`eclass_estructuralfeatures_idx`"/>
> <one-to-many entity-name="EStructuralFeature"/>
> </list>
> <list name="eGenericSuperTypes" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eclass_egenericsupertypes_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`eclass_egenericsupertypes_idx`"/>
> <one-to-many entity-name="EGenericType"/>
> </list>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EDataTypeImpl" entity-name="EDataType" abstract="false" lazy="false" extends="EClassifier" discriminator-value="EDataType">
> <meta attribute="eclassName">EDataType</meta>
> <property name="serializable" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`serializable`"/>
> </property>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EEnumImpl" entity-name="EEnum" abstract="false" lazy="false" extends="EDataType" discriminator-value="EEnum">
> <meta attribute="eclassName">EEnum</meta>
> <list name="eLiterals" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eenumliteral_eenum_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`eenum_eliterals_idx`"/>
> <one-to-many entity-name="EEnumLiteral"/>
> </list>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EEnumLiteralImpl" entity-name="EEnumLiteral" abstract="false" lazy="false" extends="ENamedElement" discriminator-value="EEnumLiteral">
> <meta attribute="eclassName">EEnumLiteral</meta>
> <property name="value" lazy="false" insert="true" update="true" not-null="false" unique="false" type="int">
> <column not-null="false" unique="false" name="`value`"/>
> </property>
> <property name="literal" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`literal`"/>
> </property>
> <many-to-one name="eEnum" entity-name="EEnum" lazy="false" insert="false" update="false" not-null="false">
> <column not-null="false" unique="false" name="`eenumliteral_eenum_e_id`"/>
> </many-to-one>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EFactoryImpl" entity-name="EFactory" abstract="false" lazy="false" extends="EModelElement" discriminator-value="EFactory">
> <meta attribute="eclassName">EFactory</meta>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EOperationImpl" entity-name="EOperation" abstract="false" lazy="false" extends="ETypedElement" discriminator-value="EOperation">
> <meta attribute="eclassName">EOperation</meta>
> <column not-null="false" unique="false" name="`eoperation_econtainingclass_e_id`"/>
> </many-to-one>
> <key update="true">
> <column name="`eoperation_etypeparameters_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`eoperation_etypeparameters_idx`"/>
> </list>
> <list name="eParameters" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eparameter_eoperation_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`eoperation_eparameters_idx`"/>
> <one-to-many entity-name="EParameter"/>
> </list>
> <list name="eExceptions" lazy="true">
> <key update="true">
> <column name="`eoperation_eexceptions_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`eoperation_eexceptions_idx`"/>
> <one-to-many entity-name="EClassifier"/>
> </list>
> <list name="eGenericExceptions" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eoperation_egenericexceptions_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`eoperation_egenericexceptions_idx`"/>
> </list>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EPackageImpl" entity-name="EPackage" abstract="false" lazy="false" extends="ENamedElement" discriminator-value="EPackage">
> <meta attribute="eclassName">EPackage</meta>
> <property name="nsURI" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`nsuri`"/>
> </property>
> <property name="nsPrefix" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`nsprefix`"/>
> </property>
> <list name="eClassifiers" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`eclassifier_epackage_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`epackage_eclassifiers_idx`"/>
> </list>
> <list name="eSubpackages" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`epackage_esuperpackage_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`epackage_esubpackages_idx`"/>
> <one-to-many entity-name="EPackage"/>
> </list>
> <many-to-one name="eSuperPackage" entity-name="EPackage" lazy="false" insert="false" update="false" not-null="false">
> <column not-null="false" unique="false" name="`epackage_esuperpackage_e_id`"/>
> </many-to-one>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EParameterImpl" entity-name="EParameter" abstract="false" lazy="false" extends="ETypedElement" discriminator-value="EParameter">
> <meta attribute="eclassName">EParameter</meta>
> <many-to-one name="eOperation" entity-name="EOperation" lazy="false" insert="false" update="false" not-null="false">
> <column not-null="false" unique="false" name="`eparameter_eoperation_e_id`"/>
> </many-to-one>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EReferenceImpl" entity-name="EReference" abstract="false" lazy="false" extends="EStructuralFeature" discriminator-value="EReference">
> <meta attribute="eclassName">EReference</meta>
> <property name="containment" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`containment`"/>
> </property>
> <property name="resolveProxies" lazy="false" insert="true" update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`resolveproxies`"/>
> </property>
> <many-to-one name="eOpposite" entity-name="EReference" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`ereference_eopposite_e_id`"/>
> </many-to-one>
> <list name="eKeys" lazy="true">
> <key update="true">
> <column name="`ereference_ekeys_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`ereference_ekeys_idx`"/>
> <one-to-many entity-name="EAttribute"/>
> </list>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.EGenericTypeImpl" entity-name="EGenericType" abstract="false" lazy="false" extends="ecore_EObject" discriminator-value="EGenericType">
> <meta attribute="eclassName">EGenericType</meta>
> <many-to-one name="eUpperBound" entity-name="EGenericType" cascade="all" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`egenerictype_eupperbound_e_id`"/>
