Home » Language IDEs » Java Development Tools (JDT) » unable to launch
Re: unable to launch [message #791137 is a reply to message #790837] |
Sun, 05 February 2012 10:36 |
yasin alm Messages: 3 Registered: February 2012 |
eclipse-jdt is installed, too.Version of both eclipse and jdt is 3.7.1
and this is theconfiguration info;
*** Date: 05 Şubat 2012 Pazar 02:13:15 Doğu Avrupa Saati
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20110909-1335
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-showsplash
/opt/eclipse//plugins/org.eclipse.platform_3.7.1.v201109091335/splash.bmp
-launcher
/opt/eclipse/eclipse
-name
Eclipse
--launcher.library
/opt/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.100.v20110505/eclipse_1407.so
-startup
/opt/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.overrideVmargs
-vm
/opt/sun-jdk/jre/bin/../lib/i386/client/libjvm.so
eclipse.home.location=file:/opt/eclipse/
eclipse.launcher=/opt/eclipse/eclipse
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=PlatformProfile
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1328400758673
eclipse.vm=/opt/sun-jdk/jre/bin/../lib/i386/client/libjvm.so
eclipse.vmargs=-Xms40m
-Xmx384m
-Dorg.eclipse.swt.browser.UseWebKitGTK=true
-XX:MaxPermSize=256m
-Djava.class.path=/opt/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
equinox.use.ds=true
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.version=50.0
java.endorsed.dirs=/opt/sun-jdk/jre/lib/endorsed
java.ext.dirs=/opt/sun-jdk/jre/lib/ext:/usr/java/packages/lib/ext
java.home=/opt/sun-jdk/jre
java.io.tmpdir=/tmp
java.library.path=/opt/sun-jdk/jre/lib/i386/client:/opt/sun-jdk/jre/lib/i386::/usr/java/packages/lib/i386:/lib:/usr/lib
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_26-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=//java.sun.com/
java.vendor.url.bug=//java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_26
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=20.1-b02
line.separator=
org.eclipse.equinox.launcher.splash.location=/opt/eclipse//plugins/org.eclipse.platform_3.7.1.v201109091335/splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=tr
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.37.6
org.osgi.framework.processor=x86
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=208cde1d-8e4f-0011-1d14-f0a318d2a534
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.6.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=i386
os.name=Linux
os.version=2.6.37.6
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.equinox.simpleconfigurator_1.0.200.v20110502-1955.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/home/almalioglu/.eclipse/org.eclipse.platform_3.7.0_1473617060/configuration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/home/almalioglu/.eclipse/org.eclipse.platform_3.7.0_1473617060/configuration/
osgi.framework=file:/opt/eclipse/plugins/org.eclipse.osgi_3.7.1.R37x_v20110808-1106.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.7.1.R37x_v20110808-1106
osgi.install.area=file:/opt/eclipse/
osgi.instance.area=file:/home/almalioglu/EclipseBench/
osgi.instance.area.default=file:/home/almalioglu/workspace/
osgi.logfile=/home/almalioglu/EclipseBench/.metadata/.log
osgi.manifest.cache=/home/almalioglu/.eclipse/org.eclipse.platform_3.7.0_1473617060/configuration/org.eclipse.osgi/manifests
osgi.nl=tr_TR
osgi.os=linux
osgi.sharedConfiguration.area=file:/opt/eclipse/configuration/
osgi.splashLocation=/opt/eclipse//plugins/org.eclipse.platform_3.7.1.v201109091335/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/opt/eclipse/plugins
osgi.tracefile=/home/almalioglu/EclipseBench/.metadata/trace.log
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/opt/sun-jdk/jre/lib/resources.jar:/opt/sun-jdk/jre/lib/rt.jar:/opt/sun-jdk/jre/lib/sunrsasign.jar:/opt/sun-jdk/jre/lib/jsse.jar:/opt/sun-jdk/jre/lib/jce.jar:/opt/sun-jdk/jre/lib/charsets.jar:/opt/sun-jdk/jre/lib/modules/jdk.boot.jar:/opt/sun-jdk/jre/classes
sun.boot.library.path=/opt/sun-jdk/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=unknown
user.country=TR
user.dir=/home/almalioglu/Belgeler
user.home=/home/almalioglu
user.language=tr
user.name=almalioglu
user.timezone=Europe/Istanbul
*** Features:
org.eclipse.help (1.3.0.v20110327-7i7uFFkFFp7gNobOpNgKo0) "Help System Base"
org.eclipse.platform (3.7.1.r37x_v20110729-9gF7UHOxFtniV7mI3T556iZN9AU8bEZ1lHMcVK) "Eclipse Platform"
org.eclipse.rcp (3.7.1.r37x_v20110729-9DB5FmNFnFLSFCtLxnRfMqt15A4A) "Eclipse RCP"
*** Plug-in Registry:
com.ibm.icu (4.4.2.v20110208) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v201101211617) "JSch" [Resolved]
javax.servlet (2.5.0.v201103041518) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v201101211617) "Java Server Pages API Bundle" [Resolved]
org.apache.ant (1.8.2.v20110505-1300) "Apache Ant" [Resolved]
