Home » Eclipse Projects » Remote Application Platform (RAP) » java.util.MissingResourceException occured after changing to RAP1.5M5(rap 1.5 m5)
java.util.MissingResourceException occured after changing to RAP1.5M5 [message #790279] Sat, 04 February 2012 02:35 Go to next message
David Song is currently offline David SongFriend
hi all,
I change the rap runtime 1.5M5 for my app. It works well in eclipse ide develop environment but when I deploy to jboss as 7.02, and it also works on the rap runtime 1.5M4, but an exception message occured on the new version 1.5M5;
!ENTRY org.eclipse.osgi 4 0 2012-02-04 10:09:59.053
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
java.util.MissingResourceException: Resource bundle not found for locale: zh_CN
	at org.eclipse.core.internal.runtime.Activator.getLocalization(Activator.java:243)
!ENTRY org.eclipse.equinox.http.registry 4 0 2012-02-04 10:09:59.054
!MESSAGE FrameworkEvent ERROR
!STACK 0
and I already put the Babel Language Packs(RAP zh_CN) labs to the classpath.
David
[Updated on: Mon, 06 February 2012 14:08]
Report message to a moderator
Re: java.util.MissingResourceException occured after changing to RAP1.5M5 [message #792391 is a reply to message #790279] Tue, 07 February 2012 00:11 Go to previous messageGo to next message
Steve Robenalt is currently offline Steve RobenaltFriend
I had the same problem with Tomcat 7 and the en_US locale. I was able to fix it by commenting out -registryMultiLanguage in the web.xml, which I believe worked only because I haven't internationalized the app yet. If you are expecting to internationalize, you may want to review the steps in the RAP help guide and make sure they are all in place.
Re: java.util.MissingResourceException occured after changing to RAP1.5M5 [message #792394 is a reply to message #790279] Tue, 07 February 2012 00:11 Go to previous messageGo to next message
Re: java.util.MissingResourceException occured after changing to RAP1.5M5 [message #793104 is a reply to message #792394] Tue, 07 February 2012 19:38 Go to previous messageGo to next message
Arnaud MERGEY is currently offline Arnaud MERGEYFriend
I also have similar issue after switching from 1.5 M4 to 1.5 M5. I have tested with same code, in M4 the RAP launcher launch my app without any issue, and it does not work anymore if I switch my target platform to M5 with following exception.
In my case I have this exception even by launching RAP from eclipse, it seems to occurs if the application uses configuration admin osgi service or declarative service, and it is definitely caused by some changes introduced 1.5 M5, so maybe related to equinox juno and not rap ?
java.util.MissingResourceException: Resource bundle not found for locale: fr
at org.eclipse.core.internal.runtime.ResourceTranslator.getResourceBundle(ResourceTranslator.java:69)
at org.eclipse.core.internal.runtime.ResourceTranslator.getResourceString(ResourceTranslator.java:76)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.translate(RegistryStrategyOSGI.java:106)
at org.eclipse.core.internal.registry.ExtensionRegistry.translate(ExtensionRegistry.java:1379)
at org.eclipse.core.internal.registry.ConfigurationElementMulti.getTranslatedAtIndex(ConfigurationElementMulti.java:64)
at org.eclipse.core.internal.registry.ConfigurationElementMulti.getAttribute(ConfigurationElementMulti.java:47)
at org.eclipse.core.internal.registry.ConfigurationElementMulti.getAttribute(ConfigurationElementMulti.java:111)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getAttribute(ConfigurationElementHandle.java:34)
at org.eclipse.equinox.http.registry.internal.ServletManager.added(ServletManager.java:112)
at org.eclipse.equinox.http.registry.internal.ExtensionPointTracker.open(ExtensionPointTracker.java:75)
at org.eclipse.equinox.http.registry.internal.ServletManager.start(ServletManager.java:62)
at org.eclipse.equinox.http.registry.internal.HttpRegistryManager.start(HttpRegistryManager.java:106)
at org.eclipse.equinox.http.registry.internal.HttpServiceTracker.addingService(HttpServiceTracker.java:58)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:990)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:262)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:234)
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:951)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433)
at org.eclipse.equinox.http.servlet.internal.Activator.registerHttpService(Activator.java:81)
at org.eclipse.equinox.http.servlet.internal.Activator.addProxyServlet(Activator.java:60)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.init(ProxyServlet.java:40)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.init(HttpServerManager.java:300)
at org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:473)
at org.eclipse.jetty.servlet.ServletHolder.doStart(ServletHolder.java:293)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)
at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:776)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:258)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:699)
at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:90)
at org.eclipse.jetty.server.Server.doStart(Server.java:263)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:113)
at org.eclipse.equinox.http.jetty.internal.Activator.start(Activator.java:62)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
[Updated on: Tue, 07 February 2012 19:48]
Re: java.util.MissingResourceException occured after changing to RAP1.5M5 [message #793108 is a reply to message #792394] Tue, 07 February 2012 19:38 Go to previous messageGo to next message
Member
Re: java.util.MissingResourceException occured after changing to RAP1.5M5 [message #793517 is a reply to message #793108] Wed, 08 February 2012 08:22 Go to previous message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi all,
from the bug report that David opened:
370724: java.util.MissingResourceException occured after changing to
RAP1.5M5
https://bugs.eclipse.org/bugs/show_bug.cgi?id=370724
I understand that this happens only when the application is deployed in
an external container (jboss, tomcat...). Working fine from within
Eclipse (with Jetty). Could you confirm this?
Please, let continue the discussion/details in the bug report.
Best,
Ivan
> locale: fr
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Ivan Furnadjiev
Twitter: @EclipseRAP
Previous Topic:RAP / Tomcat Issue
Next Topic:Eclipse RAP questions
Current Time: Mon Dec 06 20:44:21 GMT 2021
Powered by FUDForum. Page generated in 0.02325 seconds
