Re: javascript dependency [message #92953 is a reply to message #92099] |
Sat, 07 February 2009 05:17 |
Originally posted by: dave.salesanswer.com
Matthew,
I turned off JavaScript Syntax Validation in
Window/Preferences/Validation. This does not really fix the issue, but
at least if you have a real error it would not be mixed in with hundreds
of erroneous errors on the Problems View.
I am trying to set up a Drupal development environment using PDT. I am
hoping that there is some way to configure the drupal.js and jquery.js
libraries on the one of the Eclipse paths - I have tried but nothing
seems to work.
Do you know of any solutions for this issue?
Dave
Matthew Young wrote:
> Ok, you know exactly what I'm talking about. So I you even find the
> solution, please let me know.
> At the meantime, does anyone else know what to do about this?
>> Unfortunately this isn't a problem with PDT per say. It is a problem
>> with the way the project is setup in Eclipse and there is additional
>> steps needed to make sure the Javascript interpreter knows that you are
>> using jQuery. I am currently in the same process of getting Drupal
>> projects JS files working with Eclipse. If you do a web search for
>> "eclipse jquery" you will see some documentation on the topic. I haven't
>> found a great step-by-step guide to do this setup yet. In the general
>> sense you have to include the the javascript files within the misc
>> directory as an included files to the project even if you aren't
>> interacting with it directly. So jquery.js and drupal.js would be two
>> files as included scripts available to the other javascript files.
>> If / when I find a good guide to getting jQuery working in Eclipse I
>> will post it here.
Re: javascript dependency [message #92968 is a reply to message #92099] |
Sat, 07 February 2009 05:22 |
Matthew,
seems to work.
Dave
>> will post it here.
FUDForum. Page generated in 0.02931 seconds