org.apache.commons.codec (1.3.0.v201101211617) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.el (1.0.0.v201101211617) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v201012070820) "Apache Commons Httpclient" [Resolved]
org.apache.commons.logging (1.0.4.v201101211617) "Apache Commons Logging Plug-in" [Resolved]
org.apache.jasper (5.5.17.v201101211617) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.lucene (2.9.1.v201101211721) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (2.9.1.v201101211721) "Apache Lucene Analysis" [Resolved]
org.apache.lucene.core (2.9.1.v201101211721) "Apache Lucene Core" [Resolved]
org.eclipse.ant.core (3.2.300.v20110511) "Ant Build Tool Core" [Starting]
org.eclipse.compare (3.5.201.R37x_v20110817-0800) "Compare Support" [Starting]
org.eclipse.compare.core (3.5.200.I20110208-0800) "Core Compare Support" [Active]
org.eclipse.core.boot (3.1.200.v20100505) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20110111-0800) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20110423-0524) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.4.0.I20110111-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.100.I20100824-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.4.0.I20110222-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.4.0.I20110222-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.300.v20110228) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.100.v20110506) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.200.v20110505-0800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.100.v20110423-0524) "Core File Systems" [Active]
org.eclipse.core.filesystem.linux.x86 (1.4.0.v20110423-0524) "Core File System for Linux" [Resolved]
org.eclipse.core.jobs (3.5.100.v20110404) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20110511-0800) "Internet Connection Management" [Active]
org.eclipse.core.net.linux.x86 (1.1.200.I20110419-0800) "Proxy for Linux" [Resolved]
org.eclipse.core.resources (3.7.100.v20110510-0712) "Core Resource Management" [Active]
org.eclipse.core.runtime (3.7.0.v20110110) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.100.v20100505) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.200.v20110110) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.5.0.v20110505) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.500.v20110511) "Core Variables" [Starting]
org.eclipse.debug.core (3.7.0.v20110518) "Debug Core" [Starting]
org.eclipse.debug.ui (3.7.101.v20110817_r371) "Debug UI" [Starting]
org.eclipse.ecf (3.1.300.v20110531-2218) "ECF Core API" [Active]
org.eclipse.ecf.filetransfer (5.0.0.v20110531-2218) "ECF Filetransfer API" [Active]
org.eclipse.ecf.identity (3.1.100.v20110531-2218) "ECF Core Identity API" [Active]
org.eclipse.ecf.provider.filetransfer (3.2.0.v20110531-2218) "ECF Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient (4.0.0.v20110531-2218) "ECF HttpClient Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20110531-2218) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20110531-2218) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.100.v20110531-2218) "ECF Core API" [Resolved]
org.eclipse.equinox.app (1.3.100.v20110321) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.6.0.v20110523) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.0.200.v20110502) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.3.1.R37x_v20110701) "Declarative Services" [Active]
org.eclipse.equinox.event (1.2.100.v20110502) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.0.v20110502-1955) "Equinox Framework Admin" [Starting]
org.eclipse.equinox.frameworkadmin.equinox (1.0.300.v20110506) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (2.0.100.v20110502) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.100.v20110502) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.200.v20110502) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.300.v20110502) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.200.v20100503) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.2.0.v20110502) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.gtk.linux.x86 (1.1.100.v20110505) "Equinox Launcher Linux X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.101.R37x_v20110714) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.300.v20110502-1955) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.1.0.v20110502-1955) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.1.0.v20110504-1715) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.300.v20110505) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.300.v20110502-1955) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (2.1.0.v20110511) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.100.v20110510) "Equinox Provisioning Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.200.v20110510) "Equinox Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.200.v20110502-1955) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.1.0.v20110510) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.2.0.v20110511-1359) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.1.0.v20110511-1821) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.publisher (1.2.0.v20110511) "Equinox Provisioning Publisher Infrastructure" [Starting]