> </many-to-one>
> <list name="eTypeArguments" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`egenerictype_etypearguments_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`egenerictype_etypearguments_idx`"/>
> </list>
> <many-to-one name="eLowerBound" entity-name="EGenericType" cascade="all" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`egenerictype_elowerbound_e_id`"/>
> </many-to-one>
> <many-to-one name="eTypeParameter" entity-name="ETypeParameter" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`etypeparameter_etypeparameter_e_id`"/>
> </many-to-one>
> <many-to-one name="eClassifier" entity-name="EClassifier" lazy="false" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`eclassifier_eclassifier_e_id`"/>
> </many-to-one>
> </subclass>
> <subclass name="org.eclipse.emf.ecore.impl.ETypeParameterImpl" entity-name="ETypeParameter" abstract="false" lazy="false" extends="ENamedElement" discriminator-value="ETypeParameter">
> <meta attribute="eclassName">ETypeParameter</meta>
> <list name="eBounds" lazy="true" cascade="all,delete-orphan">
> <key update="true">
> <column name="`etypeparameter_ebounds_e_id`" not-null="false" unique="false"/>
> </key>
> <list-index column="`etypeparameter_ebounds_idx`"/>
> </list>
> </subclass>
> </hibernate-mapping>
The Netherlands
Content-Type: text/xml;
name="deb_martin.ecore"
Content-Disposition: inline;
filename="deb_martin.ecore"
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<ecore:EPackage name="PrimitiveTypes" nsURI="atl.primitive.type" nsPrefix="ptyp">
<eClassifiers xsi:type="ecore:EDataType" name="Boolean" instanceClassName="boolean"/>
<eClassifiers xsi:type="ecore:EDataType" name="Integer" instanceClassName="int"/>
<eClassifiers xsi:type="ecore:EDataType" name="String" instanceClassName="java.lang.String"/>
</ecore:EPackage>
<ecore:EPackage name="deb" nsURI="my.model.of.debian.package" nsPrefix="deb">
<eClassifiers xsi:type="ecore:EClass" name="Deb">
<eStructuralFeatures xsi:type="ecore:EReference" name="metadata" ordered="false" lowerBound="1" eType="/1/Databin" containment="true" eOpposite="/1/Databin/debpm"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="control" ordered="false" lowerBound="1" eType="/1/Archcontrol" containment="true" eOpposite="/1/Archcontrol/debc"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="data" ordered="false" lowerBound="1" eType="/1/Archdata" containment="true" eOpposite="/1/Archdata/debd"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" ordered="false" unique="false" lowerBound="1" eType="/0/String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Databin">
<eStructuralFeatures xsi:type="ecore:EReference" name="debpm" ordered="false" lowerBound="1" eType="/1/Deb" eOpposite="/1/Deb/metadata"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="blocs" ordered="false" upperBound="-1" eType="/1/Bloc" containment="true" eOpposite="/1/Bloc/meta"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Bloc">
<eStructuralFeatures xsi:type="ecore:EReference" name="meta" ordered="false" lowerBound="1" eType="/1/Databin" eOpposite="/1/Databin/blocs"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="field" ordered="false" upperBound="-1" eType="/1/Field" containment="true" eOpposite="/1/Field/blocs"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Field" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="val" ordered="false" unique="false" lowerBound="1" eType="/0/String"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type" ordered="false" unique="false" lowerBound="1" eType="/0/String"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="blocs" ordered="false" lowerBound="1" eType="/1/Bloc" eOpposite="/1/Bloc/field"/>
</eClassifiers>
<eGenericSuperTypes eClassifier="/1/Field"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="package_name">
</eClassifiers>
</eClassifiers>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Script_descriptions">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Archcontrol">
<eStructuralFeatures xsi:type="ecore:EReference" name="debc" ordered="false" lowerBound="1" eType="/1/Deb" eOpposite="/1/Deb/control"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="scripts" ordered="false" upperBound="-1" eType="/1/Script" containment="true" eOpposite="/1/Script/archscript"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Script">
<eStructuralFeatures xsi:type="ecore:EReference" name="archscript" ordered="false" lowerBound="1" eType="/1/Archcontrol" eOpposite="/1/Archcontrol/scripts"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="script_name" ordered="false" unique="false" lowerBound="1" eType="/0/String"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="code" ordered="false" unique="false" lowerBound="1" eType="/0/String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Archdata">
<eStructuralFeatures xsi:type="ecore:EReference" name="debd" ordered="false" lowerBound="1" eType="/1/Deb" eOpposite="/1/Deb/data"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="fil" ordered="false" upperBound="-1" eType="/1/File" containment="true" eOpposite="/1/File/data"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="File">
<eStructuralFeatures xsi:type="ecore:EReference" name="data" ordered="false" lowerBound="1" eType="/1/Archdata" eOpposite="/1/Archdata/fil"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="filename" ordered="false" unique="false" lowerBound="1" eType="/0/String"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="location" ordered="false" unique="false" lowerBound="1" eType="/0/String"/>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
--------------090608060508000500000906--
Re: [Teneo] Problems with inherited field [message #93257 is a reply to message #93196] Sat, 11 August 2007 09:06 Go to previous messageGo to next message
Before send you the preceding message I have renamed the attached file,
the previous name debFromTeneo.ecore was testdeb.ecore...
