Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Unable to find module?
[Acceleo] Unable to find module? [message #791755] Mon, 06 February 2012 08:15 Go to next message
Wilbert Alberts is currently offline Wilbert AlbertsFriend
I'm trying to execute an Acceleo M2T transformation from java. Execution starts but it fails with trowing this exception:
org.eclipse.acceleo.engine.AcceleoEvaluationException: Could not find public template generate in module generate.
	at org.eclipse.acceleo.engine.service.AcceleoService.findTemplates(AcceleoService.java:1084)
	at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoService.java:550)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:193)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.doGenerate(AbstractAcceleoGenerator.java:158)
	at asml.carm.pgwb.pgwb2c.files.Generate.doGenerate(Generate.java:192)
	at asml.carm.pgwb.pgwbm2c.GenerateImplementation.generateCode(GenerateImplementation.java:103)
What I tried: I have two projects, one being a simple Acceleo project containing the actual transformation and one Java project that will be invoking the transformation. The project setup is such that the Java project depends on the Acceleo project.
In order to test this, I just execute a run-time eclipse instance from eclipse. Then when I invoke the java project (via a right-click pop menu entry) I get the exception.
I suspect that I need to configure where to find the templates but how? How should I make these projects depend on each other?
Greetings,
Wilbert.
[Updated on: Mon, 06 February 2012 08:16]
Report message to a moderator
Re: [Acceleo] Unable to find module? [message #792677 is a reply to message #791755] Tue, 07 February 2012 09:14 Go to previous message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
Do you have two templates named "generate"? Are you using Acceleo 3.0.x (you may want to switch to 3.1.2)? Does your Java launcher generated by Acceleo has just a file name for the name of the module (MODULE_NAME = "Yop" and not MODULE_NAME = "com/mydomain/mypackage/myotherpackage/Yop")?
If yes, then Acceleo will look for the first module named "generate" that can be found, it may not be your main module.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Previous Topic:Using Acceleo investigating a model
Next Topic:Syntax clarification.
Current Time: Fri Mar 05 02:05:10 GMT 2021
Powered by FUDForum. Page generated in 0.02039 seconds