org.eclipse.equinox.p2.publisher.eclipse (1.0.0.v20110511) "Equinox Provisioning Publisher for Eclipse" [Starting]
org.eclipse.equinox.p2.ql (2.0.100.v20110510) "Equinox Provisioning p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.100.v20110510) "Equinox Provisioning Drop-in" [Active]
org.eclipse.equinox.p2.repository (2.1.0.v20110601) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.0.100.v20110512-1320) "Equinox Provisioning Repository Tools" [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.1.1.R37x_v20110815-0935) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.0.300.v20110502-1955) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.transport.ecf (1.0.0.v20110510) "Equinox Provisioning ECF based Transport" [Active]
org.eclipse.equinox.p2.ui (2.1.0.v20110601) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.importexport (1.0.0.v20110511) "Equinox Provisioning Import and Export" [Starting]
org.eclipse.equinox.p2.ui.sdk (1.0.200.v20110502-1955) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.100.v20110502-1955) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.200.v20110502-1955) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.300.v20110510) "Equinox Provisioning Legacy Update Site Support" [Starting]
org.eclipse.equinox.preferences (3.4.1.R37x_v20110725) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.101.R37x_v20110810-1611) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.1.1.R37x_v20110822-1018) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.1.0.v20101004) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.simpleconfigurator (1.0.200.v20110502-1955) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20110502-1955) "Simple Configurator Manipulator" [Starting]
org.eclipse.equinox.util (1.0.300.v20110502) "Equinox Util Bundle" [Active]
org.eclipse.help (3.5.100.v20110426) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20110425) "Help Application Server" [Starting]
org.eclipse.help.base (3.6.1.v201109091335) "Help System Base" [Starting]
org.eclipse.help.ui (3.5.101.r37_20110819) "Help System UI" [Starting]
org.eclipse.help.webapp (3.6.0.v20110518) "Help System Webapp" [Starting]
org.eclipse.jface (3.7.0.I20110522-1430) "JFace" [Active]
org.eclipse.jface.databinding (1.5.0.I20100907-0800) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.7.1.r371_v20110825-0800) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.1.300.I20110514-0800) "JSch Core" [Starting]
org.eclipse.jsch.ui (1.1.300.I20110511-0800) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.5.201.r371_v20110824-0800) "Refactoring Core" [Starting]
org.eclipse.ltk.ui.refactoring (3.6.0.v20110505-0800) "Refactoring UI" [Starting]
org.eclipse.osgi (3.7.1.R37x_v20110808-1106) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.3.0.v20110513) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.util (3.2.200.v20110110) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.platform (3.7.1.v201109091335) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (3.7.0.v20110601-0800) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.rcp (3.7.0.v201109091335) "Eclipse RCP" [Starting]
org.eclipse.search (3.7.0.v20110505-0800) "Search Support" [Starting]
org.eclipse.swt (3.7.1.v3738a) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86 (3.7.1.v3738a) "Standard Widget Toolkit for GTK 2.0" [Resolved]
org.eclipse.team.core (3.6.0.I20110525-0800) "Team Support Core" [Active]
org.eclipse.team.ui (3.6.100.I20110525-0800) "Team Support UI" [Starting]
org.eclipse.text (3.5.101.r371_v20110810-0800) "Text" [Resolved]
org.eclipse.ui (3.7.0.I20110602-0100) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.3.100.v20110426) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.4.100.v20110425) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.5.100.v20110511) "Console" [Active]
org.eclipse.ui.editors (3.7.0.v20110517-0800) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.2.0.v20110506) "External Tools" [Starting]
org.eclipse.ui.forms (3.5.100.v20110425) "Eclipse Forms" [Starting]
org.eclipse.ui.ide (3.7.0.v20110809-1737) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.300.I20110306-2000) "Eclipse IDE UI Application" [Resolved]
org.eclipse.ui.intro (3.4.100.v20110425) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.500.v20110510) "Universal Welcome" [Starting]
org.eclipse.ui.navigator (3.5.100.v20110809-2227) "Common Navigator View" [Starting]
org.eclipse.ui.navigator.resources (3.4.300.I20110421-1800) "Navigator Workbench Components" [Starting]
org.eclipse.ui.net (1.2.100.I20110511-0800) "Internet Connection Management UI" [Active]