But I did not know wy the name of the file is adding here.
I will try your code and tell you If it works...
Guillaume
Martin Taal a écrit :
> was read from the db). Your debFromTeneo.ecore has a view strange sections:
> </eClassifiers>
> </eClassifiers>
> resource which reads the debFromTeneo.ecore (btw, this may not be the
> is that it needs to be done through a resourceset this ensures that the
> packages are placed in the EPackage registry and that this registry is
> read it back. There are a number of calls to convenience methods
> (store.beginTransaction etc.) but for the rest it is pretty simple. This
> production code you should do this. You can try to replicate this simple
> approach and then check if the output is incorrect or correct.
> store.store(o);
> gr. Martin
Re: [Teneo] Problems with inherited field [message #93314 is a reply to message #93257] Mon, 13 August 2007 18:02 Go to previous message
I have try your code, it works fine :)
Once the "ecore:EClass myfile.ecore" removed from the file, all the
problems with the mapping are gone out...
It need more test to see if all works fine, but it seems to be...
thanks a lot !
Guillaume
guillaume a écrit :
> Guillaume
>> Hi,
>> one was read from the db). Your debFromTeneo.ecore has a view strange
>> sections:
>> </eClassifiers>
>> </eClassifiers>
>> the resource which reads the debFromTeneo.ecore (btw, this may not be
>> filesystem is that it needs to be done through a resourceset this
>> and read it back. There are a number of calls to convenience methods
>> in production code you should do this. You can try to replicate this
>> simple approach and then check if the output is incorrect or correct.
>> store.store(o);
>> gr. Martin
Re: [Teneo] Problems with inherited field [message #609446 is a reply to message #92934] Fri, 10 August 2007 10:13 Go to previous message
Hi Guillaume,
gr. Martin
guillaume wrote:
> Hi all,
> at
> works.
> Guillaume Doux
The Netherlands
Re: [Teneo] Problems with inherited field [message #609448 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous message
Hi again,
</eClassifiers>
Guillaume
> Hi Guillaume,
> gr. Martin
> guillaume wrote:
>> Hi all,
>> model.
>> at
>> at
>> at
>> at
>> my model It works.
>> table is
>> create
>> work...
>> solution...
>> Thanks,
>> Guillaume Doux
Re: [Teneo] Problems with inherited field - File 1 of 4 - debFile.ecore (1/1) [message #609449 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous message
Re: [Teneo] Problems with inherited field - File 2 of 4 - debFromTeneo.ecore (1/1) [message #609450 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous message
Re: [Teneo] Problems with inherited field - File 3 of 4 - mappingWithModelFromEcoreFile.xml (1/1) [message #609451 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous message
Re: [Teneo] Problems with inherited field - File 4 of 4 - mappingWithModelFromTeneo.xml (1/1) [message #609452 is a reply to message #92961] Fri, 10 August 2007 10:59 Go to previous message
Re: [Teneo] Problems with inherited field [message #609453 is a reply to message #93005] Fri, 10 August 2007 11:22 Go to previous message
EClassifier.
gr. Martin
guillaume wrote:
> Hi again,
> </eClassifiers>
> Guillaume
>> Hi Guillaume,
>> gr. Martin
>> guillaume wrote:
>>> Hi all,
>>> model.
