Home » Eclipse Projects » Remote Application Platform (RAP) » HTTP Status 404 - ProxyServlet: /tmf_rap/mcrap
HTTP Status 404 - ProxyServlet: /tmf_rap/mcrap [message #788746] Thu, 02 February 2012 06:55 Go to next message
no name no name is currently offline no name no nameFriend
I am developing RAP application .When i run it from eclipse jetty environment it worked fine but when I deployed war into Jboss5,i got this error
Status report
message ProxyServlet: /tmf_rap/mcrap
description The requested resource (ProxyServlet: /tmf_rap/mcrap) is not available.
I also cheked log files and found this
org.osgi.framework.BundleException: The bundle "com.tcs.mcif.ui_1.0.0 [26]" could not be resolved. Reason: Missing Constraint: Require-Bundle: com.tcs.webdebugger.ui; bundle-version="1.0.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1315)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1299)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:322)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:377)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1109)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
What could be the problem
Any help would appreciate
Smile
Re: HTTP Status 404 - ProxyServlet: /tmf_rap/mcrap [message #788818 is a reply to message #788746] Thu, 02 February 2012 09:05 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
this error message couldn't be much clearer ;-)
You can activate the OSGi console in your web.xml to analyze the problem.
Regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: HTTP Status 404 - ProxyServlet: /tmf_rap/mcrap [message #788846 is a reply to message #788818] Thu, 02 February 2012 09:40 Go to previous message
Hi Ralf,
Thanks for the reply
well the first plugin is my host plugin for enrtypoint
and second is jus a simple plugin which is contributing in RAP UI.
Previous Topic:Capture Screen Shot of WorkSpace
Next Topic:How to add js for widgets?
Current Time: Mon Dec 06 06:52:36 GMT 2021
Powered by FUDForum. Page generated in 0.01862 seconds