org.eclipse.ui.presentations.r21 (3.2.200.I20100517-1500) "R21 Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.6.0.I20110412-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.5.200.I20110201-0800) "Tabbed Properties View" [Starting]
org.eclipse.ui.workbench (3.7.0.I20110519-0100) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.100.I20110413-1600) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.7.0.v20110505-0800) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.3.100.v20100512) "Install/Update Configurator" [Active]
org.eclipse.update.core (3.2.500.v20110330) "Install/Update Core" [Active]
org.eclipse.update.core.linux (3.2.200.v20100512) "Install/Update Core for Linux" [Resolved]
org.eclipse.update.scheduler (3.2.300.v20100512) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.2.300.v20100512) "Install/Update UI" [Starting]
org.mortbay.jetty.server (6.1.23.v201012071420) "Jetty Server" [Resolved]
org.mortbay.jetty.util (6.1.23.v201012071420) "Jetty Utilities" [Resolved]
org.sat4j.core (2.3.0.v20110329) "SAT4J Core" [Resolved]
org.sat4j.pb (2.3.0.v20110329) "SAT4J Pseudo" [Resolved]
*** User Preferences:
#Sun Feb 05 02:13:17 EET 2012
/bundle_defaults/org.eclipse.core.resources/description.buildorder=
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time=false
/bundle_defaults/org.eclipse.ui.editors/othersIndicationInOverviewRuler=false
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_R/uri=http\://download.eclipse.org/technology/epp/packages/indigo/R/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_categories/uri=http\://download.eclipse.org/eclipse/updates/3.7/categories
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_R/name=Feature
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201109230900/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0" encoding\="UTF-8"?>\n<editors version\="3.1">\n<info extension\="html" name\="*">\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\n</info>\n<info extension\="htm" name\="*">\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\n</info>\n<info extension\="shtml" name\="*">\n<editor id\="org.eclipse.ui.browser.editorSupport"/>\n</info>\n</editors>
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_SR1/isSystem=true
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInOverviewRuler=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_updates_releases/isSystem=false
/instance/org.eclipse.ui.workbench/<Java>_persp=<?xml version\="1.0" encoding\="UTF-8"?>\n<perspective editorAreaTrimState\="2" editorAreaVisible\="1" fixed\="0" version\="0.016">\n<descriptor descriptor\="org.eclipse.jdt.ui.JavaPerspective" id\="<Java>" label\="<Java>"/>\n<window height\="546" width\="1024" x\="0" y\="0"/>\n<alwaysOnActionSet id\="org.eclipse.ui.cheatsheets.actionSet"/>\n<alwaysOnActionSet id\="org.eclipse.search.searchActionSet"/>\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.annotationNavigation"/>\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\n<alwaysOnActionSet id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo"/>\n<alwaysOnActionSet id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\n<alwaysOnActionSet id\="org.eclipse.ui.actionSet.keyBindings"/>\n<alwaysOnActionSet id\="org.eclipse.ui.actionSet.openFiles"/>\n<alwaysOnActionSet id\="org.eclipse.debug.ui.launchActionSet"/>\n<alwaysOnActionSet id\="org.eclipse.ui.NavigateActionSet"/>\n<alwaysOnActionSet id\="org.eclipse.debug.ui.breakpointActionSet"/>\n<alwaysOnActionSet id\="org.eclipse.debug.ui.debugActionSet"/>\n<show_view_action id\="org.eclipse.jdt.ui.PackageExplorer"/>\n<show_view_action id\="org.eclipse.jdt.ui.TypeHierarchy"/>\n<show_view_action id\="org.eclipse.jdt.ui.SourceView"/>\n<show_view_action id\="org.eclipse.jdt.ui.JavadocView"/>\n<show_view_action id\="org.eclipse.search.ui.views.SearchView"/>\n<show_view_action id\="org.eclipse.ui.console.ConsoleView"/>\n<show_view_action id\="org.eclipse.ui.views.ContentOutline"/>\n<show_view_action id\="org.eclipse.ui.views.ProblemView"/>\n<show_view_action id\="org.eclipse.ui.views.ResourceNavigator"/>\n<show_view_action id\="org.eclipse.ui.views.TaskList"/>\n<show_view_action id\="org.eclipse.ui.views.ProgressView"/>\n<show_view_action id\="org.eclipse.ui.navigator.ProjectExplorer"/>\n<show_view_action id\="org.eclipse.ui.texteditor.TemplatesView"/>\n<show_view_action id\="org.eclipse.pde.runtime.LogView"/>\n<show_view_action id\="org.eclipse.ant.ui.views.AntView"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.JavaProjectWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewPackageCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewInterfaceCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewEnumCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewAnnotationCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewSourceFolderCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewSnippetFileCreationWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.ui.wizards.NewJavaWorkingSetWizard"/>\n<new_wizard_action