>>> at
>>> at
>>> at
>>> at
>>> my model It works.
>>> table is
>>> create
>>> work...
>>> solution...
>>> Thanks,
>>> Guillaume Doux
The Netherlands
Re: [Teneo] Problems with inherited field - 1 attachment [message #609455 is a reply to message #93101] Fri, 10 August 2007 12:38 Go to previous message
</meta>
</property>
</property>
</many-to-one>
orphan">
<key update="true">
</key>
</list>
</subclass>
thanks,
Guillaume.
> gr. Martin
> guillaume wrote:
>> Hi again,
>> </eClassifiers>
>> Thanks,
>> Guillaume
>>> Hi Guillaume,
>>> edatatypes, etc.).
>>> gr. Martin
>>> guillaume wrote:
>>>> Hi all,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> my model It works.
>>>> table is
>>>> create
>>>> solution...
>>>> Thanks,
>>>> Guillaume Doux
Re: [Teneo] Problems with inherited field - 1 attachment [message #609458 is a reply to message #93131] Fri, 10 August 2007 21:02 Go to previous message
</eClassifiers>
</eClassifiers>
store.store(o);
gr. Martin
guillaume wrote:
> </meta>
> </property>
> </property>
> </many-to-one>
> orphan">
> <key update="true">
> </key>
> </list>
> </subclass>
> thanks,
> Guillaume.
>> Hi,
>> gr. Martin
>> guillaume wrote:
>>> Hi again,
>>> </eClassifiers>
>>> Thanks,
>>> Guillaume
>>>> Hi Guillaume,
>>>> edatatypes, etc.).
>>>> gr. Martin
>>>> guillaume wrote:
>>>>> Hi all,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> my model It works.
>>>>> table is
>>>>> create
>>>>> solution...
>>>>> Thanks,
>>>>> Guillaume Doux
> </typedef>
> </typedef>
> </typedef>
> </typedef>
> </typedef>
> </typedef>
> </typedef>
> </typedef>
> </typedef>
> </id>
> </version>
> </class>
> <key update="true">
> </key>
> </list>
> </subclass>
> </property>
> </subclass>
> </property>
> </property>
> </property>
> </property>
> </many-to-one>
> </many-to-one>
> </subclass>
> </property>
> </property>
> </property>
> </property>
> </property>
> </property>
> </many-to-one>
> </subclass>
> </property>
> </subclass>
> </property>
> <key update="true">
> </key>
> </map>
> </many-to-one>
> <key update="true">
> </key>
> </many-to-any>
> </list>
> <key update="true">
> </key>
> </many-to-any>
> </list>
> </subclass>
> </property>
> </property>
> </many-to-one>
> <key update="true">
> </key>
> </list>
> </subclass>
> </property>
> </property>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </list>
> </subclass>
> </property>
> </subclass>
> <key update="true">
> </key>
> </list>
> </subclass>
> </property>
> </property>
> </many-to-one>
> </subclass>
> </subclass>
> </many-to-one>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </list>
> </subclass>
> </property>
> </property>
> <key update="true">
> </key>
> </list>
> <key update="true">
> </key>
> </list>
> </many-to-one>
> </subclass>
> </many-to-one>
> </subclass>
> </property>
> </property>
> </many-to-one>
> <key update="true">
> </key>
> </list>
> </subclass>
> </many-to-one>
> <key update="true">
> </key>
> </list>
> </many-to-one>
> </many-to-one>
> </many-to-one>
> </subclass>
> <key update="true">
> </key>
> </list>
> </subclass>
The Netherlands
</ecore:EPackage>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
Re: [Teneo] Problems with inherited field [message #609462 is a reply to message #93196] Sat, 11 August 2007 09:06 Go to previous message
Guillaume
> </eClassifiers>
> </eClassifiers>
> store.store(o);
> gr. Martin
Re: [Teneo] Problems with inherited field [message #609466 is a reply to message #93257] Mon, 13 August 2007 18:02 Go to previous message
thanks a lot !
Guillaume
guillaume a écrit :
> Guillaume
>> Hi,
>> sections:
>> </eClassifiers>
>> </eClassifiers>
>> store.store(o);
>> gr. Martin
Previous Topic:Backward compatibility: SET_FOREIGN_KEY_NAME to false
Next Topic:[Teneo] Turn off lazy-loading
Current Time: Tue Oct 04 08:13:16 GMT 2022
Powered by FUDForum. Page generated in 0.03008 seconds