id\="org.eclipse.ui.wizards.new.folder"/>\n<new_wizard_action id\="org.eclipse.ui.wizards.new.file"/>\n<new_wizard_action id\="org.eclipse.ui.editors.wizards.UntitledTextFileWizard"/>\n<new_wizard_action id\="org.eclipse.jdt.junit.wizards.NewTestCaseCreationWizard"/>\n<perspective_action id\="org.eclipse.jdt.ui.JavaBrowsingPerspective"/>\n<perspective_action id\="org.eclipse.debug.ui.DebugPerspective"/>\n<hide_toolbar_item_id id\="org.eclipse.jdt.ui.actions.OpenProjectWizard"/>\n<hide_toolbar_item_id id\="org.eclipse.ui.edit.text.toggleShowSelectedElementOnly"/>\n<view id\="org.eclipse.ui.views.ResourceNavigator"/>\n<view id\="org.eclipse.ui.views.ProblemView"/>\n<view id\="org.eclipse.search.ui.views.SearchView"/>\n<view id\="org.eclipse.debug.ui.DebugView"/>\n<view id\="org.eclipse.ui.console.ConsoleView"/>\n<view id\="org.eclipse.ui.views.ContentOutline"/>\n<fastViewBars/>\n<layout>\n<mainWindow>\n<info folder\="true" part\="left">\n<folder activePageID\="org.eclipse.ui.views.ResourceNavigator" appearance\="2" expanded\="2">\n<page content\="org.eclipse.ui.views.ResourceNavigator" label\="Navigator"/>\n<page content\="org.eclipse.jdt.ui.PackageExplorer" label\="LabelNotFound"/>\n<page content\="org.eclipse.jdt.ui.TypeHierarchy" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.navigator.ProjectExplorer" label\="LabelNotFound"/>\n<page content\="org.eclipse.jdt.junit.ResultView" label\="LabelNotFound"/>\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\n<part id\="0"/>\n</presentation>\n</folder>\n</info>\n<info folder\="true" part\="stickyFolderRight" ratio\="0.7495049" ratioLeft\="757" ratioRight\="253" relationship\="2" relative\="left">\n<folder appearance\="2" expanded\="2">\n<page content\="org.eclipse.help.ui.HelpView" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.internal.introview" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.cheatsheets.views.CheatSheetView" label\="LabelNotFound"/>\n</folder>\n</info>\n<info part\="org.eclipse.ui.editorss" ratio\="0.18272096" ratioLeft\="184" ratioRight\="823" relationship\="2" relative\="left"/>\n<info folder\="true" part\="bottom" ratio\="0.38173303" ratioLeft\="163" ratioRight\="264" relationship\="4" relative\="org.eclipse.ui.editorss">\n<folder activePageID\="org.eclipse.ui.console.ConsoleView" appearance\="2" expanded\="2">\n<page content\="org.eclipse.ui.views.ProblemView" label\="Problems"/>\n<page content\="org.eclipse.search.ui.views.SearchView" label\="Search"/>\n<page content\="org.eclipse.debug.ui.DebugView" label\="Debug"/>\n<page content\="org.eclipse.ui.console.ConsoleView" label\="Console"/>\n<page content\="org.eclipse.jdt.ui.JavadocView" label\="LabelNotFound"/>\n<page content\="org.eclipse.jdt.ui.SourceView" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.views.BookmarkView" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.views.ProgressView" label\="LabelNotFound"/>\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\n<part id\="0"/>\n<part id\="1"/>\n<part id\="2"/>\n<part id\="3"/>\n</presentation>\n</folder>\n</info>\n<info folder\="true" part\="right" ratio\="0.74934036" ratioLeft\="568" ratioRight\="190" relationship\="2" relative\="org.eclipse.ui.editorss">\n<folder activePageID\="org.eclipse.ui.views.ContentOutline" appearance\="2" expanded\="2">\n<page content\="org.eclipse.ui.views.ContentOutline" label\="Outline"/>\n<page content\="org.eclipse.ant.ui.views.AntView" label\="LabelNotFound"/>\n<page content\="org.eclipse.ui.texteditor.TemplatesView" label\="LabelNotFound"/>\n<presentation id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory">\n<part id\="0"/>\n</presentation>\n</folder>\n</info>\n</mainWindow>\n</layout>\n</perspective>
/bundle_defaults/org.eclipse.ui.editors/quickdiff.nowarn.before.switch=
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_gmf_updates_milestones/enabled=false
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/schedule=on-startup
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.dropdown=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_SR1/suffix=content.xml
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_windowbuilder_WB_integration_3.7/enabled=false
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.updateInterval=500
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/bundle_defaults/org.eclipse.ui.editors/quickdiff.quickDiff=true
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.previous=false
/bundle_defaults/org.eclipse.ui.editors/showFilteredSearchResultInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Navigation.SmartHomeEnd=true
/instance/org.eclipse.debug.ui/preferredDetailPanes=DefaultDetailPane\:DefaultDetailPane|org.eclipse.jdt.debug.ui.DETAIL_PANE_LINE_BREAKPOINT\:org.eclipse.jdt.debug.ui.DETAIL_PANE_LINE_BREAKPOINT|
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201109230900/isSystem=false
/bundle_defaults/org.eclipse.ui/LINK_NAVIGATOR_TO_EDITOR=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_subversive_0.7_update-site/enabled=false
/bundle_defaults/org.eclipse.ui.editors/taskTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui/SHIFT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifierMask=262144
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_xpand_updates/isSystem=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.text=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_cdt_releases_indigo/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7-201106131736/uri=http\://download.eclipse.org/eclipse/updates/3.7/R-3.7-201106131736
/bundle_defaults/org.eclipse.ui.workbench/ENABLED_DECORATORS=
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7-201106131736/version=1.0.0
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/printMargin=false
/bundle_defaults/org.eclipse.ui.ide/LIMIT_BOOKMARKS=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_egit_updates/enabled=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.color=50,70,120
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_opt_eclipse_.eclipseextension/isSystem=true
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndication=true
/instance/org.eclipse.debug.ui/preferredTargets=default\:default|
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_home_almalioglu_.eclipse_org.eclipse.platform_3.7.0_1473617060_configuration_org.eclipse.osgi_bundles_79_data_listener_1925729951/uri=file\:/home/almalioglu/.eclipse/org.eclipse.platform_3.7.0_1473617060/configuration/org.eclipse.osgi/bundles/79/data/listener_1925729951/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_ptp_updates_indigo/enabled=false
/bundle_defaults/org.eclipse.ui.editors/currentIPOverviewRuler=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.jdt.debug.ui.javaDebug.alertHCRFailed=false
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToPreviousNavigationTarget=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo/name=EPP Packages Repository
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_opt_eclipse_.eclipseextension/name=/opt/eclipse/.eclipseextension
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_emft_updates/isSystem=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS_BOOLEAN=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_gmf_updates_milestones/uri=http\://download.eclipse.org/modeling/gmf/updates/milestones/
/bundle_defaults/org.eclipse.ui.editors/textDragAndDropEnabled=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_SR1/name=Feature
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_egit_updates/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7/nickname=The Eclipse Project Updates
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__eclipse.org_modeling_emft_updates/uri=http\:eclipse.org/modeling/emft/updates/
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/hasAuth=false
/bundle_defaults/org.eclipse.ui.editors/secondaryIPTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionForeground.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/linked.exit.verticalruler=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_mylyn_releases_3.6/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_home_almalioglu_.eclipse_org.eclipse.platform_3.7.0_1473617060_configuration_org.eclipse.osgi_bundles_79_data_listener_1925729951/isSystem=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.width=
/instance/org.eclipse.jdt.ui/breadcrumb.org.eclipse.jdt.ui.JavaPerspective=true
/bundle_defaults/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=prompt
/bundle_defaults/org.eclipse.ui.editors/changeIndication=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201106220900/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_categories/enabled=false
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.debug.sourceFile=generate
/instance/org.eclipse.core.resources/version=1
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.enumIdentifier=error
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_LIMIT=100
/bundle_defaults/org.eclipse.ui.editors/searchResultTextStyle=NONE
/bundle_defaults/org.eclipse.core.net/nonProxiedHosts=localhost|127.0.0.1
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/showInfoInNextPrevDropdownToolbarAction=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocations.migrated=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_updates_udc/uri=http\://download.eclipse.org/technology/epp/updates/udc/
/bundle_defaults/org.eclipse.ui.editors/linked.slave.verticalruler=false
/bundle_defaults/org.eclipse.ui.ide/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.editors/showTaskInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.showMax=false
/bundle_defaults/org.eclipse.ui.editors/infoIndicationHighlighting=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__dev.eclipse.org_svnroot_dsdp_org.eclipse.tm.tcf_releases_0.4.0/uri=http\://dev.eclipse.org/svnroot/dsdp/org.eclipse.tm.tcf/releases/0.4.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_emft_mwe_updates/isSystem=false
/bundle_defaults/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_CREATION=prompt
/instance/org.eclipse.jdt.ui/fontPropagated=true
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background=255,255,255
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToNextNavigationTarget=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_emft_updates/enabled=false
/bundle_defaults/org.eclipse.ui.editors/taskIndicationColor=0,128,255
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201109230900/enabled=true
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/errorIndicationColor=255,0,128
/bundle_defaults/org.eclipse.ui/RECENTLY_USED_WORKINGSETS_SIZE=5
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/bundle_defaults/org.eclipse.ui.ide/TASKS_LIMIT=100
/bundle_defaults/org.eclipse.core.resources/description.applyfilestatepolicy=true
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationColor=34,164,99
/instance/org.eclipse.ui.workbench/RUN_IN_BACKGROUND=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201106220900/enabled=false
/bundle_defaults/org.eclipse.ui.editors/printMarginColor=176,180,185
@org.eclipse.ui=3.7.0.I20110602-0100
/bundle_defaults/org.eclipse.core.resources/description.defaultbuildorder=true
/bundle_defaults/org.eclipse.ui.editors/taskIndication=false
/bundle_defaults/org.eclipse.ui.editors/warningIndication=true
/bundle_defaults/org.eclipse.ui/SHOW_MULTIPLE_EDITOR_TABS=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_jwt_update-site/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_orbit_downloads_drops_R20100519200754_repository/uri=http\://download.eclipse.org/tools/orbit/downloads/drops/R20100519200754/repository
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationColor=0,0,0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_mylyn_update_e3.4/uri=http\://download.eclipse.org/tools/mylyn/update/e3.4/
/bundle_defaults/org.eclipse.ui.editors/showTrailingSpaces=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_windowbuilder_WB_integration_3.7/uri=http\://download.eclipse.org/windowbuilder/WB/integration/3.7
/instance/org.eclipse.help.base/always_external_browser=false
/bundle_defaults/org.eclipse.ui.editors/show_range_indicator=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToPreviousNavigationTarget=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_updates/enabled=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo/description=
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInVerticalRuler=true
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/bundle_defaults/org.eclipse.ui.ide/saveInterval=5
/bundle_defaults/org.eclipse.ui.ide/USE_MARKER_LIMITS=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo_R/isSystem=true
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.dropdown=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__eclipse.org_modeling_mdt_?project\=papyrus\#papyrus/isSystem=false
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowRevision=false
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.compliance=1.6
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_categories/version=1.0.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__eclipse.org_modeling_updates/uri=http\:eclipse.org/modeling/updates/
/bundle_defaults/org.eclipse.ui/showIntro=true
/instance/org.eclipse.debug.core/org.eclipse.debug.core.PREF_DELETE_CONFIGS_ON_PROJECT_DELETE=false
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/port=-1
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7.1-201109091335/suffix=content.xml
/instance/org.eclipse.help.base/help_view_open_mode=in_place
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_mdt_updates/uri=http\://download.eclipse.org/modeling/mdt/updates/
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.debug.localVariable=generate
/bundle_defaults/org.eclipse.ui.editors/showErrorInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.core.resources/description.filestatelongevity=604800000
/bundle_defaults/org.eclipse.ui/CLOSE_EDITORS_ON_EXIT=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_datatools_updates/uri=http\://download.eclipse.org/datatools/updates
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_emft_updates/uri=http\://download.eclipse.org/technology/emft/updates/
/bundle_defaults/org.eclipse.ui.editors/linked.focus.verticalruler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.overviewruler=false
/bundle_defaults/org.eclipse.ui.editors/spellingEnabled=false
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.DebugVieworg.eclipse.debug.ui.DebugView=<?xml version\="1.0" encoding\="UTF-8"?>\n<DebugViewMemento org.eclipse.debug.ui.BREADCRUMB_DROPDOWN_AUTO_EXPAND\="false"/>
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_updates/isSystem=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.FindScope=185,176,180
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201109230900/version=1.0.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7-201106131736/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_mdt_papyrus_updates_milestones_0.8/uri=http\://download.eclipse.org/modeling/mdt/papyrus/updates/milestones/0.8
/bundle_defaults/org.eclipse.ui.editors/linked.target.highlight=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo_201106220900/version=1.0.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_xpand_updates/uri=http\://download.eclipse.org/modeling/m2t/xpand/updates/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_m2t_updates_releases/uri=http\://download.eclipse.org/modeling/m2t/updates/releases/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_mat_1.1_update-site/enabled=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_opt_eclipse_.eclipseextension/description=
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationColor=88,88,22
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToNextNavigationTarget=false
/project/lab/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.6
/bundle_defaults/org.eclipse.ui.editors/secondaryIPHighlight=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_templates_migrated=true
/bundle_defaults/org.eclipse.ui.editors/linked.slave.overviewruler=false
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST_TIME=1000
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/bundle_defaults/org.eclipse.ui.editors/showBookmarkInNextPrevDropdownToolbarAction=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_releases_indigo/type=org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository
/bundle_defaults/org.eclipse.ui.editors/showUnchangedInNextPrevDropdownToolbarAction=false
/configuration/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_mylyn_releases_3.6/uri=http\://download.eclipse.org/mylyn/releases/3.6
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo/suffix=compositeContent.xml
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_sequoyah_updates_2.0/uri=http\://download.eclipse.org/sequoyah/updates/2.0/
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_cdt_releases_indigo/uri=http\://download.eclipse.org/tools/cdt/releases/indigo
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToNextNavigationTarget=false
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/bundle_defaults/org.eclipse.ui.editors/hyperlinksEnabled=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.next=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7/type=org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository
/bundle_defaults/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=false
/instance/org.eclipse.ui.workbench/STICKY_CYCLE=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_gef_updates_releases/uri=http\://download.eclipse.org/tools/gef/updates/releases
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToNextNavigationTarget=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_objectteams_updates_2.0/uri=http\://download.eclipse.org/objectteams/updates/2.0
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_epp_packages_indigo/provider=
/bundle_defaults/org.eclipse.ui.editors/searchResultHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationColor=237,237,252
/bundle_defaults/org.eclipse.core.resources/snapshots.operations=100
/bundle_defaults/org.eclipse.ui/USE_WINDOW_WORKING_SET_BY_DEFAULT=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_eclipse_updates_3.7_R-3.7-201106131736/isSystem=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_mdt_papyrus_updates_releases/isSystem=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_objectteams_updates_2.0/enabled=false
/bundle_defaults/org.eclipse.ui.editors/currentLineColor=232,242,254
/bundle_defaults/org.eclipse.ui.editors/deletionIndication=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder.resourceCopyExclusionFilter=
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/infoIndication=false
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_technology_subversive_0.7_update-site/uri=http\://download.eclipse.org/technology/subversive/0.7/update-site/
/bundle_defaults/org.eclipse.ui/SHOW_FILTERED_TEXTS=true
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_opt_eclipse_.eclipseextension/suffix=eclipse
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/day=Every day
/profile/file\:\\2fhome\\2falmalioglu\\2f.eclipse\\2forg.eclipse.platform_3.7.0_1473617060\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_datatools_updates/isSystem=false
/profile/f
[Updated on: Sun, 05 February 2012 10:44] Report message to a moderator
Current Time: Thu Apr 25 20:42:21 GMT 2024
Powered by FUDForum. Page generated in 0.04401 seconds
